Update IPU and display property, make sure these dts files can
pass build.
Signed-off-by: Sandor Yu <R01008@freescale.com>
bc677ff42e81bbf78308a7b66cf7b63b0f5c26b0 adds a device-tree property
to specify that an external watchdog reset is used to reset other
portions of the board and not just the IMX6 SoC.
This adds the property to the proper watchdog as well as the pinmux for
the Gateworks Ventana boards that use this external watchdog reset to
reset the PMIC which will reset all the PMIC power rails and not just
a chip-level IMX6 reset. This helps to work around various system issues
that can cause a hang when coming out of reset.
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
Fix some invalid pwm pinmux configurations.
Ventana boards have an off-board connector with signals that can be pinmuxed
as either GPIO or PWM. This patch adds pwm device-tree nodes in the disabled
state which the bootloader can decide to enable based on bootloader config.
UHS-I support is available on Ventana boards with micro-SD sockets depending
on the board revision. To support this pinctl states for 100Mhz and 200MHz
must be added as well as pinmux of the VSELECT signal. In order to support
UHS-I the I/O rail of the 4-bit data bus must be switchable between 1.8V
and 3.3V.
By adding the no-1-8-v property, which disables UHS-I support, we allow the
bootloader to be in charge of selecting which boards have this capability
by removing that property if the board model/revision implement the support.
Additionally we will remove NANDF_CS1 here from the nand pinmux group as the
second chip-select is not used on any ventana boards and this is the pad
that is used for SD3_VELECT.
Add support for the Gateworks GW5520 board.
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
