path: root/arch/arm/boot/dts/imx6q-tx6q-1010-comtft.dts
2019-02-12MLK-11431-4: ARM: DTS: imx: Update IPU and display propertySandor Yu
Update IPU and display property, make sure these dts files can pass build. Signed-off-by: Sandor Yu <R01008@freescale.com>
2016-11-02ARM: dts: imx: Fix "ERROR: code indent should use tabs where possible"Jagan Teki
Fixed code indent tabs in respetcive imx23, imx51, imx53, imx6dl, imx6q and imx6sx dtsi and dts files. Signed-off-by: Jagan Teki <jagan@openedev.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-04-13ARM: dts: imx6-tx6: Relicense the Ka-Ro DT files under GPLv2/X11Lothar Waßmann
GPLv2-only devicetrees make reuse difficult for software components licensed under a different license. The consensus is that a GPL/X11 dual-license should allow all necessary uses, so relicense the imx6*-tx6* files to this combination. Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2014-07-18ARM: dts: imx6: add support for Ka-Ro TX6 modulesLothar Waßmann
This patch adds support for the Ka-Ro electronics GmbH TX6 modules. There are five distinct module types with either i.MX6Q or i.MX6DL and LVDS or LCD display interface and one DTS file for a complete system with an i.MX6DL based TX6 module and a baseboard mounted on the back of a display (imx6dl-tx6dl-comtft.dts). Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
