path: root/arch/arm/boot/dts/imx6qdl-nitrogen6x.dtsi
2018-12-10ARM: dts: imx6qdl: Fix memory node duplicationMarco Franchi
Boards based on imx6qdl have duplicate memory nodes: - One coming from the board device tree file: memory@ - One coming from the imx6qdl.dtsi file. Fix the duplication by removing the memory node from the imx6qdl.dtsi file and by adding 'device_type = "memory";' in the board Device Tree. Converted using the following command: perl -p0777i -e 's/memory\@10000000 \{\n/memory\@10000000 \{\n\t\tdevice_type = \"memory\";\n/m' `find ./arch/arm/boot/dts -name "imx6*"`` Reported-by: Rob Herring <robh@kernel.org> Signed-off-by: Marco Franchi <marco.franchi@nxp.com> Reviewed-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2018-07-17ARM: dts: imx: Switch Boundary Devices boards to SPDX identifierGary Bisson
Adopt the SPDX license identifier headers to ease license compliance management. Signed-off-by: Gary Bisson <gary.bisson@boundarydevices.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2018-06-17ARM: dts: imx6: make edt-ft5x06 a wakeup source for imx6 boardsDaniel Mack
The touchscreen driver no longer configures the device as wakeup source by default. A "wakeup-source" property is needed. Signed-off-by: Daniel Mack <daniel@zonque.org> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2018-02-12ARM: dts: imx: Add memory node unit nameMarco Franchi
Fix the following warnings from dtc by adding the unit name to memory nodes: Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name Converted using the following command: perl -p0777i -e 's/memory \{\n\t\treg = \<0x+([0-9a-f])/memory\@$1$\0000000 \{\n\t\treg = <0x$1/m' `find ./arch/arm/boot/dts -name "imx*"` The files below were manually fixed: -imx1-ads.dts -imx1-apf9328.dts -imx6q-pistachio.dts Signed-off-by: Marco Franchi <marco.franchi@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-12-26ARM: dts: imx6qdl-nitrogen6x: Add SPI NOR partitionsOtavio Salvador
This adds the partitions definition for the SPI NOR to provide backward compatibility with the documented[1] layout used with Boundary Devices BSP. 1. https://boundarydevices.com/boot-flash-access-linux/ It exports to Linux: mtd0: bootloader mtd1: env mtd2: splash Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-10-30Merge tag 'imx-dt-4.15' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into next/dt Pull "i.MX device tree updates for 4.15" from Shawn Guo: - New board support: i.MX51 ZII RDU1, i.MX53 GE Healthcare PPD, i.MX6 TX modules for MB7 from Ka-Ro Electronics, i.MX6 Wandboard revd1 variants, i.MX6 LWN DISPLAY5 board, Pistachio i.MX6Q board, i.MX6SX Vining-2000 board. - Use the 'vpcie-supply' property for PCIe device for boards imx6qdl-sabresd, imx6q-novena and imx6q-cm-fx6. - A series from Jagan Teki to update imx6qdl-icore board with audio, touch and CAN support. - Switch to nvmem for accessing OCOTP from tempmon for i.MX6SX and add tempmon support for i.MX6UL. - A bunch of patches from Lothar Waßmann updating Ka-Ro i.MX28, i.MX53 and i.MX6 TX modules. - Fix DTC warnings in i.MX device trees, dropping leading zeros from unit address, correcting display nodes notation and display port names, fixing nodes with unit name and no reg property. - Other random device updates for various board support. * tag 'imx-dt-4.15' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux: (63 commits) ARM: dts: imx53-tx53: fix interrupt flags ARM: dts: imx28-tx28: fix interrupt flags ARM: dts: display5: Device tree description of LWN's DISPLAY5 board ARM: dts: imx53-qsb-common: Fix 'led_gpio7_7@0' node with unit name and no reg property ARM: dts: imx53-m53evk: Fix 'led_gpio@0' node with unit name and no reg property ARM: dts: imx53: Fix 'usbphy@x' node with unit name and no reg property ARM: dts: imx51-ts4800: Fix 'port@0' node with unit name and no reg property ARM: dts: imx51-apf51dev: Fix 'backlight@bl1' node with unit name and no reg property ARM: dts: imx: