Update IPU and display property, make sure these dts files can
pass build.
Signed-off-by: Sandor Yu <R01008@freescale.com>
The FEC driver ignores the GPIO polarity from 'phy-reset-gpios' and
considers that the Ethernet PHY is active low, unless the
property 'phy-reset-active-high' is present.
Fix the device tree description by explicitly passing the
'GPIO_ACTIVE_LOW' flag to the 'phy-reset-gpios' property.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Since commit b36581df7e78 ("spi: imx: Using existing properties for
chipselects") the device tree property 'fsl,spi-num-chipselects' is
unused and it is already marked as obsolete in device tree binding
documentation. Remove the property from the existing DTS files to
avoid its reoccurence on copying.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
As of commit 1006ed7e1b258dac ("serial: imx: Use generic uart-has-rtscts
DT property"), the Freescale IMX UART driver recognizes the generic
"uart-has-rtscts" DT property, deprecating the vendor-specific
"fsl,uart-has-rtscts" DT property. Hence replace the latter by the
former in all DTS files.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Starting with commit 8947e396a829 ("Documentation: dt: mtd: replace
"nor-jedec" binding with "jedec, spi-nor"") we have "jedec,spi-nor"
binding indicating support for JEDEC identification.
Use it for all flashes that are supposed to support READ ID op according
to the datasheets.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
cd-gpios polarity should be changed to GPIO_ACTIVE_LOW and wp-gpios
should be changed to GPIO_ACTIVE_HIGH.
Otherwise, the SD may not work properly due to wrong polarity inversion
specified in DT after switch to common parsing function mmc_of_parse().
Signed-off-by: Dong Aisheng <aisheng.dong@freescale.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
This patch add support for the imx6dl based aristainetos board
with following configuration:
CPU: Freescale i.MX6DL rev1.1 at 792 MHz
DRAM: 1 GiB
NAND: 512 MiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
SF: Detected N25Q128 with page size 256 Bytes, erase size 64 KiB, total 16 MiB
As this board can used with 2 different display types, the
differences between them are extracted into 2 DTS files, and
the common settings are collected in a common file.
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
