Since iMX6Q/DL PCIe have the PM limitation (ERR005723).
Only enable PCIe in the xxx-pcie.dts files.
Signed-off-by: Richard Zhu <hongxing.zhu@nxp.com>
Reviewed-by: Fugang Duan <fugang.duan@nxp.com>
(cherry picked from commit e07881a460c9afbaf5b56ccbd3ac27cfdc645b3f)
Add bus recovery for all i2c buses to avoid bus dead lock.
Signed-off-by: Clark Wang <xiaoning.wang@nxp.com>
Acked-by: Fugang Duan <fugang.duan@nxp.com>
(cherry picked from commit d1300cec8a03c46d803d04fea7389bb397f20b3d)
select a proper freq for S20_3LE/S24_LE/S16_LE, the frequency
can be divided by 24/32/16.
Signed-off-by: Shengjiu Wang <shengjiu.wang@nxp.com>
Reviewed-by: Viorel Suman <viorel.suman@nxp.com>
There are snvs design issue on legacy i.mx6q/dl chip so gpio key used
instead of snvs_pwrkey on i.mx6qdl-sabresd board. Disable snvs_pwrkey to
match board design though there is another software workaround for such
design issue in the future:
https://lore.kernel.org/linux-arm-kernel/20191125161210.8275-1-robin@protonic.nl/
Signed-off-by: Robin Gong <yibin.gong@nxp.com>
Reviewed-by: Anson Huang <Anson.Huang@nxp.com>
(cherry picked from commit 26e4d220c335f2225fc35ba7f28acc5671e5483c)
The source of reg_vdd3p0 should be from USB_VBUS instead of VDD_HIGH_IN
which is provied by PMIC. Correct it, otherwise below error will come out
on i.mx6sll-evk board since usb driver want to raise voltage to 3.2V and
mismatch is here(3.2V + 125mv = 3.325V > 3.3V max):
[ 5.836553] SW2: unsupportable voltage range: 3325000-3300000uV
[ 5.843066] regulator regulator.1: Failed to increase supply voltage: -22
Reviewed-by: Anson Huang <anson.huang@nxp.com>
The VGEN_1V8 is used on SCH-28857 REV B sabresd board.
Add the according vgen3 into PCIe node.
Thus, the external OSC can keep toggling with the correct
power supply.
Acked-by: Fugang Duan <Fugang.duan@nxp.com>
Enable mipi dsi for imx6q and imx6dl sabresd
boards by default.
Signed-off-by: Fancy Fang <chen.fang@nxp.com>
Reviewed-by: Robby Cai <robby.cai@nxp.com>
Reviewed-by: Dong Aisheng <aisheng.dong@nxp.com>
Add ldo-bypass support.
boards
i.MX6Q/DL ENET cannot wake up system in wait mode because ENET
tx & rx interrupt signal don't connect to GPC. Add ENET GPIO IRQ
workaround for sabresd/sabreauto boards.
Signed-off-by: Fugang Duan <fugang.duan@nxp.com>
Acked-by: Richard Zhu <hongxing.zhu@nxp.com>
This patch changes LDB_DI0/1_SEL clock's parent from PLL3_USB_OTG to
PLL2_PFD0_352M so that it aligns with imx_4.19.y kernel. Also, with
this patch applied, the clock tree may provide ~64.6MHz pixel clock
rate to the Hannstar XGA LVDS panel, which is closer to the desired
65MHz(before the change, it's ~68.5MHz).
Signed-off-by: Liu Ying <victor.liu@nxp.com>
(cherry picked from commit a76d0c86ada7717c1cb556a1ac1fc4dd022db8bc)
change cpu-dai to audio-cpu for alignment between
imx-wm8962 and fsl-asoc-card
(cherry picked from commit 010293d320968ac8b74ae2beff2815574efaf2a6)
This reverts commit fbfe81a9783a604226689455666abdad472e37aa.