add ZII RDU1 board ARM: dts: imx: add support for TX6 modules on MB7 baseboard ARM: dts: imx: add support for TX6QP ARM: dts: imx6-tx6: add a .dtsi file for the MB7 baseboard ARM: dts: imx6-tx6: move display configuration to .dtsi file ARM: dts: imx6-tx6: add support for I2C bus recovery ARM: dts: imx6-tx6: convert to using simple-audio-card ARM: dts: imx6-tx6: specify ethernet phy reset post-delay ARM: dts: imx6-tx6: improve ethernet related pinctrl setup ARM: dts: imx6-tx6: add trickle-charge config for DS1339 ARM: dts: imx6-tx6: remove obsolete ipu1 alias ARM: dts: imx6-tx6: remove obsolete eeti,egalax_ts ... [arnd: made sure we have no new leading zeroes in unit address during merge]
2017-10-20arm: dts: fix unit-address leading 0sRob Herring
Fix dtc warnings for 'simple_bus_reg' due to leading 0s. Converted using the following command: perl -p -i -e 's/\@0+([0-9a-f])/\@$1/g' `find arch/arm/boot/dts -type -f -name '*.dts*' Dropped changes to ARM, Ltd. boards LED nodes and manually fixed up some occurrences of uppercase hex. Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2017-10-13ARM: dts: imx: Fix incorrect display nodes notationMarco Franchi
The following build warnings are seen with W=1: Warning (unit_address_vs_reg): Node /display@di0 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /display@di1 has a unit name, but no reg property Fix all these warnings by changing 'display@diX' to 'dispX'. Signed-off-by: Marco Franchi <marco.franchi@nxp.com> Acked-by: Philipp Zabel <p.zabel@pengutronix.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-07-26ARM: dts: imx6qdl-nitrogen6x: fix USB PHY resetGary Bisson
Declared as a regulator since the driver doesn't have a reset-gpios property for this. This ensures that the PHY is woken up, not depending on the state the second stage bootloader leaves the pin. This is a workaround until a proper mechanism is provided to reset such devices like the pwrseq library [1] for instance. [1] https://lkml.org/lkml/2017/2/10/779 Signed-off-by: Gary Bisson <gary.bisson@boundarydevices.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-06-05ARM: dts: imx: Fix Ethernet PHY reset polarityFabio Estevam
The FEC driver ignores the GPIO polarity from 'phy-reset-gpios' and considers that the Ethernet PHY is active low, unless the property 'phy-reset-active-high' is present. Fix the device tree description by explicitly passing the 'GPIO_ACTIVE_LOW' flag to the 'phy-reset-gpios' property. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-01-29Merge tag 'imx-dt-4.11' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into next/dt i.MX device tree updates for 4.11: - New board support: vf610-zii-dev-rev-c, imx6ul-opos6uldev, imx6ul-isiot, imx6qdl-savageboard, imx6q-mccmon6. - A patch from Alexandre to correct the mangled license text which has been copied & pasted all over the i.MX device tree files. - Update cpu nodes of some i.MX SoCs to make them consistent and match ePAPR spec. - Add OCOTP device for i.MX6UL SoC. - Add security violation interrupt for i.MX25 DryIce. - Enable USB OTG, WIFI and Bluetooth support for i.MX6SX Udoo Neo board. - Enable S/PDIF and 2nd display pipeline support for CompuLab board.. - Add SPI and LTC3676 PMIC support for Gateworks Ventana boards. - A few random device addition for various boards: TVE DAC regulators for imx53-qsb, EEPROM for vf610-zii-dev, eMMC and NAND support for i.MX6UL Engicam boards. - Cleanups on obsoleted or unused properties. * tag 'imx-dt-4.11' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux: (32 commits) ARM: dts: udoo_neo: Add Bluetooth support ARM: dts: udoo_neo: Add Wifi support ARM: dts: udoo_neo: Add UDOO Neo USB OTG1 and OTG2 support ARM: dts: imx6ul: Add Engicam Is.IoT MX6UL NAND initial support ARM: dts: imx6ul: Add Engicam Is.IoT MX6UL eMMC initial support ARM: dts: imx6qdl: Fix "ERROR: code indent should use tabs where possible" ARM: dts: vf610-zii-dev: add EEPROM entry to