wm8962 sound card work in codec master mode as before
Signed-off-by: Shengjiu Wang <shengjiu.wang@freescale.com>
Add pmic 5v supply to i.MX6qdl sabresd dts.
Signed-off-by: Sandor Yu <Sandor.yu@nxp.com>
Set tx-d-cal to be 0x5 to improve usb signal quality for all imx6qdl
sabresd boards.
Signed-off-by: Li Jun <jun.li@nxp.com>
Add imx6q/dl/qp sabresd, imx6sx sabreauto magic packet support.
Signed-off-by: Fugang Duan <B38611@freescale.com>
We move WDOG_B pinctrl setting from pinctrl_hog to wdog driver, so need to
remove the original setting in pinctl_hog device node, otherwise the below
warning message will be caught:
[ 1.284161] imx6ul-pinctrl 20e0000.iomuxc: pin MX6UL_PAD_LCD_RESET already requested by 20e0000.iomuxc; cannot claim for 20bc000.wdog
[ 1.294990] imx6ul-pinctrl 20e0000.iomuxc: pin-69 (20bc000.wdog) status -22
[ 1.300689] imx6ul-pinctrl 20e0000.iomuxc: could not request pin 69 (MX6UL_PAD_LCD_RESET) from group wdoggrp on device 20e0000.iomuxc
[ 1.311550] imx2-wdt 20bc000.wdog: Error applying setting, reverse things back
Signed-off-by: Robin Gong <b38343@freescale.com>
Enable the sdio wakeup capability for SDIO cards.
Note: we do not enable it for sabresd usdhc4 since it has a solid
eMMC card on it.
Signed-off-by: Dong Aisheng <b29396@freescale.com>
(cherry picked from commit 9ea7e84fe686a5c959aebbbf4a1b81dcb1c3e3fd)
(cherry picked from commit 58a5347a1b3a6b8970ac7ddc8e336c5d9adf4ddb)
Signed-off-by: Haibo Chen <haibo.chen@freescale.com>
All i.MX6 SabreAuto/SabreSD/EVK has the ability to keep card power
during suspend. So add this capability for them.
(cherry picked from commit 3f18df4746eb33e934c55de23d6496bb4adad33b)
(cherry picked from commit 55553b7300fb3d0e3a7961f569a42bd689b3670f)
i.MX6QP SabreSD board HDMI compliance test 7-15 Vcec2 test failed,
the value is 0.403V, which should be 0.274V>Vcec2>0.196V.
Disable the pad internal PU resistor, and change the external PU
resistor(R647) from 47K to 100K.
With all the changes, the calculated voltage on CEC is 0.248V, and the
test value is 0.250V.
In the patch disable CEC pin internal PULL/Keep function.
Signed-off-by: Sandor Yu <R01008@freescale.com>
(cherry picked from commit 0a9388ff8ef77778f5e81d8dbc980cacf87fc12b)
Add egalax touch screen support for imx6qdl-sabresd board.
On i.MX6QP SabreSD board, VDDCORE is from PFuze's SW2, this
is different from i.MX6QDL SabreSD board, which is from SW1A/B.
Signed-off-by: Anson Huang <Anson.Huang@freescale.com>
This patch enables the two prefetch resolve gasket(PRG) engines on the
imx6qp-sabresd platform.
Signed-off-by: Liu Ying <Ying.Liu@freescale.com>
in dts
cherry-pick below patch:
ENGR00295892-2: ARM: dts: imx6qdl-sabresd: add retain-state-suspended property in dts
Add property "retain-state-suspended" in dts.
(cherry picked from commit aff480769c26ff7f64059f9631b10e8177c4791b)
(cherry picked from commit 4a029915c4693b16db4806f078504cc86f34c069)
ENGR00290496-1 ARM: imx6: Add charging led support on Sabresd board
Enable led lighting while the board in charging status. Implement it on Sabresd
board.
(cherry picked from commit 7a47183634c524f5ac11c60fe555b0b18c0fe7e0)
(cherry picked from commit 28b266aa0bdd531b8eb43a76435f2fcc658bab84)
ENGR00330406-1: ARM: dts: imx6: add battery device node in dts file
Add battery device node on imx6q/dl-sabresd and imx6sl-evk board
(cherry picked from commit 1f2670578decd4a527208864ab3a014d840773f6)
Add imx v4l2 capture driver.
