The imx6 PCI driver ignores the GPIO polarity from 'reset-gpio' and
considers that the PCI reset is active low, unless the
property 'reset-gpio-active-high' is present.
Fix the device tree description by explicitly passing the
'GPIO_ACTIVE_LOW' flag to the 'reset-gpio' property.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
"bcrmf" is a typo and "wifi" is the preferred form to describe
such node, so change it accordingly.
Reported-by: Andreas Färber <afaerber@suse.de>
Reviewed-by: Andreas Färber <afaerber@suse.de>
The license text has been mangled at some point then copy pasted across
multiple files. Restore it to what it should be.
Note that this is not intended as a license change.
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Acked-by: Afzal Mohammed <afzal.mohd.ma@gmail.com>
Acked-by: Michael Trimarchi <michael@amarulasolutions.com>
Acked-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Since commit b36581df7e78 ("spi: imx: Using existing properties for
chipselects") the device tree property 'fsl,spi-num-chipselects' is
unused and it is already marked as obsolete in device tree binding
documentation. Remove the property from the existing DTS files to
avoid its reoccurence on copying.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
As of commit 1006ed7e1b258dac ("serial: imx: Use generic uart-has-rtscts
DT property"), the Freescale IMX UART driver recognizes the generic
"uart-has-rtscts" DT property, deprecating the vendor-specific
"fsl,uart-has-rtscts" DT property. Hence replace the latter by the
former in all DTS files.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Based on i.MX6 SoloX with 1GB of RAM.
https://boundarydevices.com/product/nit6_solox-imx6/
Signed-off-by: Gary Bisson <gary.bisson@boundarydevices.com>
