When VPU is running at 396MHz, need to increase
VDDSOC_CAP voltage for all cpu set-points, so add
vpu clock node for cpufreq driver.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Add busfreq device node label to allow override busfreq
properties on machine device tree descriptor
Signed-off-by: Adrian Alonso <aalonso@freescale.com>
Signed-off-by: Anson Huang <b20788@freescale.com>
(cherry picked from commit fd8faeb7a40fc2f9fb331d6ca6a60b64c95d7ee6)
Currently 128M reserved for GPU in all the i.MX6 boards that is
requiring kernel to allocate CMA 320M. For the low end devices like 6SX
and 6SL, the 320M is huge. Sometimes customer board may have very less
RAM.
With Kernel 4.1, there is a new feature CMA can be calculated at DTS
level based on the amount queried from different module drivers.So
moving the GPU memory to DTS is valid and can be configured for each
board.
And at the same time, also keep the option for user to configure the
parameters "contiguousBase and contiguousSize" in u-boot.
Signed-off-by: Shawn Xiao <b49994@freescale.com>
Add imx v4l2 capture driver.
Signed-off-by: Sandor Yu <R01008@freescale.com>
add ldo bypass support on i.mx6q/dl and i.mx6sl.
Signed-off-by: Robin Gong <b38343@freescale.com>
There was a missing parenthesis from the following patch:
commit d55d221778065c6537e4369c11ca175f61aa3cd0
Author: Shawn Xiao <b49994@freescale.com>
Date: Wed Aug 26 15:29:26 2015 +0800
Signed-off-by: Oliver Brown <oliver.brown@freescale.com>
1. Upstream 5.0.11p7 driver to kernel
2. Add the GPU configuration to imx6q.dtsi
3. Remove IRQF_DISABLED in GPU driver
The IRQF_DISABLED has been removed from 4.1.0 kernel. To accomodate with
the change, add version check logic and use 0x0 instead of IRQF_DISABLED
from 4.1.0 kernel on.
4. Convert file->f_dentry->d_inode to file_inode() in GPU driver
The file struct has changed since 3.19. Changed the usage in GPU driver
too.
5. Add version check for CONFIG_PM_RUNTIME
The CONFIG_PM_RUNTIME will never be used in 4.1.0 kernel. Add version
check to avoid calling it in GPU driver.
Add IPU, HDMI and LDB support.
Add busfreq support for i.MX6Q/DL.
Add pll1, pll1_bypass and pll1_bypass_src clock
reference define in dts file.
Signed-off-by: Bai Ping <b51503@freescale.com>
Reserve iram space for low power code. The first 16KB space
is used for suspend/resume and cpuidle. Another 4KB space is
for busfreq code.
for i.MX6SX, it has a dedicated ocram space start at 0x8f8000
for low power code.
The MIPI DSI node contains some ports which represent possible DRM CRTCs
it can connect with. Each port has a 'reg' property embedded. This
property will be wrongly interpretted by the MIPI DSI bus driver, because
the driver will take each subnode which contains a 'reg' property as a
DSI peripheral device. This patch moves the existing MIPI DSI ports into
a new 'ports' node so that the MIPI DSI bus driver may distinguish its
DSI peripheral device(s) from the existing ports.
Acked-by: Philipp Zabel <p.zabel@pengutronix.de>
Signed-off-by: Liu Ying <Ying.Liu@freescale.com>
Enable dma support for ecspi5 controller
Signed-off-by: Anton Bondarenko <anton_bondarenko@mentor.com>
According to latest i.MX6Q datasheet Rev. 3, 02/2014,
the latest cpufreq volt/freq table is as below:
LDO enabled/bypassed(min value):
996MHz: VDDARM: 1.225V, VDDSOC: 1.150V;
792MHz: VDDARM: 1.150V, VDDSOC: 1.150V;
396MHz: VDDARM: 0.925V, VDDSOC: 1.150V;
the 792MHz setpoint's VDDARM min voltage is updated
from 1.125V to 1.150V, adding 25mV to cover board IR
drop, 1.175V is the right voltage we should use.