On imx6qdl-sabresd board we use WDOG2 as WDOG_B reset source. So use WDOG2
instead of WDOG1.
add ldo bypass support on i.mx6q/dl and i.mx6sl.
Add IPU v4l2 output driver.
board
add ssi<->wm8962 sound card support for imx6qdl-sabresd board
Signed-off-by: Zidan Wang <zidan.wang@freescale.com>
Cherry-pick below patch:
ENGR00317981 ARM: dts: imx: apply ENET IRQ workaround for sabresd board
This a forward porting of commit (ENGR00313685-15 ARM: dts: imx: apply
ENET IRQ workaround for sabresd board) from imx_3.10.y to imx_3.14.y.
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
Signed-off-by: Anson Huang <b20788@freescale.com>
Add IPU, HDMI and LDB support.
cherry-pick below patch from v3.14.y:
ENGR00307635-5 ASoC: imx-wm8962: Add non-SSI cpu dai support
The current imx-wm8962 machine driver is designed for SSI as CPU DAI only
while as its name we should make the driver more generic to any other CPU
DAI on i.MX serires -- ESAI, SAI for example.
So this patch makes the driver more general so as to support those non-SSI
cases.
Acked-by: Wang Shengjiu <b02247@freescale.com>
Signed-off-by: Nicolin Chen <Guangyu.Chen@freescale.com>
(cherry picked from commit b6fca438dde1b4c0bbdee31729871d601f287dc9)
Add isl29023 sensor device tree support on i.MX6Q/DL/SX platform.
Signed-off-by: Luwei Zhou <b45643@freescale.com>
Add mag3110 sensor device tree support on i.MX6Q/DL/SX platform.
Add mma8451 sensor device tree support on i.MX6Q/DL/SX platform.
Add uart5 DTE mode pinctrl set for imx6q-sabresd board. Since there
have pin confliction, so add new dts file.
(cherry picked from commit d63b40d5b1b05992d2328ef0bdc80ec5d96f2dce)
Disable all otg features for otg1 port of imx6qdl-sabresd board, then
the otg port can only do role swtich by ID pin state.
Signed-off-by: Li Jun <jun.li@freescale.com>
(cherry picked from commit 71ed636ea10843cc2aac46711adf2350a34fa7b0)
commit 89c1a8cf63f8c69dfddb6e377c04df8b25ab1c88 upstream.
cd-gpios polarity should be changed to GPIO_ACTIVE_LOW and wp-gpios
should be changed to GPIO_ACTIVE_HIGH.
Otherwise, the SD may not work properly due to wrong polarity inversion
specified in DT after switch to common parsing function mmc_of_parse().
Signed-off-by: Dong Aisheng <aisheng.dong@freescale.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
USB vbus 5V is from PMIC SWBST, so set swbst_reg as vbus's
parent reg, it fixed a bug that the voltage of vbus is incorrect
due to swbst_reg is disabled after boots up.
Cc: stable@vger.kernel.org
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Pull ARM SoC DT updates from Arnd Bergmann:
"The DT branch adds a lot of new stuff for additional SoC and board
support. The branch is the largest one and contains 513 out of the
total 972 non-merge arm-soc changesets for 3.19.
Most of the changes are about enabling additional on-chip devices for
existing machines, but there are also an unusual number of new SoC
types being added this time:
- AMLogic Meson8
- ARM Realview in DT mode
- Allwinner A80
- Broadcom BCM47081
- Broadcom Cygnus
- Freescale LS1021A
- Freescale Vybrid 500 series
- Mediatek MT6592, MT8127, MT8135
- STMicroelectronics STiH410
- Samsung Exynos4415
The level of support for the above differs widely, some are just stubs
with nothing more than CPU, memory and a UART, but others are fairly
complete. As usual, these get extended over time.
