path: root/arch/arm/boot/dts/imx6q-ts4900.dts
2020-02-09ARM: dts: imx6: Pass memory unit-adressFabio Estevam
Pass the memory unit-adress to fix the following build warnings with W=1: Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name There are cases where dts passes an empty memory node, which will be filled by the bootloader. Passing the memory base address still allows the bootloader to fill the memory size. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Acked-By: Lothar Waßmann <LW@KARO-electronics.de> Signed-off-by: Shawn Guo <shawnguo@kernel.org> (cherry picked from commit edc05819786fd5eee330b89bd5892dad1199effc) Conflicts: arch/arm/boot/dts/imx6dl-colibri-eval-v3.dts arch/arm/boot/dts/imx6dl-dfi-fs700-m60.dts arch/arm/boot/dts/imx6dl-ts4900.dts arch/arm/boot/dts/imx6dl-ts7970.dts arch/arm/boot/dts/imx6q-dfi-fs700-m60.dts arch/arm/boot/dts/imx6q-h100.dts arch/arm/boot/dts/imx6q-novena.dts arch/arm/boot/dts/imx6q-ts4900.dts arch/arm/boot/dts/imx6q-ts7970.dts arch/arm/boot/dts/imx6q-zii-rdu2.dts arch/arm/boot/dts/imx6qdl-apalis.dtsi arch/arm/boot/dts/imx6qdl-cubox-i.dtsi arch/arm/boot/dts/imx6qdl-hummingboard.dtsi arch/arm/boot/dts/imx6qdl-hummingboard2.dtsi arch/arm/boot/dts/imx6qp-zii-rdu2.dts arch/arm/boot/dts/imx6ul-tx6ul.dtsi arch/arm/boot/dts/imx6ull-colibri-nonwifi.dtsi arch/arm/boot/dts/imx6ull-colibri-wifi.dtsi Signed-off-by: Philippe Schenker <philippe.schenker@toradex.com>
2017-01-10ARM: dts: imx/vf: Correct license textAlexandre Belloni
The license text has been mangled at some point then copy pasted across multiple files. Restore it to what it should be. Note that this is not intended as a license change. Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Afzal Mohammed <afzal.mohd.ma@gmail.com> Acked-by: Michael Trimarchi <michael@amarulasolutions.com> Acked-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-08-15ARM: dts: TS-4900: add basic device treeLucile Quirion
These device trees add support for TS-4900 by Technologic Systems. More details here: http://wiki.embeddedarm.com/wiki/TS-4900 Signed-off-by: Lucile Quirion <lucile.quirion@savoirfairelinux.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
