Remove the ldb clocks from the ldb node. Those clocks were added
upstream and they are needed for the DRM imx-ldb driver. Since we are
using the fbdev ldb driver for imx6qp, those clocks are not compatible
with our fbdev driver.
Fixes: 78241a88958a ("ARM: dts: add dts file for imx6qp")
Signed-off-by: Robert Chiras <robert.chiras@nxp.com>
In order to pass the pcie gen2 electronic compliance
tests, the external oscillator is manatory required.
Enable pcie external osc support on imx6qp platforms
Signed-off-by: Richard Zhu <Richard.Zhu@freescale.com>
Add dtsi and dts file for i.MX6QP
Signed-off-by: Bai Ping <b51503@freescale.com>
In 4.14 upstream has different definitions for pre/prg. Picked our
definitions instead because our driver is unrelated.
Adjusted pcie overrides to match upstream rename from
commit 3e1b857786f0 ("ARM: dts: imx: fix PCI bus dtc warnings")
Drop adding duplicate imx6qp-sabreauto.dtb to Makefile
Upstream removed definitions for ipu1/ipu2, added our definitions as per
latest 4.9.y. Originally part of:
MLK-14282: 4.9 rebase: LVDS display not working on iMX6QP SabreSD
Fix IPU2 DI(Display Interface) clocks for iMX6QP SABRESD. The upstream
version uses ldb_di0_podf and ldb_di1_podf as clock parents for ipu_di,
which fails to work on iMX6QP SABRESD. This patch fixes clock tree by:
- setting ipu_di selectors to ldb_di_div_sel in imx6q clock driver
- matching "ldb_di0", "ldb_di1" clock names with
IMX6QDL_CLK_LDB_DI0_DIV_SEL, IMX6QDL_CLK_LDB_DI1_DIV_SEL; otherwise,
ldb_di0_div_sel and ldb_di1_div_sel will not be recognized as LDB clk parents
and will not drive the Display Interface.
Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com>
Add the more specific QuadPlus compatible to the GPC node, to trigger the
required workarounds in the power domain code.
In regard to the interrupt mapping the QuadPlus controller is fully
compatible to the Quad one, so keep that compatible in place.
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
Add the DT nodes for the Prefetch Resolve Gaskets found on i.MX6QP
and hook them up to the assigned IPU nodes.
Add the DT nodes for the Prefetch Resolve Engines found on i.MX6QP.
Reference them by handle and remove the changed clocks that are copied
from the downstream DT and are not part of the mainline binding.
Referencing the node by handle make the QP DT more resilent against
changes of the base DT. Also remove the duplicated reg property, it's
not needed as it the same as in the base DT, just the compatible is
actually different.
By using the handle, we can avoid some duplication of the base DT
and so avoid any maintenance overhead in the QP DT if the referenced
node changes.
On i.MX6QP the FEC interrupts are wired to the GPC, just like all other
device interrupts. This allows to FEC to wake the CPU from WFI, but for
this to work the kernel needs to know about the new IRQ routing.
Pull ARM DT updates from Arnd Bergmann:
"Lots of changes as usual, so I'm trying to be brief here. Most of the
new hardware support has the respective driver changes merged through
other trees or has had it available for a while, so this is where
things come together.
