Pass the memory unit-adress to fix the following build warnings with W=1:
Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name
There are cases where dts passes an empty memory node, which will be filled
by the bootloader. Passing the memory base address still allows the
bootloader to fill the memory size.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Acked-By: Lothar Waßmann <LW@KARO-electronics.de>
(cherry picked from commit edc05819786fd5eee330b89bd5892dad1199effc)
arch/arm/boot/dts/imx6dl-colibri-eval-v3.dts
arch/arm/boot/dts/imx6dl-dfi-fs700-m60.dts
arch/arm/boot/dts/imx6dl-ts4900.dts
arch/arm/boot/dts/imx6dl-ts7970.dts
arch/arm/boot/dts/imx6q-dfi-fs700-m60.dts
arch/arm/boot/dts/imx6q-h100.dts
arch/arm/boot/dts/imx6q-novena.dts
arch/arm/boot/dts/imx6q-ts4900.dts
arch/arm/boot/dts/imx6q-ts7970.dts
arch/arm/boot/dts/imx6q-zii-rdu2.dts
arch/arm/boot/dts/imx6qdl-apalis.dtsi
arch/arm/boot/dts/imx6qdl-cubox-i.dtsi
arch/arm/boot/dts/imx6qdl-hummingboard.dtsi
arch/arm/boot/dts/imx6qdl-hummingboard2.dtsi
arch/arm/boot/dts/imx6qp-zii-rdu2.dts
arch/arm/boot/dts/imx6ul-tx6ul.dtsi
arch/arm/boot/dts/imx6ull-colibri-nonwifi.dtsi
arch/arm/boot/dts/imx6ull-colibri-wifi.dtsi
Update IPU and display property, make sure these dts files can
pass build.
Signed-off-by: Sandor Yu <R01008@freescale.com>
The license text has been mangled at some point then copy pasted across
multiple files. Restore it to what it should be.
Note that this is not intended as a license change.
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Acked-by: Afzal Mohammed <afzal.mohd.ma@gmail.com>
Acked-by: Michael Trimarchi <michael@amarulasolutions.com>
Acked-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
PCIe reset signals are active low, and our GPIO for this is directly
connected to the PCIe reset. However, as the PCIe driver was not using
the flag, the specification of '0' flags (which means active high) had
not been noticed. Correct this oversight, and switch to using the
GPIO flag definitions instead.
Use proper gpio flag definitions for GPIOs rather than using opaque
uninformative numbers.
cd-gpios polarity should be changed to GPIO_ACTIVE_LOW and wp-gpios
should be changed to GPIO_ACTIVE_HIGH.
Otherwise, the SD may not work properly due to wrong polarity inversion
specified in DT after switch to common parsing function mmc_of_parse().
Signed-off-by: Dong Aisheng <aisheng.dong@freescale.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Arrange the license text a bit to make it clear.
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Add PCIe support. Based on a patch from Rabeeh Khoury from the solid-run
tree.
imx6qdl-hummingboard boards use sgtl5000 codec and the machine file
(imx-sgtl5000) already sets SSI in slave mode and codec in master mode, so there
is no need for having the 'fsl,mode' property.
Add the DT description for the SGTL5000 found on the Hummingboard Pro
model.
Setup pwm lines as follows -
pwm1: In case HummingBoard base carrier; this pin drives through a serial
capacitor the mono out of the audio jack.
In case HummingBoard pro the this pad can be reached by wiring to
C8 capacitors on the board.
pwm2: Setup pwm2 on gpio-1 but leave the default function of the iopad as
a gpio.
The user can change the io pad mux in user space and therefore use
this function on gpio-1 (pin number 7 on the 26 pin header).
pwm3,pwm4: unused
Signed-off-by: Rabeeh Khoury <rabeeh@solid-run.com>
[tweaked alias for pwm pinctrl group --rmk]
Enable the commented out PCF8523 RTC support for Hummingboard pro
base boards.
Acked-by: Philipp Zabel <p.zabel@pengutronix.de>
Update SolidRun iMX6 platforms DT descriptions to be dual-licensed.
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Acked-by: Rabeeh Khoury <rabeeh@solid-run.com>
Add the IOMUX setting for the IR input, rather than relying on the
boot loader.
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
HummingBoard after rev 2.0 and the production one starting rev 3.0 uses
gpio 3,5 (EIM_DA5 pad) as the gpio infra red receiver input.
Since the original Carrier1 board is obsolete and we are retiring it,
update the DT file for this. This will mean IR reception will not
work on Carrier1 with this DT file.
