path: root/arch/arm/boot/dts/imx6q-sabreauto.dts
2013-08-22ARM: dtsi: enable ahci sata on imx6q platformsRichard Zhu
Only imx6q has the ahci sata controller, enable it on imx6q platforms. Signed-off-by: Richard Zhu <r65037@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-08-22ARM: dts: imx: share pad macro names between imx6q and imx6dlShawn Guo
The imx6q and imx6dl are two pin-to-pin compatible SoCs. The same board design can work with either chip plugged into the socket, e.g. sabresd and sabreauto boards. We currently define pin groups in imx6q.dtsi and imx6dl.dtsi respectively because the pad macro names are different between two chips. This brings a maintenance burden on having the same label point to the same pin group defined in two places. The patch replaces prefix MX6Q_ and MX6DL_ with MX6QDL_ for both SoCs pad macro names. Then the pin groups becomes completely common between imx6q and imx6dl and can just be moved into imx6qdl.dtsi, so that the long term maintenance of imx6q/dt pin settings becomes easier. Unfortunately, the change brings some dramatic diff stat, but it's all about DTS file, and the ultimate net diff stat is good. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-06-17ARM: dts: imx6q{dl}: fix the pin conflict between SPI and WEIMHuang Shijie
In the imx6q-sabreauto and imx6dl-sabreauto boards, the pin MX6Q{DL}_PAD_EIM_D19 is used as a GPIO for SPI NOR, but it is used as a data pin for the WEIM NOR. In order to fix the conflict, this patch removes the pin from the hog, and adds a new board-level pinctrl: pinctrl_ecspi1_sabreauto. The SPI NOR selects this pinctrl_ecspi1_sabreauto when it is enabled. Signed-off-by: Huang Shijie <b32955@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-06-17ARM: dts: imx6q: add a gpio for hogHuang Shijie
The SPI/NOR needs this gpio for CS. So add this gpio in the hog pinctrl. Signed-off-by: Huang Shijie <b32955@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-04-09ARM: dts: imx: make sabreauto and sabresd commonShawn Guo
The sabreauto and sabresd boards are common for imx6q and imx6dl. Create imx6qdl-sabreauto.dtsi and imx6qdl-sabresd.dtsi for those common parts. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-04-09pinctrl: imx: move hard-coding data into device treeShawn Guo
Currently, all imx pinctrl drivers maintain a big array of struct imx_pin_reg which hard-codes data like register offset and mux mode setting for each pin function. Every time a new imx SoC support is added, we need to add such a big mount of data. With moving to single kernel build, it's only matter of time to be blamed on memory consuming. With DTC pre-processor support in place, the patch moves all these data into device tree by redefining the PIN_FUNC_ID in imxXX-pinfunc.h and changing the PIN_FUNC_ID parsing code a little bit. The pin id gets re-numbered based on mux register offset, or config register offset if the pin has no mux register, so that kernel can identify the pin id from register offsets provided by device tree. As a bonus point of the change, those arbitrary magic numbers standing for particular PIN_FUNC_ID in device tree sources are now replaced by macros to improve the readability of dts files. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Dong Aisheng <dong.aisheng@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2013-04-09ARM: imx: use #include for all device treesShawn Guo
Replace /include/ (dtc) with #include (C pre-processor) for all imx DT files, so that gcc -E handles the entire include tree, and hence any of those files can #include some other file e.g. for constant definitions. This allows future use of #defines and header files in order to define names for various constants, such as pinctrl settings. Use of those features will increase the readability of the device tree files. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-02-10ARM: dts: add dtsi for imx6q and imx6dlShawn Guo
Add dtsi for imx6q and imx6dl with non-common blocks moved into there. Major differences between imx6dl and imx6q: * Dual vs. Quad cores * single vs. dual IPU * 128 vs. 256 KB OCRAM * imx6q: ECSPI5, OpenVG (GC355), SATA * imx6dl: I2C4, PXP, EPDC, LCDIF * iomuxc/pads definition Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-02-10ARM: dts: rename imx6q.dtsi to imx6qdl.dtsiShawn Guo
i.MX6 Quad and i.MX6 DualLite is similar enough to share one dtsi file, so rename imx6q.dtsi to imx6qdl.dtsi preparing for the addition of imx6dl support. Another member of i.MX6 series i.MX6 SoloLite is different enough from the other two, so it will stand as a separate dtsi. That's why we rename to imx6qdl.dtsi not imx6.dtsi. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-02-10ARM: dts: imx: use nodes label in board dtsShawn Guo
Following omap3-evm.dts way, it changes all imx dts files to use label in board dts to refer to nodes defined by soc dtsi. Thus, the board dts files become easier to read and edit with the least indentation levels. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2012-11-16ARM: dts: imx6q-sabreauto: Add basic supportFabio Estevam
mx6qsabreauto is a board based on mx6q SoC with the following features: - 2GB of DDR3 - 2 USB ports - 1 HDMI output port - SPI NOR - 2 LVDS LCD ports - Gigabit Ethernet - Camera - eMMC and SD card slot - Multichannel Audio - CAN - SATA - NAND - PCIE - Video Input Add very basic support for it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2011-12-14arm/imx6q: Rename Sabreauto to Armadillo2Dirk Behme
The Sabreauto board was renamed to Armadillo2 recently. To avoid confusion, rename Sabreauto to Armadillo2/arm2. Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2011-12-14dts/imx: rename uart labels to consistent with hw specRichard Zhao
UART1/UART2/... is more readable than UART0/UART1/... . Remove redundant UART comments. Signed-off-by: Richard Zhao <richard.zhao@linaro.org> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2011-12-14dts/imx: rename gpio labels to consistent with hw specRichard Zhao
GPIO1/GPIO2/... is more readable than GPIO0/GPIO1/... . Remove redundant gpio comments. Signed-off-by: Richard Zhao <richard.zhao@linaro.org> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2011-10-31arm/imx6q: add device tree sourceShawn Guo
It adds device tree source and documentation for imx6q platform. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