There are also many new boards getting added, this is the list of
model strings that are showing up in new dts files:
- ARM RealView PB1176
- Altera SOCFPGA Arria 10
- Asus RT-N18U (BCM47081)
- Buffalo WZR-1750DHP (BCM4708)
- Buffalo WZR-600DHP2 (BCM47081)
- Cygnus Enterprise Phone (BCM911360_ENTPHN)
- D-Link DIR-665
- Google Spring
- IGEP COM MODULE Rev. G (TI OMAP AM/DM37x)
- IGEPv2 Rev. F (TI OMAP AM/DM37x)
- LS1021A QDS Board
- LS1021A TWR Board
- LeMaker Banana Pi
- MarsBoard RK3066
- MediaTek MT8127 Moose Board
- MediaTek MT8135 evaluation board
- Mele M3
- Merrii A80 Optimus Board
- Netgear R6300 V2 (BCM4708)
- Nomadik STN8815NHK
- NovaTech OrionLXm
- Olimex A20-OLinuXino-LIME2
- Raspberry Pi Model B+
- STiH410 B2120
- Samsung Monk board
- Samsung Rinato board
- Synology DS213j
- Synology DS414
- TBS2910 Matrix ARM mini PC
- TI AM5728 BeagleBoard-X15
- Toradex Colibri VF50 on Colibri Evaluation Board
- Zynq ZYBO Development Board
Other notable changes include:
- exynos: cleanup of existing dts files
- mvebu: improved pinctrl support for Armada 370/XP
- nomadik: restructuring dts files
- omap: added CAN bus support
- shmobile: added clock support for some SoCs
- shmobile: added sound support for some SoCs
- sirf: reset controller support
- sunxi: continuing the relicensing under dual GPL/MIT
- sunxi: lots of new on-chip device support
- sunxi: working simplefb support (long awaited)
- various: provide stdout-path property for earlycon"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (510 commits)
ARM: dts: rk3288: add arm,cpu-registers-not-fw-configured
Revert "ARM: dts: rockchip: temporarily disable smp on rk3288"
ARM: BCM5301X: Add DT for Buffalo WZR-600DHP2
ARM: BCM5301X: Add DT for Asus RT-N18U
ARM: BCM5301X: Add DT for Buffalo WZR-1750DHP
ARM: BCM5301X: Add DT for Netgear R6300 V2
ARM: BCM5301X: Add buttons for Netgear R6250
ARM: dts: rockchip: Add input voltage supply regulators in pmic for Marsboard
ARM: BCM5301X: Add IRQs to Broadcom's bus-axi in DTS file
arm: dts: zynq: Add Digilent ZYBO board
arm: dts: zynq: Move crystal freq. to board level
doc: dt: vendor-prefixes: Add Digilent Inc
Documentation: devicetree: Fix Xilinx VDMA specification
ARM: dts: rockchip: set FIFO size for SDMMC, SDIO and EMMC on rk3066 and rk3188
ARM: dts: rockchip: add label property for leds on Radxa Rock
ARM: BCM5301X: Add LEDs for Netgear R6250 V1
ARM: BCM5301X: Add Broadcom's bus-axi to the DTS file
ARM: dts: add sysreg phandle to i2c device nodes for exynos
ARM: dts: Remove unused bootargs from exynos3250-rinato
ARM: dts: add board dts file for Exynos3250-based Monk board
All chips of i.mx6 can be powered off by programming SNVS.
For example :
On i.mx6q-sabresd board, PMIC_ON_REQ connect with external
pmic ON/OFF pin, that will cause the whole PMIC powered off
except VSNVS. And system can restart once PMIC_ON_REQ goes
high by push POWRER key.
Since commit e409dfbfccf9a49 ("ASoC: dapm: Add a few supply widget sanity
checks") the following error is seen:
imx-wm8962 sound: wm8962 <-> 202c000.ssi mapping ok
imx-wm8962 sound: Connecting non-supply widget to supply widget is not supported (AMIC -> MICBIAS)
imx-wm8962 sound: ASoC: no dapm match for AMIC --> (null) --> MICBIAS
imx-wm8962 sound: ASoC: Failed to add route AMIC -> direct -> MICBIAS
Invert the route between the microphone and the bias in order to fix it.
While at it, align the audio routing with imx6sl-evk and imx6sx-sdb, which have
the same wm8962 circuitry.
Use IMX6QDL_CLK_CKO definition instead of its hard coded clock number for better
readability.