Rev C ARM: dts: add Armadeus Systems OPOS6UL and OPOS6ULDEV support ARM: dts: imx6q-utilite-pro: enable 2nd display pipeline ARM: dts: vf610-zii-dev: Add .dts file for rev. C ARM: dts: vf610-zii-dev-rev-b: Remove leftover PWM pingroup ARM: dts: imx6: Support Savageboard quad ARM: dts: imx6: Support Savageboard dual ARM: dts: imx6: Add Savageboard common file ARM: dts: imx53-qsb: Provide the TVE DAC regulators ARM: dts: imx6q: Add mccmon6 board support Doc: devicetree: bindings: Add vendor prefix entry - lwn ARM: dts: imx/vf: Correct license text ARM: dts: imx25.dtsi: DryIce security violation interrupt ARM: dts: imx: Add ocotp node for imx6ul ... Signed-off-by: Olof Johansson <olof@lixom.net>
2017-01-10ARM: dts: imx/vf: Correct license textAlexandre Belloni
The license text has been mangled at some point then copy pasted across multiple files. Restore it to what it should be. Note that this is not intended as a license change. Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Afzal Mohammed <afzal.mohd.ma@gmail.com> Acked-by: Michael Trimarchi <michael@amarulasolutions.com> Acked-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-01-02ARM: dts: imx: remove obsoleted property fsl,spi-num-chipselectsVladimir Zapolskiy
Since commit b36581df7e78 ("spi: imx: Using existing properties for chipselects") the device tree property 'fsl,spi-num-chipselects' is unused and it is already marked as obsolete in device tree binding documentation. Remove the property from the existing DTS files to avoid its reoccurence on copying. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-01-02ARM: dts: imx6qdl-nitrogen6x: remove duplicate iomux entryGary Bisson
The NANDF_CS2 pad is also part of the wlan-vmmcgrp iomux group. Removing is from the usdhc2grp group avoids the following error: imx6q-pinctrl 20e0000.iomuxc: pin MX6Q_PAD_NANDF_CS2 already requested by regulators:regulator@4; cannot claim for 2194000.usdhc imx6q-pinctrl 20e0000.iomuxc: pin-187 (2194000.usdhc) status -22 imx6q-pinctrl 20e0000.iomuxc: could not request pin 187 (MX6Q_PAD_NANDF_CS2) from group usdhc2grp on device 20e0000.iomuxc Signed-off-by: Gary Bisson <gary.bisson@boundarydevices.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-01-02ARM: dts: boundary: remove hardcoded LVDS bus formatGary Bisson
The bus format is therefore retrieved from the connected panel information. Signed-off-by: Gary Bisson <gary.bisson@boundarydevices.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-11-02ARM: dts: imx6qdl-nitrogen6x: use hyphens for nodes nameGary Bisson
Also aligning the panel nodes name across all platforms. Signed-off-by: Gary Bisson <gary.bisson@boundarydevices.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-08-09ARM: dts: imx6qdl: don't configure reserved pad settingsUwe Kleine-König
Several dts files set a bit in the SPEED field for pads RGMII_{R,T}{XC,D0,D1,D2,D3,X_CTL}, but that doesn't exist. Writing there doesn't have an effect and the bit reads as zero. Signed-off-by: Uwe Kleine-König <uwe@kleine-koenig.org> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-06-11ARM: dts: imx6: tag boards that have the HW workaround for ERR006687Lucas Stach
Add the DT property to all boards that have the hardware workaround for erratum ERR006687 present. This allows the CPUidle driver to use the deep idle states, even if the FEC is active. Signed-off-by: Lucas Stach <l.stach@pengutronix.de> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-04-27ARM: dts: imx6: Do not hardcode the CLKO clockFabio Estevam
Using "IMX6QDL_CLK_CKO" for the clock is easier to read instead of the hardcoded clock number. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-02-29ARM: dts: imx: replace legacy wakeup property with 'wakeup-source'Sudeep Holla
