Commit 833f2cbf7091 ("ARM: dts: imx6: change the core clock of spdif")
changed many more clocks than only the SPDIF core clock as stated in
the commit message.
The MLB clock has been added and this causes SPDIF regression as
reported by Xavi Drudis Ferran and also in this forum post:
https://forum.digikey.com/thread/34240
The MX6Q Reference Manual does not mention that MLB is a clock related
to SPDIF, so change it back to a dummy clock to restore SPDIF
functionality.
Thanks to Ambika for providing the fix at:
https://community.nxp.com/thread/387131
Fixes: 833f2cbf7091 ("ARM: dts: imx6: change the core clock of spdif")
Cc: <stable@vger.kernel.org> # 4.4.x
Reported-by: Xavi Drudis Ferran <xdrudis@tinet.cat>
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Tested-by: Xavi Drudis Ferran <xdrudis@tinet.cat>
The imx6 SMP system has the same DMA memory coherency issue [1] with
pl310 L2 controller. With this shared override bit set, the customer
reports the DMA coherency issue is gone. Besides, I have tested
the performance using USB ethernet with/without this bit, it shows
no difference.
[1] http://patchwork.ozlabs.org/patch/469362/
Signed-off-by: Peter Chen <peter.chen@nxp.com>
This node describes the DI1 port of IPU, fix the node name to reflect this.
There's currently no user of this node in mainline, so this change should
not break any supported platforms.
Signed-off-by: Juergen Borleis <jbe@pengutronix.de>
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
Add clocks property for ocotp node.
Signed-off-by: Peng Fan <van.freenix@gmail.com>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Rob Herring <robh+dt@kernel.org>
The following build warnings are seen when building with 'W=1' option:
Warning (unit_address_vs_reg): Node /soc/aips-bus@02000000/anatop@020c8000/regulator-1p1@110 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /soc/aips-bus@02000000/anatop@020c8000/regulator-3p0@120 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /soc/aips-bus@02000000/anatop@020c8000/regulator-2p5@130 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /soc/aips-bus@02000000/anatop@020c8000/regulator-vddcore@140 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /soc/aips-bus@02000000/anatop@020c8000/regulator-vddpu@140 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /soc/aips-bus@02000000/anatop@020c8000/regulator-vddsoc@140 has a unit name, but no reg property
Fix them by removing the unneeded unit-addresses.
When compiled with "W=1", dtc complains: e.g.
"Warning (unit_address_vs_reg):
Node /soc/ipu@02800000/port@2/endpoint@0
has a unit name, but no reg property"
Endpoint nodes don't have a reg property, and the addresses
in their node names are ordinals without any special meaning
so remove them and swap them for semantic node names.
Signed-off-by: Joshua Clayton <stillcompiling@gmail.com>
Pull more ARM DT changes from Arnd Bergmann:
"Here are some final updates for ARM SoC specific dts files:
- The i.MX changes were sent relatively late, and had a dependency on
the clk tree, so I delayed that a bit. Support for the new i.MX6qp
SoC and a couple of new boards is added in this branch.
- Uniphier renames a few files to match the final product names that
were decided by the company, kudos to the kernel developer(s) for
getting support upstream before the product release. Also two
boards are added. The patches were posted early enough and nice
overall, but we forgot to apply them and decided to give it some
more time in linux-next
- at91 has two small bug fixes"
* tag 'armsoc-dt2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (83 commits)
ARM: dts: at91: sama5d4 Xplained: don't disable hsmci regulator
ARM: dts: at91: sama5d3 Xplained: don't disable hsmci regulator
ARM: dts: uniphier: add pinmux node for I2C ch4
ARM: dts: uniphier: add @{address} to EEPROM node
ARM: dts: uniphier: add PH1-Pro4 Sanji board support
ARM: dts: uniphier: add PH1-Pro4 Ace board support
ARM: dts: uniphier: enable I2C channel 2 of ProXstream2 Gentil board
ARM: dts: uniphier: add EEPROM node for ProXstream2 Gentil board
ARM: dts: uniphier: add reference clock nodes
ARM: dts: uniphier: rework UniPhier System Bus nodes
ARM: dts: uniphier: factor out ranges property of support card
arm64: dts: uniphier: rename PH1-LD10 to PH1-LD20
ARM: dts: imx53-qsb: Fix gpio button polarity
ARM: dts: vfxxx: Add DAC node for Vybrid SoC
ARM: dts: imx6q: add missing links between ipu2 and mipi dsi
ARM: dts: imx: Add support for Advantech/GE B850v3
ARM: dts: imx: Add support for Advantech/GE B650v3
ARM: dts: imx: Add support for Advantech/GE B450v3
ARM: dts: imx: Add support for Advantech/GE Bx50v3
ARM: dts: imx: Add Advantech BA-16 Qseven module
According to the reference manual the shp_2_mcu / mcu_2_shp
scripts must be used for devices connected through the SPBA.