(cherry picked from commit c4786ad992e5e48d474ee5cf15af0a292b61bc62)
Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com>
This patch enables mxc_v4l2_output device tree support for
the i.MX6qdl Sabresd platforms.
use internal version and resolve conflict with upstreaming code.
add the nodes for v4l2 capture, mipi csi, and ov5460 cameras.
Signed-off-by: Robby Cai <robby.cai@nxp.com>
Enable HDMI Audio in devicetree
add dcic property.
Signed-off-by: Sandor Yu <Sandor.yu@nxp.com>
add imx6qp/q/dl hdmi property.
Use vdd-supply for isl29023.
support audio sound card (wm8962)
Change isl29023's compatible string into "fsl,isl29023". Make sure it
will match the driver drivers/input/misc/isl29023.c.
This patch enables internal IPUv3 fb and LVDS displays in device tree.
Add max11801 device node.
in dts
cherry-pick below patch:
ENGR00295892-2: ARM: dts: imx6qdl-sabresd: add retain-state-suspended
property in dts.
Add property "retain-state-suspended" in dts.
Signed-off-by: Robin Gong <b38343@freescale.com>
(cherry picked from commit aff480769c26ff7f64059f9631b10e8177c4791b)
(cherry picked from commit 4a029915c4693b16db4806f078504cc86f34c069)
Signed-off-by: Arulpandiyan Vadivel <arulpandiyan_vadivel@mentor.com>
Signed-off-by: Srikanth Krishnakar <Srikanth_Krishnakar@mentor.com>
(cherry picked from commit 85923d1f6ae824af2bc297a097b17c041efe00f0)
ENGR00290496-1 ARM: imx6: Add charging led support on Sabresd board
Enable led lighting while the board in charging status. Implement it
on Sabresd board.
(cherry picked from commit 7a47183634c524f5ac11c60fe555b0b18c0fe7e0)
(cherry picked from commit 28b266aa0bdd531b8eb43a76435f2fcc658bab84)
[Arul: Fix merge conflicts]
(cherry picked from commit 0d4fb6276e02d56fe6abbd08bd470487f5b25eaf)
Add battery device node on imx6q/dl-sabresd and imx6sl-evk board
(cherry picked from commit 1f2670578decd4a527208864ab3a014d840773f6)
Add uart5 DTE mode pinctrl set for imx6q-sabresd board. Since there
have pin confliction, so add new dts file.
Signed-off-by: Fugang Duan <B38611@freescale.com>
(cherry picked from commit d63b40d5b1b05992d2328ef0bdc80ec5d96f2dce)
Add imx6q/dl/qp sabresd magic packet support.
Broken the auto cmd23 function for eMMC on imx6qpdl/imx6sx/imx7d, otherwise
the eMMC RPMB write access will return general fail.
Signed-off-by: Haibo Chen <haibo.chen@nxp.com>
The SNVS power key depends on board design, by default it should
be disabled in SoC DT and ONLY be enabled on board DT if it is
wired up.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
On i.MX6Q/DL SabreSD board, vgen5 supplies vdd1p1/vdd2p5 LDO and
sw2 supplies vdd3p0 LDO, this patch assigns corresponding power
supply for vdd1p1/vdd2p5/vdd3p0 to avoid confusion by below log:
vdd1p1: supplied by regulator-dummy
vdd3p0: supplied by regulator-dummy
vdd2p5: supplied by regulator-dummy
With this patch, the power supply is more accurate:
vdd1p1: supplied by VGEN5
vdd3p0: supplied by SW2
vdd2p5: supplied by VGEN5
Commit 6d4cd041f0af ("net: phy: at803x: disable delay only for RGMII mode")
exposed an issue on imx DTS files using AR8031/AR8035 PHYs.
The end result is that the boards can no longer obtain an IP address
via UDHCP, for example.