This patch adds links to the on-chip SRAM and reset controller nodes
and switches the interrupts. Make the BIT processor interrupt, which exists on
all variants, the first one. The JPEG unit interrupt, which does not exist on
i.MX27 and i.MX5 thus is an optional second interrupt.
Use different compatible strings for i.MX6Q/D and i.MX6S/DL, as they have to
load separate firmware images for some reason.
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
Switch to use DT macro for clock ID, so that device tree source is more
readable.
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
This patch adds CSI subnodes for IPU1 and IPU2 that will contain
ports and endpoints connecting to external elements in the video
pipeline.
Pull ARM SoC device tree changes from Arnd Bergmann:
"A large part of the arm-soc patches are nowadays DT changes, adding
support for new SoCs, boards and devices without changing kernel
source. The plan is still to move the devicetree files out of the
kernel tree and reduce the amount of churn going on here, but we keep
finding reasons to delay doing that.
Changes are really all over the place, with little sticking out
particularly. We have contributions from a total of 116 people in
this branch.
Unfortunately, the size of this branch also causes a significant
number of conflicts at the moment, typically when subsystem
maintainers merge patches that change the driver at the same time as
the dts files. In most cases this could be avoided because the dts
changes are supposed to be compatible in both ways, and we are asking
everyone to send ARM dts changes through our tree only"
* tag 'dt-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (541 commits)
dts: stmmac: Document the clocks property in the stmmac base document
dts: socfpga: Add DTS entry for adding the stmmac glue layer for stmmac.
ARM: STi: stih41x: Add support for the FSM Serial Flash Controller
ARM: STi: stih416: Add support for the FSM Serial Flash Controller
ARM: tegra: fix Dalmore pinctrl configuration
ARM: dts: keystone: use common "ti,keystone" compatible instead of -evm
ARM: dts: k2hk-evm: set ubifs partition size for 512M NAND
ARM: dts: Build all keystone dt blobs
ARM: dts: keystone: Fix control register range for clktsip
ARM: dts: keystone: Fix domain register range for clkfftc1
ARM: dts: bcm28155-ap: leave camldo1 on to fix reboot
ARM: dts: add bcm590xx pmu support and enable for bcm28155-ap
ARM: dts: bcm21664: Add device tree files.
ARM: DT: bcm21664: Device tree bindings
ARM: efm32: properly namespace i2c location property
ARM: efm32: fix unit address part in USART2 device nodes' names
ARM: mvebu: Enable NAND controller in Armada 385-DB
ARM: mvebu: Add support for NAND controller in Armada 38x SoC
ARM: mvebu: Add the Core Divider clock to Armada 38x SoCs
ARM: mvebu: Add a 2 GHz fixed-clock on Armada 38x SoCs
This patch connects IPU and display encoder (HDMI, LVDS, MIPI)
device tree nodes, as well as parallel displays on the DISP0
and DISP1 outputs, using the OF graph bindings described in
Documentation/devicetree/bindings/media/video-interfaces.txt
The IPU ports correspond to the two display interfaces. The
order of endpoints in the ports is arbitrary.
Each encoder with an associated input multiplexer has multiple
input ports in the device tree. The order and reg property of
the ports must correspond to the multiplexer input order.
Since the imx-drm node now only needs to contain links to the
display interfaces, it can be moved to the SoC dtsi level. At
the board level, only connections between the display interface
ports and encoders or panels have to be added.
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
Extracted from another patch by Fabio Estevam, this adds the DT
configuration for HDMI output on the IMX6 SoCs
According to datasheet, i.MX6Q has setpoint of 852MHz
which is exclusive with 996MHz, the fuse map of speed_grading
defines the max speed of ARM, here we add this 852MHz
setpoint opp info, kernel will check the speed_grading
fuse and remove all illegal setpoints.
