The license text has been mangled at some point then copy pasted across
multiple files. Restore it to what it should be.
Note that this is not intended as a license change.
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Acked-by: Afzal Mohammed <afzal.mohd.ma@gmail.com>
Acked-by: Michael Trimarchi <michael@amarulasolutions.com>
Acked-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Since commit b36581df7e78 ("spi: imx: Using existing properties for
chipselects") the device tree property 'fsl,spi-num-chipselects' is
unused and it is already marked as obsolete in device tree binding
documentation. Remove the property from the existing DTS files to
avoid its reoccurence on copying.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Several dts files set a bit in the SPEED field for pads
RGMII_{R,T}{XC,D0,D1,D2,D3,X_CTL}, but that doesn't exist. Writing there
doesn't have an effect and the bit reads as zero.
Signed-off-by: Uwe Kleine-König <uwe@kleine-koenig.org>
Embest MarS Board [1] is a multi-core platform based on Freescale i.MX6
Cortex-A9 Dual Core, running up to 1GHz with 1 GB of RAM, 4GB of eMMC
and with a 4MB SPI flash.
[1] http://www.embest-tech.com/shop/star/marsboard.html
Signed-off-by: Sergio Prado <sergio.prado@e-labworks.com>