Quoting Andrew Lunn:
"The problem here is, all the DTs were broken since day 0. However,
because the PHY driver was also broken, nobody noticed and it
worked. Now that the PHY driver has been fixed, all the bugs in the
DTs now become an issue"
To fix this problem, the phy-mode property needs to be "rgmii-id", which
has the following meaning as per
Documentation/devicetree/bindings/net/ethernet.txt:
"RGMII with internal RX and TX delays provided by the PHY, the MAC should
not add the RX or TX delays in this case)"
Tested on imx6-sabresd, imx6sx-sdb and imx7d-pico boards with
successfully restored networking.
Based on the initial submission from Steve Twiss for the
imx6qdl-sabresd.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Tested-by: Baruch Siach <baruch@tkos.co.il>
Tested-by: Soeren Moch <smoch@web.de>
Tested-by: Steve Twiss <stwiss.opensource@diasemi.com>
Tested-by: Adam Thomson <Adam.Thomson@diasemi.com>
Signed-off-by: Steve Twiss <stwiss.opensource@diasemi.com>
Tested-by: Marc Kleine-Budde <mkl@pengutronix.de>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
Now that all sensors supplied by reg_sensors have supported
regulator control, reg_sensors does NOT need to be always ON,
remove "regulator-always-on" to save power.
The mma8451 sensor driver has supported regulators control,
assign the power supplies for mma8451 to enable the control.
The mag3110 sensor driver has supported regulators control,
assign the power supplies for mag3110 to enable the control.
The isl29023 light sensor driver has supported regulator control,
assign the power supply for isl29023 to enable the control.
Passing GPIO_ACTIVE_HIGH as GPIO flags for the GPIO controlled
regulator improves the readability, so use it instead of the
hardcoded number.
Add accelerometer sensor mma8451 support on i2c1 bus.
Reviewed-by: Fabio Estevam <festevam@gmail.com>
Add magnetometer sensor mag3110 support on i2c3 bus.
Add isl29023 light sensor support on i2c3 bus, the light
sensor's power is controlled by a fixed regulator, since
the isl29023 driver and most of other sensors on same
board like mag3110 and mma8451 do NOT support regulator
operation currently, they are all controlled by this
regulator, so this patch also adds the fixed regulator
support and make it always on.
It is not recommended to place regulators inside "simple-bus", so move
them out to make it cleaner the addition of new regulators.
Boards based on imx6qdl have duplicate memory nodes:
- One coming from the board device tree file: memory@
- One coming from the imx6qdl.dtsi file.
Fix the duplication by removing the memory node from
the imx6qdl.dtsi file and by adding 'device_type = "memory";'
in the board Device Tree.
Converted using the following command:
perl -p0777i -e 's/memory\@10000000 \{\n/memory\@10000000 \{\n\t\tdevice_type = \"memory\";\n/m' `find ./arch/arm/boot/dts -name "imx6*"``
Reported-by: Rob Herring <robh@kernel.org>
Signed-off-by: Marco Franchi <marco.franchi@nxp.com>
Add egalax touch screen support on i2c2 bus, it is connected
to LVDS0, while the existing one on i2c3 bus is connected to
LVDS1.
On i.MX6QDL Sabre-SD board, pfuze100 sw4 supplies
GPS, touch and RGMII etc., these modules do NOT
implement power domain control, so pfuze100 sw4
needs to be always on to make sure these modules
work normally.
