path: root/arch/arm/boot/dts/imx6q-wandboard-revd1.dts
2018-12-10ARM: dts: imx6qdl: Fix memory node duplicationMarco Franchi
Boards based on imx6qdl have duplicate memory nodes: - One coming from the board device tree file: memory@ - One coming from the imx6qdl.dtsi file. Fix the duplication by removing the memory node from the imx6qdl.dtsi file and by adding 'device_type = "memory";' in the board Device Tree. Converted using the following command: perl -p0777i -e 's/memory\@10000000 \{\n/memory\@10000000 \{\n\t\tdevice_type = \"memory\";\n/m' `find ./arch/arm/boot/dts -name "imx6*"`` Reported-by: Rob Herring <robh@kernel.org> Signed-off-by: Marco Franchi <marco.franchi@nxp.com> Reviewed-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2018-05-14ARM: dts: imx6qdl-wandboard: Switch to SPDX identifierFabio Estevam
Adopt the SPDX license identifier headers to ease license compliance management. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2018-02-12ARM: dts: imx: Add memory node unit nameMarco Franchi
Fix the following warnings from dtc by adding the unit name to memory nodes: Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name Converted using the following command: perl -p0777i -e 's/memory \{\n\t\treg = \<0x+([0-9a-f])/memory\@$1$\0000000 \{\n\t\treg = <0x$1/m' `find ./arch/arm/boot/dts -name "imx*"` The files below were manually fixed: -imx1-ads.dts -imx1-apf9328.dts -imx6q-pistachio.dts Signed-off-by: Marco Franchi <marco.franchi@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-10-23ARM: dts: imx6qdl-wandboard: Add support for the revd1 variantsFabio Estevam
Latest wandboard hardware revision is revd1, which brings the following new features: - PFUZE100 PMIC - AR8035 Ethernet PHY - Upgrade Wifi/BT chip to BCM4339/BCM43430. Add support for the mx6, mx6dl and mx6qp revd1 variants. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