This fixes an issue we saw with DMA transfers from SPI NOR Flashes.
Sometimes the SPI controller RX FIFO was not empty after a DMA
transfer and the driver got stuck in the next PIO transfer when
it read one word more than expected.
The interrupt-parent property is not needed as it is inherited from
the parent bus and in the case of the CAAM node actively points to
the wrong interrupt controller (GIC instead of GPC). This leads to
the CAAM IRQs not getting unmasked at the GPC level, leaving them
unable to wake the CPU from wait mode, potentially impacting
performance of the CAAM unit when CPUidle is enabled.
This adds the device nodes for 2D, 3D and VG GPU cores.
No functional change, just moving the node to the place where it
belongs according to its unit address.
This allows for consistent numbering of the IPU output and
input ports.
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
This has been moved to the reg property where it belongs for quite some
time. The range has been unused by the kernel since then and with kernel
4.4 it's flagged as an unparsable range, as it does not comply to the
PCI ranges DT binding. Fix this by removing the superfluous range.
Audio IP need the spba clock, but original clock name "dma" is not
accurate, so change it to name "spba". The audio driver has been
using the new name "spba", the binding document has been updated.
Signed-off-by: Shengjiu Wang <shengjiu.wang@freescale.com>
It can improve the USB performance when choosing larger
burst size at some systems (bus size is larger), there is
no side effect if this burst size is larger than bus size.
Signed-off-by: Peter Chen <peter.chen@freescale.com>
After setting ahb burst configuration as 0, we can increase tx/rx
burst size, it will improve the USB performance
The correct core clock of spdif is SPDIF_GCLK, which is added to
clock tree. So the dts also need to be updated.
Pull ARM DT updates from Olof Johansson:
"Ladies and gentlemen, we proudly announce to you the latest branch of
ARM device tree contents for the mainline kernel. Come and see, come
and see!
No less than twentythree thousand lines of additions! Just imagine the
joy you will have of using your mainline kernel on newly supported
hardware such as Rockchip Chromebooks, Freescale i.MX6UL boards or
UniPhier hardware!
For those of you feeling less adventurous, added hardware support on
platforms such as TI DM814x and Gumstix Overo platforms might be more
of your liking.
We've got something for everyone here!
Ahem. Cough. So, anyway...
This is the usual large batch of DT updates. Lots and lots of smaller
changes, some of the larger ones to point out are:
- Rockchip veyron (Chromebook) support, as well as several other new boards
- DRM support on Atmel AT91SAM9N12EK
- USB additions on some Allwinner platforms
- Mediatek MT6580 support
- Freescale i.MX6UL support
- cleanups for Renesas shmobile platforms
- lots of added devices on LPC18xx
- lots of added devices and boards on UniPhier
There's also some dependent code added here, in particular some
branches that are primarily merged through the clock tree"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (389 commits)
ARM: tegra: Add gpio-ranges property
ARM: tegra: Fix AHB base address on Tegra20, Tegra30 and Tegra114
ARM: tegra: Add Tegra124 PMU support
ARM: tegra: jetson-tk1: Add GK20A GPU DT node
ARM: tegra: venice2: Add GK20A GPU DT node
ARM: tegra: Add IOMMU node to GK20A
ARM: tegra: Add CPU regulator to the Jetson TK1 device tree
ARM: tegra: Add entries for cpufreq on Tegra124
ARM: tegra: Enable the DFLL on the Jetson TK1
ARM: tegra: Add the DFLL to Tegra124 device tree
ARM: dts: zynq: Add devicetree entry for Xilinx Zynq reset controller.
