Several dts files set a bit in the SPEED field for pads
RGMII_{R,T}{XC,D0,D1,D2,D3,X_CTL}, but that doesn't exist. Writing there
doesn't have an effect and the bit reads as zero.
Signed-off-by: Uwe Kleine-König <uwe@kleine-koenig.org>
Replace the non-standard vendor prefix stm with st for
STMicroelectronics. The drivers do not specify the vendor prefixes
since the I2C Core strips them away from the DT provided compatible
string. Therefore, changing existing device trees does not have any
impact on device detection.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Rob Herring <robh@kernel.org>
Starting with commit 8947e396a829 ("Documentation: dt: mtd: replace
"nor-jedec" binding with "jedec, spi-nor"") we have "jedec,spi-nor"
binding indicating support for JEDEC identification.
Use it for all flashes that are supposed to support READ ID op according
to the datasheets.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Signed-off-by: Silvio Fricke <silvio.fricke@gmail.com>
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
Add support for the PCI express bus available on MX6 Data Modul
edm-qmx6 board.
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
This adds the stdout-path property to various i.MX boards. Values
of the property have been taken from barebox, so they should be
correct. Also, the older linux,stdout-path property is converted
to stdout-path.
GPIO7_12 switches the D+/D- USB lines on and off. When we use this as
VBUS regulator it means that USB device mode can never work as VBUS is
never turned on in Device mode.
Signed-off-by: Silvio F <silvio.fricke@gmail.com>
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
