2018-03-08 | ARM: dts: imx6: use SNVS RTC label | Stefan Agner | |
The SNVS RTC does not use an address in its node name anymore. Instead of using the full path, simply use the SNVS RTC label. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2017-12-21 | ARM: dts: imx6: forward port downstream apalis / ixora combination | Max Krummenacher | |
Forward port the device tree sources for the Apalis iMX6 / Ixora module - carrier combination from the downstream toradex_4.1-2.0.x-imx branch. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> |
