path: root/arch/arm/boot/dts/imx6q-tx6q-1036.dts
2016-04-13ARM: dts: imx6: add support for more Ka-Ro electronics modulesLothar Waßmann
Add support for the following i.MX6 based modules from Ka-Ro electronics GmbH: TX6S-8034: Processor Freescale i.MX 6 Solo, 800MHz RAM 256MiB DDR3 SDRAM ROM 128MiB NAND Flash Power supply Single 3.1V to 5.5V Size 31mm SO-DIMM Temp. Range industrial grade (-40°C/-25°C to 105°C Tj) TX6S-8035: Processor Freescale i.MX 6 Solo, 800MHz RAM 512MiB DDR3 SDRAM ROM 4GiB eMMC Power supply Single 3.1V to 5.5V Size 31mm SO-DIMM Temp. Range industrial grade (-40°C/-25°C to 105°C Tj) TX6U-8033: Processor Freescale i.MX 6 Dual Lite, 800MHz RAM 1GiB DDR3 SDRAM ROM 4GiB eMMC Power supply Single 3.1V to 5.5V Size 31mm SO-DIMM Temp. Range industrial grade (-40°C/-25°C to 105°C Tj) TX6Q-1036: Processor Freescale i.MX 6Quad, 1GHz RAM 1GB DDR3 SDRAM 64-bit ROM 8GiB eMMC Power supply Single 3.1V to 5.5V Size 31mm SO-DIMM Temp. Range Extended Consumer Grade (-20°C to 105°C Tj) Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
