Update IPU and display property, make sure these dts files can
pass build.
Signed-off-by: Sandor Yu <R01008@freescale.com>
The FEC driver ignores the GPIO polarity from 'phy-reset-gpios' and
considers that the Ethernet PHY is active low, unless the
property 'phy-reset-active-high' is present.
Fix the device tree description by explicitly passing the
'GPIO_ACTIVE_LOW' flag to the 'phy-reset-gpios' property.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
When running a stress playback/stop loop test on a mx6wandboard channel
swaps can be noticed randomly.
Increasing the SGTL5000 LRCLK pad strength to its maximum value fixes
the issue, so add the 'lrclk-strength' property to avoid the audio
channel swaps.
Fixed no space before tabs warnings in respetcive imx6qdl dtsi files.
Signed-off-by: Jagan Teki <jteki@openedev.com>
Several dts files set a bit in the SPEED field for pads
RGMII_{R,T}{XC,D0,D1,D2,D3,X_CTL}, but that doesn't exist. Writing there
doesn't have an effect and the bit reads as zero.
Signed-off-by: Uwe Kleine-König <uwe@kleine-koenig.org>
Add the DT property to all boards that have the hardware workaround
for erratum ERR006687 present. This allows the CPUidle driver to use
the deep idle states, even if the FEC is active.
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
As of commit 1006ed7e1b258dac ("serial: imx: Use generic uart-has-rtscts
DT property"), the Freescale IMX UART driver recognizes the generic
"uart-has-rtscts" DT property, deprecating the vendor-specific
"fsl,uart-has-rtscts" DT property. Hence replace the latter by the
former in all DTS files.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Using "IMX6QDL_CLK_CKO" for the clock is easier to read instead of
the hardcoded clock number.
cd-gpios polarity should be changed to GPIO_ACTIVE_LOW and wp-gpios
should be changed to GPIO_ACTIVE_HIGH.
Otherwise, the SD may not work properly due to wrong polarity inversion
specified in DT after switch to common parsing function mmc_of_parse().
Signed-off-by: Dong Aisheng <aisheng.dong@freescale.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
The rev C1 Wandboard uses the Broadcom 4330 for WiFi and Bluetooth instead of
the 4329. This changes the PADS assigned for the control lines. Another
side effect of the change is that on the rev C1 board, usdhc driver can't
detect the chip presence correctly so usdhc2 now needs its 'non-removeable'
property removed.
So that rev B1 and earlier can continue to work, this patch splits the
board-specific definitions from imx6qdl-wandboard.dtsi into
imx6qdl-wandboard-revb1.dtsi and imx6qdl-wandboard-revc1.dtsi. The new files
include the original base imx6qdl-wandboard.dtsi which retains the common
definitions.
The existing imx6dl-wandboard.dts includes imx6qdl-wandboard-revc1.dtsi and
imx6dl-wandboard-revb1.dts (new) includes imx6qdl-wandboard-revb1.dtsi.
This makes the rev C1 board the new default. The same pattern is used for
imx6q-wandboard.dts.
So, from U-Boot on a WB-Quad you use imxq-wandboard-revb1.dtb for the older B1
board and imxq-wandboard.dtb for the current rev C1 board.
Signed-off-by: George Joseph <george.joseph@fairview5.com>
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
The DAI mode is and should be configured by the sound card driver as
codec and ssi have to be in the right modes to communicate with each
other. It is possible to operate the ssi unit or the codec in master mode,
sometimes even on the same board in different configurations.
With the latest changes in the fsl-ssi driver, the 'fsl,mode' property
is only handled as a fallback property. If the sound card sets the DAI
mode correctly, this fallback configuration is dropped.
Signed-off-by: Markus Pargmann <mpa@pengutronix.de>
Apply the same work-around for i.MX 6D/Q erratum 006687 as used for
Sabre Lite for the Wandboard Dual / Quad.
Like on the Sabre Lite, GPIO6 is used as a power down output for
camera expansion boards. However, these expansion boards do not work
with mainline yet anyway.
