The D9 LED controlled by gpio on the imx6qdl-sabreauto
CPU board is a debug LED according to the board design.
This patch adds the relevant device tree nodes to the
imx6qdl-sabreauto device tree file to support this LED.
Signed-off-by: Liu Ying <Ying.Liu@freescale.com>
mx6 sabreauto boards have Freescale PFUZE100 regulator, so add support for it.
Add LVDS support for mx6 sabreauto boards.
This works around a hardware bug.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
This patch adds spdif support for imx6qdl-sabreauto by inserting the cpu dai
node with pinctrl group and its ASoC dai link node.
Signed-off-by: Nicolin Chen <Guangyu.Chen@freescale.com>
Currently, all pinctrl setting nodes are defined in <soc>.dtsi, so that
boards that share the same pinctrl setting do not have to define it time
and time again in <board>.dts. However, along with the devices and use
cases being added continuously, the pinctrl setting nodes under iomuxc
becomes more than expected. This bloats device tree blob for particular
board unnecessarily since only a small subset of those pinctrl setting
nodes will be used by the board. It impacts not only the DTB file size
but also the run-time device tree lookup efficiency.
The patch moves all the pinctrl data into individual boards as needed.
With the changes, the pinctrl setting nodes becomes local to particular
board, and it makes no sense to continue numbering the setting for
given peripheral. Thus, all the pinctrl phandler name gets updated to
have only peripheral name in there.
This is needed for supporting ultra high speed cards like SD3.0 cards.
Signed-off-by: Dong Aisheng <b29396@freescale.com>
The imx6q and imx6dl are two pin-to-pin compatible SoCs. The same board
design can work with either chip plugged into the socket, e.g. sabresd
and sabreauto boards.
We currently define pin groups in imx6q.dtsi and imx6dl.dtsi
respectively because the pad macro names are different between two
chips. This brings a maintenance burden on having the same label point
to the same pin group defined in two places.
The patch replaces prefix MX6Q_ and MX6DL_ with MX6QDL_ for both SoCs
pad macro names. Then the pin groups becomes completely common between
imx6q and imx6dl and can just be moved into imx6qdl.dtsi, so that the
long term maintenance of imx6q/dt pin settings becomes easier.
Unfortunately, the change brings some dramatic diff stat, but it's all
about DTS file, and the ultimate net diff stat is good.
Enable the WEIM NOR for imx6q{dl}-sabreauto boards.
For the pin conflict with SPI NOR, its status is set to "disabled".
Signed-off-by: Huang Shijie <b32955@freescale.com>
In the imx6q-sabreauto and imx6dl-sabreauto boards,
the pin MX6Q{DL}_PAD_EIM_D19 is used as a GPIO for SPI NOR, but
it is used as a data pin for the WEIM NOR.
In order to fix the conflict, this patch removes the pin from the hog,
and adds a new board-level pinctrl: pinctrl_ecspi1_sabreauto.
The SPI NOR selects this pinctrl_ecspi1_sabreauto when it is enabled.
Since the SPI/NOR has pin conflict with the WEIM NOR,
we disable the spi/nor by default.
enable the gpmi-nand for imx6q-sabreauto and imx6qdl-sabreauto boards.
The sabreauto and sabresd boards are common for imx6q and imx6dl.
Create imx6qdl-sabreauto.dtsi and imx6qdl-sabresd.dtsi for those
common parts.
