path: root/arch/arm/boot/dts/imx6sl-warp.dts
2016-06-11ARM: dts: imx: Use generic uart-has-rtscts DT propertyGeert Uytterhoeven
As of commit 1006ed7e1b258dac ("serial: imx: Use generic uart-has-rtscts DT property"), the Freescale IMX UART driver recognizes the generic "uart-has-rtscts" DT property, deprecating the vendor-specific "fsl,uart-has-rtscts" DT property. Hence replace the latter by the former in all DTS files. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-02-29ARM: dts: imx: replace legacy wakeup property with 'wakeup-source'Sudeep Holla
Though the keyboard and other driver will continue to support the legacy "gpio-key,wakeup", "linux,wakeup" and "enable-sdio-wakeup" boolean property to enable the wakeup source, "wakeup-source" is the new standard binding. This patch replaces all the legacy wakeup properties with the unified "wakeup-source" property in order to avoid any futher copy-paste duplication. Cc: Sascha Hauer <kernel@pengutronix.de> Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2015-08-11ARM: dts: imx6sl-warp: Add changes for rev1.12Fabio Estevam
Warp board rev1.12 is the version of the hardware that will be publicly available for the customers. It uses UART5 as the Bluetooth serial port as well as some additional signals for HOSTWAKE on Wifi and Bluetooth. Make the changes to support the rev1.12 hardware. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2015-07-15ARM: dts: imx6sl-warp: Add the SD2_RESET pinFabio Estevam
imx6sl-warp has SD2_RESET pin connected to the eMMC reset line, so add this pin to the usdhc2 group. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: dts: imx6sl-warp: Fix OTG rolesFabio Estevam
USBOTG1 always work on peripheral mode and USBOTG in host mode, so fix their roles accordingly. Tested by mounting the MMC card as a storage device: modprobe g_mass_storage file=/dev/mmcblk0p2 Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: dts: imx6sl-warp: Remove USB regulatorsFabio Estevam
According to the warp schematics there are no regulators for the USB OTG ports, so let's remove them. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: dts: imx6sl-warp: Remove unused regulatorFabio Estevam
The 'reg_1p8v' regulator is not used anywhere, so let's remove it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-03-30ARM: dts: imx6sl-warp: Add BCM4330 supportFabio Estevam
Warp has a Murata chip based on a BCM4330 that provides Wifi and Bluetooth functionality. Add support for it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-03-30ARM: dts: imx6sl-warp: Pass 'bus-width' propertyFabio Estevam
USDHC2 port uses all the 8 data signals, so pass the 'bus-width' property accordingly. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-03-30ARM: dts: warp: Add initial WaRP Board supportOtavio Salvador
The WaRP Board is a Wearable Reference Plaform. The board features: - Freescale i.MX6 SoloLite processor with 512MB of RAM - Freescale FXOS8700CQ 6-axis Xtrinsic sensor - Freescale Kinetis KL16 MCU - Freescale Xtrinsic MMA955xL intelligent motion sensing platform The board implements a hybrid architecture to address the evolving needs of the wearables market. The platform consists of a main board and an example daughtercard with the ability to add additional daughtercards for different usage models. For more information about the project, visit: http://www.warpboard.org/ Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