The quad version has a SPI controller more than the other
versions. Add an alias for it.
i.MX6Q needs to update vddarm, vddsoc/pu regulators when cpu freq
is changed, each setpoint has different voltage, so we need to
pass vddarm, vddsoc/pu's freq-voltage info from dts together.
According to datasheet, VDD_CACHE_CAP must not exceed VDDARM_CAP
by more than 200mV, as all of i.MX6Q boards' VDD_CACHE_CAP currently
are connected to VDDSOC_CAP, so we need to follow this rule by
increasing VDDARM_CAP's voltage.
Make the interrupts node slightly more readable.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
The ocram on imx6q is 256 KiB while on imx6dl it's 128 KiB. Let's
have separate node for imx6q and imx6dl. It also changes imx6q size
0x3f000 to 0x40000 to match the hardware.
Acked-by: Liu Ying <Ying.Liu@freescale.com>
Only imx6q has the ahci sata controller, enable
it on imx6q platforms.
Signed-off-by: Richard Zhu <r65037@freescale.com>
Add more imx6q/dl pin groups for those supported boards, e.g. sabresd,
sabreauto, arm2.
IPU2 pin groups are added into imx6q.dtsi, since the block is only
available on imx6q.
The imx6q and imx6dl are two pin-to-pin compatible SoCs. The same board
design can work with either chip plugged into the socket, e.g. sabresd
and sabreauto boards.
We currently define pin groups in imx6q.dtsi and imx6dl.dtsi
respectively because the pad macro names are different between two
chips. This brings a maintenance burden on having the same label point
to the same pin group defined in two places.
The patch replaces prefix MX6Q_ and MX6DL_ with MX6QDL_ for both SoCs
pad macro names. Then the pin groups becomes completely common between
imx6q and imx6dl and can just be moved into imx6qdl.dtsi, so that the
long term maintenance of imx6q/dt pin settings becomes easier.
Unfortunately, the change brings some dramatic diff stat, but it's all
about DTS file, and the ultimate net diff stat is good.
In the arm2 board, the UART2 works in the dte mode.
So add a pinctrl for both the imx6q{dl} boards.
Signed-off-by: Huang Shijie <b32955@freescale.com>
The i.MX6Q and i.MX6DL are pin compatible, so the pinmux entries
should be in sync. This patch systematically adds the pinmux entries
missing from the imx6q to the imx6dl file.
Some name inconsistencies and whitespace damage is fixed along the
way.
This new pinctrl is used by the imx6q-sabresd board.
into next/dt
From Shawn Guo:
imx device tree changes for 3.11:
* A bunch of new board additions, imx6sl-evk, vf610-twr, imx53-tx53,
imx53-m53evk and imx27-phytec-phycore
* Various pinctrl setting updates and additions
* Enable various on board peripherals, usb, audio, nor, display etc.
* Configure L2 cache data and tag latency from device tree
* Add imx-weim bus driver
* tag 'imx-dt-3.11' of git://git.linaro.org/people/shawnguo/linux-2.6: (82 commits)
ARM: dts: imx27: Add VPU devicetree node
ARM: mxc: fix gpio-ranges for VF610
ARM: dtsi: imx6qdl-sabresd: Enable WM8962 audio support
ARM: dtsi: imx6qdl-sabresd: Enable SSI2 and AUDMUX
ARM: dtsi: imx6qdl-sabresd: Add WM8962 CODEC support
ARM: dtsi: imx6qdl-sabresd: add a fixed regulator for WM8962
ARM: dtsi: imx6dl: Add a pinctrl for AUDMUX
ARM: dtsi: imx6q/imx6dl: Add a pinctrl for I2C1
ARM: dts: imx6qdl-sabresd: add clko1 iomux configuration
ARM: dts: Phytec imx6q pfla02 and pbab01 support
ARM: dts: imx6q: Add pinctrl for usdhc2 and enet
ARM: dts: imx27-phytec-phycore-rdk: Add MTD name for NOR flash
ARM: dts: imx27-phytec-phycore-rdk: Add SDHC support
ARM: dts: i.MX27: Add SDHC devicetree nodes
ARM: dts: i.MX27: Add DMA devicetree node
ARM: dts: imx6qdl-sabreauto: enable the WEIM NOR
ARM: dts: imx6dl: add pinctrls for WEIM NOR
ARM: dts: imx6q: add pinctrls for WEIM NOR
ARM: dts: imx6qdl: add more information for WEIM
ARM: dts: imx6q{dl}: fix the pin conflict between SPI and WEIM
Add a pinctrl for I2C1 used on imx6q/dl-sabresd.
