[ Upstream commit 70b6ff4c549a62b59b286445f66cfec6c5327ac8 ]
Fix typo so the gpio i2c busses are really disabled.
Fixes: 2125212785c9 ("ARM: dts: imx6qdl-kontron-samx6i: add Kontron SMARC SoM Support")
Signed-off-by: Marco Felsch <m.felsch@pengutronix.de>
[ Upstream commit 19ba8fb810c60b46869acc9f455613de454e0fca ]
Use the correct pin for the i2c scl signal else we can't access the
SoM eeprom.
Fixes: 2a51f9dae13d ("ARM: dts: imx6qdl-kontron-samx6i: Add iMX6-based Kontron SMARC-sAMX6i module")
Signed-off-by: Bernd Bauer <bernd.bauer@anton-paar.com>
[m.felsch@pengutronix.de: Adapt commit message]
The patch adds the following interfaces according the SMARC Spec 1.1
[1] and provided schematics:
- SMARC SPI0/1
Note: Since Kontron still uses silicon revisions below 1.3 they have
add a spi-nor to implement Workaround #1 of erratum ERR006282.
- SMARC SDIO
- SMARC LCD
- SMARC HDMI
- SMARC Management pins
Note: Kontron don't route all of these pins to the i.MX6, some are
routed to the SoM CPLD.
- SMARC GPIO
- SMARC CSI Camera
Note: As specified in [1] the data lanes are shared to cover the
csi and the parallel case. The case depends on the baseboard so
muxing the data lanes is not part of this patch.
- SMARC I2S
- SMARC Watchdog
Note: The watchdog output pin is routed to the CPLD and the SMARC
header. The CPLD performs a reset after a 30s timeout so we
need to enable the watchdog per default.
- SMARC module eeprom
Due to the lack of hardware not all of these interfaces are tesetd.
[1] https://sget.org/standards/smarc
Signed-off-by: Michael Grzeschik <m.grzeschik@pengutronix.de>
SMARC-sAMX6i is a SMARC (Smart Mobility Architecture) compliant
module.
Signed-off-by: Priit Laes <plaes@plaes.org>