Tested on a Wandboard Quad. Before the patch:
root@arm:~# ping -q -f -c 10000 192.168.2.1
PING 192.168.2.1 (192.168.2.1) 56(84) bytes of data.
=== 192.168.2.1 ping statistics ===
10000 packets transmitted, 10000 received, 0% packet loss, time 97363ms
rtt min/avg/max/mdev = 0.290/9.586/10.198/1.432 ms, pipe 2, ipg/ewma 9.737/9.672 ms
After the patch:
10000 packets transmitted, 10000 received, 0% packet loss, time 4810ms
rtt min/avg/max/mdev = 0.246/0.355/0.863/0.044 ms, ipg/ewma 0.481/0.319 ms
Signed-off-by: Sascha Silbe <x-linux@infra-silbe.de>
We must specify the value of audmux pinctrl if we want to use pinctrl_pm().
Thus change bypass value 0x80000000 to what we exactly need.
This patch also seperately unset PUE bit for TXD so that IOMUX won't pull
up/down the pin after turning into tristate. When we use SSI normal mode to
playback monaural audio via I2S signal, there'd be a pulled curve occur to
its signal at the second slot if setting PUE bit for TXD. And it will make
the second channel to play a constant noise. So by keeping the signal level
in the second slot, we can get a constant high level signal (-1) or a low
level one (0).
Signed-off-by: Nicolin Chen <b42378@freescale.com>
The device tree specification recommends that generic name should be
used for nodes. So instead of naming those fixed regulator nodes
arbitrarily, let's use the generic name 'regulator@num' for those nodes.
Currently, all pinctrl setting nodes are defined in <soc>.dtsi, so that
boards that share the same pinctrl setting do not have to define it time
and time again in <board>.dts. However, along with the devices and use
cases being added continuously, the pinctrl setting nodes under iomuxc
becomes more than expected. This bloats device tree blob for particular
board unnecessarily since only a small subset of those pinctrl setting
nodes will be used by the board. It impacts not only the DTB file size
but also the run-time device tree lookup efficiency.
The patch moves all the pinctrl data into individual boards as needed.
With the changes, the pinctrl setting nodes becomes local to particular
board, and it makes no sense to continue numbering the setting for
given peripheral. Thus, all the pinctrl phandler name gets updated to
have only peripheral name in there.
GPIO3_29 is used to reset the ethernet phy.
Add support for it.
Reviewed-by: Nicolin Chen <b42378@freescale.com>
Tested via g_ether:
$ modprobe g_ether
using random self ethernet address
using random host ethernet address
usb0: HOST MAC 42:b5:26:a9:48:21
usb0: MAC 36:a6:85:9b:9e:13
g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
g_ether gadget: g_ether ready
$ g_ether gadget: high-speed config #1: CDC Ethernet (ECM)
$ ifconfig usb0 10.0.0.2
Then on the PC host side:
~$ sudo ifconfig usb0 10.0.0.1
~$ ping 10.0.0.2
PING 10.0.0.2 (10.0.0.2) 56(84) bytes of data.
64 bytes from 10.0.0.2: icmp_req=1 ttl=64 time=1.26 ms
64 bytes from 10.0.0.2: icmp_req=2 ttl=64 time=0.280 ms
64 bytes from 10.0.0.2: icmp_req=3 ttl=64 time=0.297 ms
The wandboard has a Broadcom 4329 WiFi connected via SDIO. This patch
sets the required pins to enable the wifi module.
Signed-off-by: Tony Prisk <linux@prisktech.co.nz>
The CLKO is widely used by imx6q board designs to clock audio codec.
Since most codecs accept 24 MHz frequency, let's initially set up CLKO
with OSC24M (cko <-- cko2 <-- osc). Then those board specific CLKO
setup for audio codec can be removed.
The board dts files also need an update on cko reference in codec node.
Add support for the imx6q wanboard variant.
Since imx6q/dl are pin to pin compatible, introduce the imx6qdl-wandboard.dtsi
file that contains the common peripheral nodes.
