Boards based on imx6qdl have duplicate memory nodes:
- One coming from the board device tree file: memory@
- One coming from the imx6qdl.dtsi file.
Fix the duplication by removing the memory node from
the imx6qdl.dtsi file and by adding 'device_type = "memory";'
in the board Device Tree.
Converted using the following command:
perl -p0777i -e 's/memory\@10000000 \{\n/memory\@10000000 \{\n\t\tdevice_type = \"memory\";\n/m' `find ./arch/arm/boot/dts -name "imx6*"``
Reported-by: Rob Herring <robh@kernel.org>
Signed-off-by: Marco Franchi <marco.franchi@nxp.com>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
Pass the memory unit-adress to fix the following build warnings with W=1:
Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name
There are cases where dts passes an empty memory node, which will be filled
by the bootloader. Passing the memory base address still allows the
bootloader to fill the memory size.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Acked-By: Lothar Waßmann <LW@KARO-electronics.de>
In preparation for removing 'reg = <0 0>;' from the dtsi SoC files, pass
'reg = <0 0 >;' to the dts/dtsi board files that do not pass the memory
size.
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Fabio Estevam suggested using GPIO_ACTIVE_HIGH in the gpio specification
for the USB regulators. Change them to conform.
Suggested-by: Fabio Estevam <festevam@gmail.com>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
Node names are supposed to be generic, fix the RTC and codec node
names for both Hummingboard and Cubox-i.
Make the regulators match the schematic - name the regulators after
one of their schematic supply names, and arrange them into their
heirarchy.
Move the microsom includes into the .dts files so different options can
be accomodated at the lowest level.
Jon and myself feel that "imx6qdl-microsom" is too generic a name for
SolidRun's microsom - some other manufacturer could have their own
microsom. Change the name to the shorter "imx6qdl-sr-som".
As all SolidRun microsoms are fitted with an AR8035, it's pointless
having the ethernet support as a separate include file. Move the
AR8035 support into the main imx6qdl-microsom file.
The regulators node is redundant, and serves no useful function.
Remove it from i.MX6 SolidRun platforms.
The license text has been mangled at some point then copy pasted across
multiple files. Restore it to what it should be.
Note that this is not intended as a license change.
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Acked-by: Afzal Mohammed <afzal.mohd.ma@gmail.com>
Acked-by: Michael Trimarchi <michael@amarulasolutions.com>
Acked-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
cd-gpios polarity should be changed to GPIO_ACTIVE_LOW and wp-gpios
should be changed to GPIO_ACTIVE_HIGH.
Otherwise, the SD may not work properly due to wrong polarity inversion
specified in DT after switch to common parsing function mmc_of_parse().
Signed-off-by: Dong Aisheng <aisheng.dong@freescale.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Arrange the license text a bit to make it clear.
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
The Cubox has a recessed button between the HDMI and RJ-45 connectors
that wasn't mapped in the device tree, so I've mapped it to gpio-keys
BTN_0.
Signed-off-by: George Joseph <george.joseph@fairview5.com>
Tested-by: George Joseph <george.joseph@fairview5.com>
Update SolidRun iMX6 platforms DT descriptions to be dual-licensed.
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Acked-by: Rabeeh Khoury <rabeeh@solid-run.com>
All PWM users should explicitly enable the used PWMs in their device tree
so they can be disabled by default in imx6qdl.dtsi.
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
Hummingboard has no over current hardware, so disable the over current
detection for both ports.
Cubox-i has over current hardware, so appropriately configure this.
The configuration of the USB OTG is a platform configuration decision,
not a microsom decision. Move this configuration out to the platform
level files.
The front panel LED on the Cubox-i is driven by one of the iMX6 PWM
channels, and is wired between the PWM output and supply.
Add the HDMI DT configuration for the SolidRun HummingBoard and Cubox-i.
The spdif pinmux configuration must be connected to the spdif device to
take effect, not the spdif-transmitter.
Add support for the SolidRun Cubox-i devices. This commit adds similar
basic support as the HummingBoard. Further devices will be supported
in future patches.