Though the keyboard and other driver will continue to support the legacy "gpio-key,wakeup", "linux,wakeup" and "enable-sdio-wakeup" boolean property to enable the wakeup source, "wakeup-source" is the new standard binding. This patch replaces all the legacy wakeup properties with the unified "wakeup-source" property in order to avoid any futher copy-paste duplication. Cc: Sascha Hauer <kernel@pengutronix.de> Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2015-10-19ARM: dts: imx6qdl-nitrogen6x: relicense under GPLv2/X11Gary Bisson
2015-10-19ARM: dts: imx6qdl-nitrogen6x: add wifi wl1271 supportGary Bisson
2015-10-19ARM: dts: imx6dql-nitrogen6x: add touchscreen supportGary Bisson
This patch adds the different touchscreens that can be connected using the displays available for this board. http://boundarydevices.com/product-category/displays/ Signed-off-by: Gary Bisson <gary.bisson@boundarydevices.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2015-10-19ARM: dts: imx6qdl-nitrogen6x: add Okaya LCD panelGary Bisson
This patch adds support for the 7" LCD display available for Nitrogen6x: http://boundarydevices.com/product/7-800x480-display/ Also add label to backlight_lcd and connect it to the panel. Signed-off-by: Gary Bisson <gary.bisson@boundarydevices.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2015-10-19ARM: dts: imx: add "jedec,spi-nor" flash compatible bindingRafał Miłecki
Starting with commit 8947e396a829 ("Documentation: dt: mtd: replace "nor-jedec" binding with "jedec, spi-nor"") we have "jedec,spi-nor" binding indicating support for JEDEC identification. Use it for all flashes that are supposed to support READ ID op according to the datasheets. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2015-09-01Merge tag 'armsoc-dt' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM DT updates from Olof Johansson: "Ladies and gentlemen, we proudly announce to you the latest branch of ARM device tree contents for the mainline kernel. Come and see, come and see! No less than twentythree thousand lines of additions! Just imagine the joy you will have of using your mainline kernel on newly supported hardware such as Rockchip Chromebooks, Freescale i.MX6UL boards or UniPhier hardware! For those of you feeling less adventurous, added hardware support on platforms such as TI DM814x and Gumstix Overo platforms might be more of your liking. We've got something for everyone here! Ahem. Cough. So, anyway... This is the usual large batch of DT updates. Lots and lots of smaller changes, some of the larger ones to point out are: - Rockchip veyron (Chromebook) support, as well as several other new boards - DRM support on Atmel AT91SAM9N12EK - USB additions on some Allwinner platforms - Mediatek MT6580 support - Freescale i.MX6UL support - cleanups for Renesas shmobile platforms - lots of added devices on LPC18xx - lots of added devices and boards on UniPhier There's also some dependent code added here, in particular some branches that are primarily merged through the clock tree" * tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (389 commits) ARM: tegra: Add gpio-ranges property ARM: tegra: Fix AHB base address on Tegra20, Tegra30 and Tegra114 ARM: tegra: Add Tegra124 PMU support ARM: tegra: jetson-tk1: Add GK20A GPU DT node ARM: tegra: venice2: Add GK20A GPU DT node ARM: tegra: Add IOMMU node to GK20A ARM: tegra: Add CPU regulator to the Jetson TK1 device tree ARM: tegra: Add entries for cpufreq on Tegra124 ARM: tegra: Enable the DFLL on the Jetson TK1 ARM: tegra: Add the DFLL to Tegra124 device tree ARM: dts: zynq: Add devicetree entry for Xilinx Zynq reset controller. ARM: dts: UniPhier: fix PPI interrupt CPU mask of timer nodes ARM: dts: rockchip: correct regulator power states for suspend ARM: dts: rockchip: correct regulator PM properties ARM: dts: vexpress: Use assigned-clock-parents for sp810 pinctrl: tegra: Only set the gpio range if needed arm: boot: dts: am4372: add ARM timers and SCU nodes ARM: dts: AM4372: Add the am4372-rtc compatible string ARM: shmobile: r8a7794 dtsi: Add CPG/MSTP Clock Domain ARM: shmobile: r8a7793 dtsi: Add CPG/MSTP Clock Domain ...