ARM: dts: UniPhier: fix PPI interrupt CPU mask of timer nodes
ARM: dts: rockchip: correct regulator power states for suspend
ARM: dts: rockchip: correct regulator PM properties
ARM: dts: vexpress: Use assigned-clock-parents for sp810
pinctrl: tegra: Only set the gpio range if needed
arm: boot: dts: am4372: add ARM timers and SCU nodes
ARM: dts: AM4372: Add the am4372-rtc compatible string
ARM: shmobile: r8a7794 dtsi: Add CPG/MSTP Clock Domain
ARM: shmobile: r8a7793 dtsi: Add CPG/MSTP Clock Domain
Pull crypto updates from Herbert Xu:
"Here is the crypto update for 4.3:
API:
- the AEAD interface transition is now complete.
- add top-level skcipher interface.
Drivers:
- x86-64 acceleration for chacha20/poly1305.
- add sunxi-ss Allwinner Security System crypto accelerator.
- add RSA algorithm to qat driver.
- add SRIOV support to qat driver.
- add LS1021A support to caam.
- add i.MX6 support to caam"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (163 commits)
crypto: algif_aead - fix for multiple operations on AF_ALG sockets
crypto: qat - enable legacy VFs
MPI: Fix mpi_read_buffer
crypto: qat - silence a static checker warning
crypto: vmx - Fixing opcode issue
crypto: caam - Use the preferred style for memory allocations
crypto: caam - Propagate the real error code in caam_probe
crypto: caam - Fix the error handling in caam_probe
crypto: caam - fix writing to JQCR_MS when using service interface
crypto: hash - Add AHASH_REQUEST_ON_STACK
crypto: testmgr - Use new skcipher interface
crypto: skcipher - Add top-level skcipher interface
crypto: cmac - allow usage in FIPS mode
crypto: sahara - Use dmam_alloc_coherent
crypto: caam - Add support for LS1021A
crypto: qat - Don't move data inside output buffer
crypto: vmx - Fixing GHASH Key issue on little endian
crypto: vmx - Fixing AES-CTR counter bug
crypto: null - Add missing Kconfig tristate for NULL2
crypto: nx - Add forward declaration for struct crypto_aead
snvs is MFP device. Change dts to use syscon to allocate register resource.
snvs power off also switch to common syscon-poweroff
Signed-off-by: Frank Li <Frank.Li@freescale.com>
Add CAAM device node to the i.MX6 device tree.
Signed-off-by: Victoria Milhoan <vicki.milhoan@freescale.com>
Tested-by: Horia Geantă <horia.geanta@freescale.com>
The PCIe interrupts are also routed through the GPC. This has been
missed from the conversion to stacked IRQ domains as the PCIe
controller uses an explicit interrupt map and thus doesn't inherit
the SoC global interrupt parent.
Cc: <stable@vger.kernel.org> # 4.1
Add ESAI, ASRC, CS42888 for imx6qdl-sabreauto board
The CODA960 VPU is part of the PU power domain. Add power-domains
phandle so it can be associated with the PU generic pm domain for
power gating.
Currently the HDMI controller is a child device of the AIPS bus in the
DT which is clearly wrong. Move it to the right location.
This introduces no functional change it just aligns the DT representation
with reality.
Since PWMs are only useful if they are actually connected to an output pin,
let users enable them explicitly in their device trees where they should
also set up the pin configuration.
The PU regulator is enabled during boot, but not necessarily always-on.
It can be disabled by the generic pm domain framework when the PU power
domain is shut down. The ramp delay of 150 us might be a bit conservative,
the value is taken from the Freescale kernel.
The PGC that is part of GPC controls isolation and power sequencing of the
power domains. The PU power domain will be handled by the generic pm domain
framework. It needs a phandle to the PU regulator to turn off power when
the domain is disabled, and a list of phandles to all clocks that must be
enabled during powerup for reset propagation.
The chipidea driver adds an extra line of spam to the log when a
host-only chipidea instance is left set to the default of a dual role
controller.
