path: root/arch/arm/boot/dts/imx6q-udoo.dts
2018-05-14ARM: dts: imx6qdl-udoo: Switch to SPDX identifierFabio Estevam
Adopt the SPDX license identifier headers to ease license compliance management. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2015-01-06ARM: dts: imx6dl-udoo: Add board support based off imx6q-udooRobert Nelson
For more information about the Udoo boards: http://www.udoo.org/ Signed-off-by: Robert Nelson <robertcnelson@gmail.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-07-18ARM: dts: imx6q-udoo: Add USB Host supportFabio Estevam
Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-05-16ARM: dts: imx6q-udoo: Add HDMI supportFabio Estevam
2014-05-16ARM: dts: Add stdout-path property to i.MX boardsSascha Hauer
This adds the stdout-path property to various i.MX boards. Values of the property have been taken from barebox, so they should be correct. Also, the older linux,stdout-path property is converted to stdout-path. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-02-09ARM: dts: imx6q-udoo: Add Ethernet supportFabio Estevam
Add Ethernet support for imx6q udoo board. Tested by booting a kernel via NFS. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-02-09ARM: dts: imx6qdl: make pinctrl nodes board specificShawn Guo
Currently, all pinctrl setting nodes are defined in <soc>.dtsi, so that boards that share the same pinctrl setting do not have to define it time and time again in <board>.dts. However, along with the devices and use cases being added continuously, the pinctrl setting nodes under iomuxc becomes more than expected. This bloats device tree blob for particular board unnecessarily since only a small subset of those pinctrl setting nodes will be used by the board. It impacts not only the DTB file size but also the run-time device tree lookup efficiency. The patch moves all the pinctrl data into individual boards as needed. With the changes, the pinctrl setting nodes becomes local to particular board, and it makes no sense to continue numbering the setting for given peripheral. Thus, all the pinctrl phandler name gets updated to have only peripheral name in there. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-09-27ARM: dts: imx6q-udoo: Add initial board supportFabio Estevam
For more information about the Udoo board: http://www.udoo.org/ Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