Passing '0x80000000' to the pin configuration means that kernel will skip the
IOMUXC_SW_PAD_CTL configuration and will use whathever values come from the
bootloader.
Instead of relying on the bootloader setup, let's configure it in the kernel to
have predictable settings.
'0x1b0b0' is the default POR value for all these pins and has also been verified
that the pins are using this value by manually inspecting the IOMUXC_SW_PAD_CTL
registers, so no functional change has been made.
Everything in the PCI specification assumes devices to be
enumerable on startup. This is only possible if they have
power available.
A future improvement may allow this regulator to be switched
off for D3hot and D3cold power states, but there is a lot
of work to do the pcie host controller side for this to work.
To keep things simple always enable the regulator for now.
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
The DAI mode is and should be configured by the sound card driver as
codec and ssi have to be in the right modes to communicate with each
other. It is possible to operate the ssi unit or the codec in master mode,
sometimes even on the same board in different configurations.
With the latest changes in the fsl-ssi driver, the 'fsl,mode' property
is only handled as a fallback property. If the sound card sets the DAI
mode correctly, this fallback configuration is dropped.
Signed-off-by: Markus Pargmann <mpa@pengutronix.de>
GPIO4_9 is used as ECSPI1 chip select and it needs to be configured as GPIO.
Configure the pin functionality explicitly in the dts file instead of relying
on the fact that it comes configured as GPIO from POR or from the bootloader.
USDHC4 is connected to a DDR MMC. Add support for it.
This adds the stdout-path property to various i.MX boards. Values
of the property have been taken from barebox, so they should be
correct. Also, the older linux,stdout-path property is converted
to stdout-path.
This isn't compatible with the new binding and should be
handled via a proper regulator. It shouldn't be needed as
the driver has always ignored this property.
Add support for the PCI express bus available on MX6 SabreSDP.
Make the red gpio led available to the user.
This can be toggled with the sysfs for example, or used as a heartbeat or mmc
activity light by changing the trigger.
Signed-off-by: Vincent Stehlé <vincent.stehle@freescale.com>
Cc: Sascha Hauer <kernel@pengutronix.de>
From schematic, the power, vol+/- key's active state is low,
so we need to set the gpio flag to active low.
mx6 sabresd boards have Freescale PFUZE100 regulator, so add support for it.
This patch adds support for imx6qdl-sabresd board's power
key, the key is named "SW1" on board, press it can wake up
system from suspend.
Add a new pinctrl entry for gpio keys and move all gpio
keys pin to this entry.
We must specify the value of audmux pinctrl if we want to use pinctrl_pm().
Thus change bypass value 0x80000000 to what we exactly need.
This patch also seperately unset PUE bit for TXD so that IOMUX won't pull
up/down the pin after turning into tristate. When we use SSI normal mode to
playback monaural audio via I2S signal, there'd be a pulled curve occur to
its signal at the second slot if setting PUE bit for TXD. And it will make
the second channel to play a constant noise. So by keeping the signal level
in the second slot, we can get a constant high level signal (-1) or a low
level one (0).
Signed-off-by: Nicolin Chen <b42378@freescale.com>
The device tree specification recommends that generic name should be
used for nodes. So instead of naming those fixed regulator nodes
arbitrarily, let's use the generic name 'regulator@num' for those nodes.
Currently, all pinctrl setting nodes are defined in <soc>.dtsi, so that
boards that share the same pinctrl setting do not have to define it time
and time again in <board>.dts. However, along with the devices and use
cases being added continuously, the pinctrl setting nodes under iomuxc
becomes more than expected. This bloats device tree blob for particular
board unnecessarily since only a small subset of those pinctrl setting
nodes will be used by the board. It impacts not only the DTB file size
but also the run-time device tree lookup efficiency.
The patch moves all the pinctrl data into individual boards as needed.
With the changes, the pinctrl setting nodes becomes local to particular
board, and it makes no sense to continue numbering the setting for
given peripheral. Thus, all the pinctrl phandler name gets updated to
have only peripheral name in there.
This patch adds support for lvds backlight on boards
i.MX6q-SabreSD and i.MX6dl-SabreSD
Signed-off-by: Rogerio Pimentel <rogerio.pimentel@freescale.com>
