path: root/arch/arm/boot/dts/imx6qdl-gw553x.dtsi
2017-07-16ARM: dts: imx: ventana: add ADV1780 analog video decoderTim Harvey
Enables the ADV7180 analog video decoder sensor connected to the IMX6 IPU on various Gateworks Ventana boards. Signed-off-by: Tim Harvey <tharvey@gateworks.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-01-02ARM: dts: imx: ventana: add LTC3676 PMIC supportTim Harvey
All of the Gateworks Ventana boards based on the IMX6 SoC except for the GW54xx use the LTC3676 PMIC. Add a device-tree node with interrupt support for this PMIC. Additionally remove the simple-bus notation in the regulator nodes and any fixed regulators that are provided by the PMIC. Signed-off-by: Tim Harvey <tharvey@gateworks.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-08-15ARM: dts: imx: add Gateworks Ventana GW553x supportTim Harvey
The Gateworks Ventana GW553x is a single-board computer based on the NXP IMX6 SoC with the following features: * IMX6 DualLite Soc (supports IMX6S,IMX6DL,IMX6Q) * small form factor (35x70mm) * 512MB DDR3 DRAM (2x32bit) (options up to 2GB) * 256MB NAND flash (4GB option) * Gateworks System Controller: - hardware watchdog - hardware monitor - pushbutton controller - EEPROM storage - power control * JTAG programmable * 1x miniPCI socket (with PCIe, USB, SIM) * 1x microSD socket * 1x SIM socket * Inertial Module (LSM9DS1 9DOF: 3x acc, 3x rate, 3x mag) * analog CVBS video in * GPS (optional uBlox EVA-M8M) * Application headers: - 2x TTL UART (TX/RX) - 4x TTL GPIO (3x configurable as PWM) - 3x CVBS Analog video input (1x decoder with 3x selectable inputs) * Front panel connectors: - micro-HDMI audio/video out - 1x user programmable LED - 1x configurable user pushbutton - 1x USB OTG See http://www.gateworks.com for more info Signed-off-by: Tim Harvey <tharvey@gateworks.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