[ 2.010873] ci_hdrc ci_hdrc.1: doesn't support gadget
Set the dr_mode property to host on all the host-only nodes
to avoid this warning.
Signed-off-by: Matt Porter <mporter@konsulko.com>
Acked-by: Peter Chen <peter.chen@freescale.com>
IMX6 has been (ab)using the gic_arch_extn to provide
wakeup from suspend, and it makes a lot of sense to convert
this code to use stacked domains instead.
This patch does just this, updating the DT files to actually
reflect what the HW provides.
BIG FAT WARNING: because the DTs were so far lying by not
exposing the fact that the GPC block is actually the first
interrupt controller in the chain, kernels with this patch
applied wont have any suspend-resume facility when booted
with old DTs, and old kernels with updated DTs won't even boot.
Tested-by: Stefan Agner <stefan@agner.ch>
Acked-by: Stefan Agner <stefan@agner.ch>
It may be useful to disable the internal rtc snvs-rtc because an
external rtc is available. This patch adds a label so that board files
can disable this rtc.
Signed-off-by: Markus Pargmann <mpa@pengutronix.de>
The MIPI DSI node contains some ports which represent possible DRM CRTCs
it can connect with. Each port has a 'reg' property embedded. This
property will be wrongly interpretted by the MIPI DSI bus driver, because
the driver will take each subnode which contains a 'reg' property as a
DSI peripheral device. This patch moves the existing MIPI DSI ports into
a new 'ports' node so that the MIPI DSI bus driver may distinguish its
DSI peripheral device(s) from the existing ports.
Acked-by: Philipp Zabel <p.zabel@pengutronix.de>
Signed-off-by: Liu Ying <Ying.Liu@freescale.com>
Pull ARM SoC DT updates from Olof Johansson:
"DT changes continue to be the bulk of our merge window contents.
We continue to have a large set of changes across the board as new
platforms and drivers are added.
Some of the new platforms are:
- Alphascale ASM9260
- Marvell Armada 388
- CSR Atlas7
- TI Davinci DM816x
- Hisilicon HiP01
- ST STiH418
There have also been some sweeping changes, including relicensing of
DTS contents from GPL to GPLv2+/X11 so that the same files can be
reused in other non-GPL projects more easily. There's also been
changes to the DT Makefile to make it a little less conflict-ridden
and churny down the road"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (330 commits)
ARM: dts: Add PPMU node for exynos4412-trats2
ARM: dts: Add PPMU node for exynos3250-monk and exynos3250-rinato
ARM: dts: Add PPMU dt node for exynos4 and exynos4210
ARM: dts: Add PPMU dt node for exynos3250
ARM: dts: add mipi dsi device node for exynos4415
ARM: dts: add fimd device node for exynos4415
ARM: dts: Add syscon phandle to the video-phy node for Exynos4
ARM: dts: Add sound nodes for exynos4412-trats2
ARM: dts: Fix CLK_MOUT_CAMn parent clocks assignment for exynos4412-trats2
ARM: dts: Fix CLK_UART_ISP_SCLK clock assignment in exynos4x12.dtsi
ARM: dts: Add max77693 charger node for exynos4412-trats2
ARM: dts: Switch max77686 regulators to GPIO control for exynos4412-trats2
ARM: dts: Add suspend configuration for max77686 regulators for exynos4412-trats2
ARM: dts: Add Maxim 77693 fuel gauge node for exynos4412-trats2
ARM: dts: am57xx-beagle-x15: Fix USB2 mode
ARM: dts: am57xx-beagle-x15: Add extcon nodes for USB
ARM: dts: dra72-evm: Add extcon nodes for USB
ARM: dts: dra7-evm: Add extcon nodes for USB
ARM: dts: rockchip: move the hdmi ddc-i2c-bus property to the actual boards
ARM: dts: rockchip: enable vops and hdmi output on rk3288-firefly and -evb
According to Documentation/devicetree/bindings/media/coda.txt:
- clock-names : Should be "ahb", "per"
The OCRAM clock is already provided inside the ocram node, so remove the OCRAM
clock from the VPU node.