2015-08-11ARM: dts: imx6qdl-nitrogen6x: Allow HDMI and LVDS to work simultaneouslyFabio Estevam
Currently it is not possible to have HDMI and LVDS working simultaneously, because both ports try to use PLL5. Move the LVDS clock parent to PLL3_USB_OTG, so that HDMI and LVDS can be driven from independent sources. With this change the LDB pixel clock goes to 68.57 MHz, which is still within the valid range for the HSD100PXN1 LVDS panel. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Gary Bisson <gary.bisson@boundarydevices.com> Acked-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2015-07-24dts: imx6: fix sd card gpio polarity specified in device treeDong Aisheng
cd-gpios polarity should be changed to GPIO_ACTIVE_LOW and wp-gpios should be changed to GPIO_ACTIVE_HIGH. Otherwise, the SD may not work properly due to wrong polarity inversion specified in DT after switch to common parsing function mmc_of_parse(). Signed-off-by: Dong Aisheng <aisheng.dong@freescale.com> Acked-by: Shawn Guo <shawnguo@kernel.org> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
2015-07-15ARM: dts: nitrogen6x: add CAN supportPeter Seiderer
Regulator stuff copied from imx6qdl-tx6.dtsi, pin configuration taken from Boundary Devices linux kernel tree ([1] and [2]). [1] https://github.com/boundarydevices/linux-imx6/blob/boundary-imx_3.10.17_1.0.2_ga/arch/arm/boot/dts/imx6qdl-nitrogen6x.dtsi [2] https://github.com/boundarydevices/linux-imx6/blob/boundary-imx_3.10.17_1.0.2_ga/arch/arm/boot/dts/imx6qdl.dtsi Signed-off-by: Peter Seiderer <ps.report@gmx.net> Tested-by: Eric Nelson <eric.nelson@boundarydevices.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: dts: nitrogen6x: use simple-panel instead of display-timings for LVDS0Eric Nelson
Also add label for backlight_lvds and connect it to the display. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-09-16ARM: dts: nitrogen6x: Add Intersil ISL1208 RTCPhilipp Zabel
This patch adds the battery backed real time clock connected to I2C1 to the device tree. Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-09-16ARM: dts: nitrogen6x: add i2c3Philipp Zabel
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Lucas Stach <l.stach@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-09-16ARM: dts: nitrogen6x: add hdmiMichael Olbrich
Signed-off-by: Michael Olbrich <m.olbrich@pengutronix.de> Signed-off-by: Lucas Stach <l.stach@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-09-16ARM: dts: nitrogen6x: add i2c2Michael Olbrich
2014-07-18ARM: dts: imx: remove ssi fsl,mode for audio cardsMarkus Pargmann
The DAI mode is and should be configured by the sound card driver as codec and ssi have to be in the right modes to communicate with each other. It is possible to operate the ssi unit or the codec in master mode, sometimes even on the same board in different configurations. With the latest changes in the fsl-ssi driver, the 'fsl,mode' property is only handled as a fallback property. If the sound card sets the DAI mode correctly, this fallback configuration is dropped. Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-05-16ARM: dts: Add stdout-path property to i.MX boardsSascha Hauer
This adds the stdout-path property to various i.MX boards. Values of the property have been taken from barebox, so they should be correct. Also, the older linux,stdout-path property is converted to stdout-path. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-02-10ARM: dts: imx6qdl-sabrelite: use GPIO_6 for FEC interrupt.Troy Kisky