We get a DT descriptions for a couple of new SoCs, all of them
variants of other chips we already support, and usually coming with a
new evaluation board:
- Oxford semiconductor (now Broadcom) OX820 SoC for NAS devices
- Qualcomm MDM9615 LTE baseband
- NXP imx6ull, the latest and smallest i.MX6 application processor variant
- Renesas RZ/G (r8a7743 and r8a7745) application processors
- Rockchip PX3, a variant of the rk3188 chip used in Android tablets
- Rockchip rk1108 single-core application processor
- ST stm32f746 Cortex-M7 based microcontroller
- TI DRA71x automotive processors
These are commercially available consumer platforms we now support:
- Motorola Droid 4 (xt894) mobile phone
- Rikomagic MK808 Android TV stick based on Rockchips rx3066
- Cloud Engines PogoPlug v3 based on OX820
- Various Broadcom based wireless devices:
- Netgear R8500 router
- Tenda AC9 router
- TP-LINK Archer C9 V1
- Luxul XAP-1510 Access point
- Turris Omnia open hardware router based on Armada 385
And a couple of new boards targeted at developers, makers or
industrial integration:
- Macnica Sodia development platform for Altera socfpga (Cyclone V)
- MicroZed board based on Xilinx Zynq FPGA platforms
- TOPEET itop/elite based on exynos4412
- WP8548 MangOH Open Hardware platform for IOT, based on Qualcomm MDM9615
- NextThing CHIP Pro gadget
- NanoPi M1 development board
- AM571x-IDK industrial board based on TI AM5718
- i.MX6SX UDOO Neo
- Boundary Devices Nitrogen6_SOM2 (i.MX6)
- Engicam i.CoreM6
- Grinn i.MX6UL liteSOM/liteBoard
- Toradex Colibri iMX6 module
Other changes:
- added peripherals on renesas, davinci, stm32f429, uniphier, sti,
mediatek, integrator, at91, imx, vybrid, ls1021a, omap, qualcomm,
mvebu, allwinner, broadcom, exynos, zynq
- Continued fixes for W=1 dtc warnings
- The old STiH415/416 SoC support gets removed, these never made it
into products and have served their purpose in the kernel as a
template for teh newer chips from ST
- The exynos4415 dtsi file is removed as nothing uses it.
- Intel PXA25x can now be booted using devicetree"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (422 commits)
arm: dts: zynq: Add MicroZed board support
ARM: dts: da850: enable high speed for mmc
ARM: dts: da850: Add node for pullup/pulldown pinconf
ARM: dts: da850: enable memctrl and mstpri nodes per board
ARM: dts: da850-lcdk: Add ethernet0 alias to DT
ARM: dts: artpec: add pcie support
ARM: dts: add support for Turris Omnia
devicetree: Add vendor prefix for CZ.NIC
ARM: dts: berlin2q-marvell-dmp: fix typo in chosen node
ARM: dts: berlin2q-marvell-dmp: fix regulators' name
ARM: dts: Add xo to sdhc clock node on qcom platforms
ARM: dts: r8a7794: Add device node for PRR
ARM: dts: r8a7793: Add device node for PRR
ARM: dts: r8a7792: Add device node for PRR
ARM: dts: r8a7791: Add device node for PRR
ARM: dts: r8a7790: Add device node for PRR
ARM: dts: r8a7779: Add device node for PRR
ARM: dts: r8a73a4: Add device node for PRR
ARM: dts: sk-rzg1e: add Ether support
ARM: dts: sk-rzg1e: initial device tree
On i.MX6QP the LDB clock tree has changed to move the clk gate
before the divider, to prevent clock glitches propagating downstream.
A consequence of this change is that the clk divider is now the
parent of the LDB inputs. Reflect this change in the devicetree
to allow the LDB driver to properly configure the display clocks.
MMDC has a slightly different programming model between imx6q and imx6qp
in terms of perf support, it's exactly same for suspend support, so we
have fsl,imx6q-mmdc here to save patching suspend driver with the new
compatible.
Signed-off-by: Frank Li <Frank.Li@nxp.com>
I.MX6Quad Plus has a slightly different version of PCIe core than reqular
i.MX6Quad.
Tested-by: Gary Bisson <gary.bisson@boundarydevices.com>
Signed-off-by: Andrey Smirnov <andrew.smirnov@gmail.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
The i.MX6Quad Plus processor is an high performance SOC of i.MX6 family.
It has enhanced graphics performance and increased overall memory bandwidth
compared to i.MX6Q. Most of the design are same as i.MX6Quad/Dual, so code
for i.MX6Quad can be resued by this chip. The revision number is identied as
i.MX6Q Rev2.0, but actually it is a new chip, as we did many change to the
overall architecture.
This patch adds basic dtsi file support for the new i.MX6Quad Plus processor.
Signed-off-by: Bai Ping <ping.bai@nxp.com>