Signed-off-by: Nicolin Chen <b42378@freescale.com>
Add a group to the usdhc2 and enet pinctrl.
Signed-off-by: Christian Hemp <c.hemp@phytec.de>
Add two pinctrls for WEIM:
one for the weim nor, another for the chipselect.
The gpmi does not use the MX6Q_PAD_NANDF_CS2__NAND_CE2_B and
MX6Q_PAD_NANDF_CS3__NAND_CE3_B.
Just remove them.
This patch updates the in-kernel dts files according to the latest cpus
and cpu bindings updates for ARM.
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Reviewed-by: Pavel Machek <pavel@ucw.cz>
Add ldb device tree node and clock lookups.
Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de>
Allow AUD3 to be used as audio output from the audmux block.
Signed-off-by: Sean Cross <xobs@kosagi.com>
Add groups to allow i2c2 and i2c3 to be used on imx6q.
Add a group of pins to allow ecspi3 to be used on imx6q.
Currently, all imx pinctrl drivers maintain a big array of struct
imx_pin_reg which hard-codes data like register offset and mux mode
setting for each pin function. Every time a new imx SoC support is
added, we need to add such a big mount of data. With moving to single
kernel build, it's only matter of time to be blamed on memory consuming.
With DTC pre-processor support in place, the patch moves all these data
into device tree by redefining the PIN_FUNC_ID in imxXX-pinfunc.h and
changing the PIN_FUNC_ID parsing code a little bit.
The pin id gets re-numbered based on mux register offset, or config
register offset if the pin has no mux register, so that kernel can
identify the pin id from register offsets provided by device tree.
As a bonus point of the change, those arbitrary magic numbers standing
for particular PIN_FUNC_ID in device tree sources are now replaced by
macros to improve the readability of dts files.
Acked-by: Dong Aisheng <dong.aisheng@linaro.org>
Replace /include/ (dtc) with #include (C pre-processor) for all imx DT
files, so that gcc -E handles the entire include tree, and hence any of
those files can #include some other file e.g. for constant definitions.
This allows future use of #defines and header files in order to define
names for various constants, such as pinctrl settings. Use of those
features will increase the readability of the device tree files.
Add USB support for imx6q sabresd board
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Add dtsi for imx6q and imx6dl with non-common blocks moved into there.
Major differences between imx6dl and imx6q:
* Dual vs. Quad cores
* single vs. dual IPU
* 128 vs. 256 KB OCRAM
* imx6q: ECSPI5, OpenVG (GC355), SATA
* imx6dl: I2C4, PXP, EPDC, LCDIF
* iomuxc/pads definition
i.MX6 Quad and i.MX6 DualLite is similar enough to share one dtsi
file, so rename imx6q.dtsi to imx6qdl.dtsi preparing for the addition
of imx6dl support.
Another member of i.MX6 series i.MX6 SoloLite is different enough
from the other two, so it will stand as a separate dtsi. That's why
we rename to imx6qdl.dtsi not imx6.dtsi.
For ANATOP LDOs, vddcpu, vddsoc and vddpu
have step time settings in the misc2 register, need
to add necessary step time info for these three LDOs,
then regulator driver can add necessary delay based on
these settings.
offset 0x170:
bit [24-25]: vddcpu
bit [26-27]: vddpu
bit [28-29]: vddsoc
field definition:
0'b00: 64 cycles of 24M clock;
0'b01: 128 cycles of 24M clock;
0'b02: 256 cycles of 24M clock;
0'b03: 512 cycles of 24M clock;