This works around a hardware bug. From "Chip Errata for the i.MX 6Dual/6Quad" ERR006687 ENET: Only the ENET wake-up interrupt request can wake the system from Wait mode. The ENET block generates many interrupts. Only one of these interrupt lines is connected to the General Power Controller (GPC) block, but a logical OR of all of the ENET interrupts is connected to the General Interrupt Controller (GIC). When the system enters Wait mode, a normal RX Done or TX Done does not wake up the system because the GPC cannot see this interrupt. This impacts performance of the ENET block because its interrupts are serviced only when the chip exits Wait mode due to an interrupt from some other wake-up source. Before this patch, ping times of a Sabre Lite board are quite random: ping 192.168.0.13 -i.5 -c5 PING 192.168.0.13 (192.168.0.13) 56(84) bytes of data. 64 bytes from 192.168.0.13: icmp_req=1 ttl=64 time=15.7 ms 64 bytes from 192.168.0.13: icmp_req=2 ttl=64 time=14.4 ms 64 bytes from 192.168.0.13: icmp_req=3 ttl=64 time=13.4 ms 64 bytes from 192.168.0.13: icmp_req=4 ttl=64 time=12.4 ms 64 bytes from 192.168.0.13: icmp_req=5 ttl=64 time=11.4 ms === 192.168.0.13 ping statistics === 5 packets transmitted, 5 received, 0% packet loss, time 2004ms rtt min/avg/max/mdev = 11.431/13.501/15.746/1.508 ms ____________________________________________________ After this patch: ping 192.168.0.13 -i.5 -c5 PING 192.168.0.13 (192.168.0.13) 56(84) bytes of data. 64 bytes from 192.168.0.13: icmp_req=1 ttl=64 time=0.120 ms 64 bytes from 192.168.0.13: icmp_req=2 ttl=64 time=0.175 ms 64 bytes from 192.168.0.13: icmp_req=3 ttl=64 time=0.169 ms 64 bytes from 192.168.0.13: icmp_req=4 ttl=64 time=0.168 ms 64 bytes from 192.168.0.13: icmp_req=5 ttl=64 time=0.172 ms === 192.168.0.13 ping statistics === 5 packets transmitted, 5 received, 0% packet loss, time 1999ms rtt min/avg/max/mdev = 0.120/0.160/0.175/0.026 ms ____________________________________________________ Also, apply same change to imx6qdl-nitrogen6x. This change may not be appropriate for all boards. Sabre Lite uses GPIO6 as a power down output for a ov5642 camera. As this expansion board does not yet work with mainline, this is not yet a conflict. It would be nice to have an alternative fix for boards where this is a problem. For example Sabre SD uses GPIO6 for I2C3_SDA. It also has long ping times currently. But cannot use this fix without giving up a touchscreen. Its ping times are also random. ping 192.168.0.19 -i.5 -c5 PING 192.168.0.19 (192.168.0.19) 56(84) bytes of data. 64 bytes from 192.168.0.19: icmp_req=1 ttl=64 time=16.0 ms 64 bytes from 192.168.0.19: icmp_req=2 ttl=64 time=15.4 ms 64 bytes from 192.168.0.19: icmp_req=3 ttl=64 time=14.4 ms 64 bytes from 192.168.0.19: icmp_req=4 ttl=64 time=13.4 ms 64 bytes from 192.168.0.19: icmp_req=5 ttl=64 time=12.4 ms === 192.168.0.19 ping statistics --- 5 packets transmitted, 5 received, 0% packet loss, time 2003ms rtt min/avg/max/mdev = 12.451/14.369/16.057/1.316 ms Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> CC: Ranjani Vaidyanathan <ra5478@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-02-09ARM: dts: imx6qdl-sabrelite: add gpio-keysTroy Kisky
Add power, menu, home, back, volume up, and volume down buttons. Also, apply same changes to imx6qdl-nitrogen6x. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-02-09ARM: dts: imx: add nitrogen6x boardTroy Kisky
Add file imx6q-nitrogen6x.dts, imx6dl-nitrogen6x.dts, imx6qdl-nitrogen6x.dtsi And add board to makefile. Eric Nelson created a web page to show the differences between Nitrogen6x and Sabre Lite boards. http://boundarydevices.com/differences-sabre-lite-nitrogen6x Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
