[ Upstream commit e01a06c8089132bb4da035c6a83df23916ca3ebf ]
The Marvell switches report their interrupts in a level sensitive way.
When using edge sensitive detection a race condition in the interrupt
handler of the swich might result in the OS to miss all future events
which might make the switch non-functional.
The problem is that both mv88e6xxx_g2_irq_thread_fn() and
mv88e6xxx_g1_irq_thread_work() sample the irq cause register
(MV88E6XXX_G2_INT_SRC and MV88E6XXX_G1_STS respectively) once and then
handle the observed sources. If after sampling but before all observed
irq sources are handled a new irq source gets active this is not noticed
by the handler which returns unsuspecting, but the interrupt line stays
active which prevents the edge detector to kick in.
All device trees but imx6qdl-zii-rdu2 get this right (most of them by
not specifying an interrupt parent). So fix imx6qdl-zii-rdu2
accordingly.
Fixes: f64992d1a916 ("ARM: dts: imx6: RDU2: Add Switch interrupts")
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
The Micrel PHY has its interrupt pin connected to a GPIO line. Wire
this up in the device tree.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Tested-by: Chris Healy <cphealy@gmail.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
The Marvell switch has its interrupt pin connected to a GPIO
line. Wire this up in the device tree. This then allows us to use
interrupts from the embedded Ethernet PHYs in the switch. Also wire
them up in device tree.
The Marvell switch has an EEPROM connected to it. List the size in DT,
in order to enable access to it via ethtool.
The RDU2 has a Marvell 88E6352 switch. Both the FEC and the i210
Ethernet interfaces are connected to the switch. Make the FEC the DSA
"CPU" port, and the i210 as a regular port on the switch.
The FEC has a Micrel PHY connected to it. This PHY is managed using
the bit-banging MDIO bus. Add this to the device tree.
This adds support for the Zodiac Inflight Innovations RDU2 board,
which has both a Quad and a QuadPlus variant.
The board supports different panels, with the bootloader patching
in the correct compatible, depending on the hardware configuration.
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
Tested-by: Nikita Yushchenko <nikita.yoush@cogentembedded.com>