Adopt the SPDX license identifier headers to ease license compliance
management.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Remove unnecessary #address-cells/#size-cells to fix the following
DTC warnings:
arch/arm/boot/dts/imx6q-novena.dtb: Warning (avoid_unnecessary_addr_size): /soc/ipu@2400000/port@2: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property
arch/arm/boot/dts/imx6q-novena.dtb: Warning (avoid_unnecessary_addr_size): /soc/ipu@2400000/port@3: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property
arch/arm/boot/dts/imx6q-novena.dtb: Warning (avoid_unnecessary_addr_size): /soc/ipu@2800000/port@2: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property
arch/arm/boot/dts/imx6q-novena.dtb: Warning (avoid_unnecessary_addr_size): /soc/ipu@2800000/port@3: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property
Fix the following warnings from dtc by adding the unit name to memory
nodes:
Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name
perl -p0777i -e 's/memory \{\n\t\treg = \<0x+([0-9a-f])/memory\@$1$\0000000 \{\n\t\treg = <0x$1/m' `find ./arch/arm/boot/dts -name "imx*"`
The files below were manually fixed:
-imx1-ads.dts
-imx1-apf9328.dts
-imx6q-pistachio.dts
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into next/dt
Pull "i.MX device tree updates for 4.15" from Shawn Guo:
- New board support: i.MX51 ZII RDU1, i.MX53 GE Healthcare PPD, i.MX6
TX modules for MB7 from Ka-Ro Electronics, i.MX6 Wandboard revd1
variants, i.MX6 LWN DISPLAY5 board, Pistachio i.MX6Q board, i.MX6SX
Vining-2000 board.
- Use the 'vpcie-supply' property for PCIe device for boards
imx6qdl-sabresd, imx6q-novena and imx6q-cm-fx6.
- A series from Jagan Teki to update imx6qdl-icore board with audio,
touch and CAN support.
- Switch to nvmem for accessing OCOTP from tempmon for i.MX6SX and add
tempmon support for i.MX6UL.
- A bunch of patches from Lothar Waßmann updating Ka-Ro i.MX28, i.MX53
and i.MX6 TX modules.
- Fix DTC warnings in i.MX device trees, dropping leading zeros from
unit address, correcting display nodes notation and display port
names, fixing nodes with unit name and no reg property.
- Other random device updates for various board support.
* tag 'imx-dt-4.15' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux: (63 commits)
ARM: dts: imx53-tx53: fix interrupt flags
ARM: dts: imx28-tx28: fix interrupt flags
ARM: dts: display5: Device tree description of LWN's DISPLAY5 board
ARM: dts: imx53-qsb-common: Fix 'led_gpio7_7@0' node with unit name and no reg property
ARM: dts: imx53-m53evk: Fix 'led_gpio@0' node with unit name and no reg property
ARM: dts: imx53: Fix 'usbphy@x' node with unit name and no reg property
ARM: dts: imx51-ts4800: Fix 'port@0' node with unit name and no reg property
ARM: dts: imx51-apf51dev: Fix 'backlight@bl1' node with unit name and no reg property
ARM: dts: imx: add ZII RDU1 board
ARM: dts: imx: add support for TX6 modules on MB7 baseboard
ARM: dts: imx: add support for TX6QP
ARM: dts: imx6-tx6: add a .dtsi file for the MB7 baseboard
ARM: dts: imx6-tx6: move display configuration to .dtsi file
ARM: dts: imx6-tx6: add support for I2C bus recovery
ARM: dts: imx6-tx6: convert to using simple-audio-card
ARM: dts: imx6-tx6: specify ethernet phy reset post-delay
ARM: dts: imx6-tx6: improve ethernet related pinctrl setup
ARM: dts: imx6-tx6: add trickle-charge config for DS1339
ARM: dts: imx6-tx6: remove obsolete ipu1 alias
ARM: dts: imx6-tx6: remove obsolete eeti,egalax_ts
[arnd: made sure we have no new leading zeroes in unit address during merge]
Fix dtc warnings for 'simple_bus_reg' due to leading 0s. Converted using
perl -p -i -e 's/\@0+([0-9a-f])/\@$1/g' `find arch/arm/boot/dts -type -f -name '*.dts*'
Dropped changes to ARM, Ltd. boards LED nodes and manually fixed up some
occurrences of uppercase hex.
Signed-off-by: Rob Herring <robh@kernel.org>
HDMI_TX_CEC_LINE pin is used for CEC, so pass it in the device tree.