Commit a04a0b6fed4f ("ARM: dts: imx6qdl: Enable CODA960 VPU") lost the
fix for the CODA960 interrupt order during a rebase before being applied.
This patch adds the missing bit and brings the interrupts and
interrupt-names properties back in sync.
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
All chips of i.mx6 can be powered off by programming SNVS.
For example :
On i.mx6q-sabresd board, PMIC_ON_REQ connect with external
pmic ON/OFF pin, that will cause the whole PMIC powered off
except VSNVS. And system can restart once PMIC_ON_REQ goes
high by push POWRER key.
Signed-off-by: Robin Gong <b38343@freescale.com>
This patch adds links to the on-chip SRAM and reset controller nodes
and switches the interrupts. Make the BIT processor interrupt, which exists on
all variants, the first one. The JPEG unit interrupt, which does not exist on
i.MX27 and i.MX5 thus is an optional second interrupt.
Use different compatible strings for i.MX6Q/D and i.MX6S/DL, as they have to
load separate firmware images for some reason.
Original gpt per clk parent is from ipg_per clk which
may be scaled when system enter low bus mode, as ipg
clk will be lower in low bus mode, to keep system clk
NOT drift, select gpt per clk parent from OSC which
is at fixed freq always.
On i.mx6qdl, add a osc_per clk source for i.mx6q
TO > 1.0 and all i.MX6dl SoC.
On i.mx6sx, just make gpt per clk from OSC.
Signed-off-by: Anson Huang <b20788@freescale.com>
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
Baud clock is used for bit clock generation in master mode. Ipg clock
is peripheral clock and peripheral access clock.
Fixes "imx6q-pcie 1ffc000.pcie: missing *config* reg space"
error exposed by new versions of the designware pcie driver.
This patch adds simple-card support to the i.MX SoCs.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
Since commit 98ea6ad2edd2 (ARM: dts: imx6: use imx51-ssi) the mx6 ssi is
compatible with imx51, so align all the mx6 variant ssi compatible strings as:
compatible = "fsl,<imx6-soc>-ssi", "fsl,imx51-ssi";
When booting a board that does not have a keypad (such as imx6q-sabresd) the
following error is seen on boot:
imx-keypad 20b8000.kpp: OF: linux,keymap property not defined in /soc/aips-bus@02000000/kpp@020b8000
imx-keypad 20b8000.kpp: failed to build keymap
imx-keypad: probe of 20b8000.kpp failed with error -2
Let's disable the keypad functionality in the dtsi files and let each board dts
enable it when needed.
Switch to use DT macro for clock ID, so that device tree source is more
readable.
All dtsi files where already moved to generic dma bindings. Remove the
old non-generic DMA properties.
The S/PDIF rxtx4 and rxtx6 clock inputs are "ESAI_HCKT" and "MLB clock",
respectively, according to the SoC documentation, and they are currently
mapped to clocks "esai" and "mlb".
However, they do not seem to actually work correctly. Testing on a
Cubox-i system with fsl_spdif driver forced to select one of those as
input will result in I/O errors on audio playback, which I believe means
missing clock signal.
Possibly the "ESAI_HCKT" and "MLB clock" refer to some other clocks
related to ESAI and MLB, or we are missing something else.
Since audio playback will not work if fsl_spdif selects these clocks
(which happens rarely), set the inputs do dummy clocks, at least for
now.
Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi>
Cc: Mark Brown <broonie@kernel.org>
Acked-by: Nicolin Chen <Guangyu.Chen@freescale.com>
The rxtx2 clock of i.MX6 S/PDIF is currently set to "asrc" clock.
However, according to SoC documentation, rxtx2 is connected to
ASRC_EXT_CLK, a different external clock.
Testing on Cubox-i system seems to confirm that: when fsl_spdif is
forced to select rxtx2 as input clock, audio playback fails with an I/O
error.
Set rxtx2 to the dummy clock by default to prevent fsl_spdif from
selecting it.
Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
This patch adds CSI subnodes for IPU1 and IPU2 that will contain
ports and endpoints connecting to external elements in the video
pipeline.
The new bindings drops one clock, renames the others and
drops the old interrupt mapping.
