path: root/arch/arm/boot/dts/imx6sx-nitrogen6sx.dts
2018-12-10ARM: dts: imx6sx: Fix memory node duplicationFabio Estevam
Boards based on imx6sx have duplicate memory nodes: - One coming from the board dts file: memory@ - One coming from the imx6sx.dtsi file. Fix the duplication by removing the memory node from the dtsi file and by adding 'device_type = "memory";' in the board dts. Reported-by: Rob Herring <robh@kernel.org> Signed-off-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2018-07-17ARM: dts: imx6sx-nitrogen6sx: remove obsolete display configurationGary Bisson
This display configuration isn't working as-is as it depends on the tfp410 LCD to HDMI bridge. This will need to be updated later once the DRM MXSFB driver will be the default. Signed-off-by: Gary Bisson <gary.bisson@boundarydevices.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2018-07-17ARM: dts: imx: Switch Boundary Devices boards to SPDX identifierGary Bisson
Adopt the SPDX license identifier headers to ease license compliance management. Signed-off-by: Gary Bisson <gary.bisson@boundarydevices.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2018-05-14ARM: dts: imx: replace underscore with hyphen in aliases nameShawn Guo
It replaces underscore with hyphen in aliases name to fix DTC alias_paths warning below, which is seen with various i.MX board dts files when W=1 switch is on. Warning (alias_paths): /aliases: aliases property name must include only lowercase and '-' Signed-off-by: Shawn Guo <shawnguo@kernel.org> Acked-By: Lothar Waßmann <LW@KARO-electronics.de> Reviewed-by: Gary Bisson <gary.bisson@boundarydevices.com>
2018-02-12ARM: dts: imx: Add memory node unit nameMarco Franchi
Fix the following warnings from dtc by adding the unit name to memory nodes: Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name Converted using the following command: perl -p0777i -e 's/memory \{\n\t\treg = \<0x+([0-9a-f])/memory\@$1$\0000000 \{\n\t\treg = <0x$1/m' `find ./arch/arm/boot/dts -name "imx*"` The files below were manually fixed: -imx1-ads.dts -imx1-apf9328.dts -imx6q-pistachio.dts Signed-off-by: Marco Franchi <marco.franchi@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-10-20arm: dts: fix unit-address leading 0sRob Herring
Fix dtc warnings for 'simple_bus_reg' due to leading 0s. Converted using the following command: perl -p -i -e 's/\@0+([0-9a-f])/\@$1/g' `find arch/arm/boot/dts -type -f -name '*.dts*' Dropped changes to ARM, Ltd. boards LED nodes and manually fixed up some occurrences of uppercase hex. Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2017-06-07ARM: dts: imx6: Fix PCI GPIO reset polarityFabio Estevam
The imx6 PCI driver ignores the GPIO polarity from 'reset-gpio' and considers that the PCI reset is active low, unless the property 'reset-gpio-active-high' is present. Fix the device tree description by explicitly passing the 'GPIO_ACTIVE_LOW' flag to the 'reset-gpio' property. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-05-22ARM: dts: imx6: Fix BCM43xx node nameFabio Estevam
"bcrmf" is a typo and "wifi" is the preferred form to describe such node, so change it accordingly. Reported-by: Andreas Färber <afaerber@suse.de> Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Andreas Färber <afaerber@suse.de> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-01-10ARM: dts: imx/vf: Correct license textAlexandre Belloni
The license text has been mangled at some point then copy pasted across multiple files. Restore it to what it should be. Note that this is not intended as a license change. Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Afzal Mohammed <afzal.mohd.ma@gmail.com> Acked-by: Michael Trimarchi <michael@amarulasolutions.com> Acked-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-01-02ARM: dts: imx: remove obsoleted property fsl,spi-num-chipselectsVladimir Zapolskiy
Since commit b36581df7e78 ("spi: imx: Using existing properties for chipselects") the device tree property 'fsl,spi-num-chipselects' is unused and it is already marked as obsolete in device tree binding documentation. Remove the property from the existing DTS files to avoid its reoccurence on copying. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-06-11ARM: dts: imx: Use generic uart-has-rtscts DT propertyGeert Uytterhoeven
As of commit 1006ed7e1b258dac ("serial: imx: Use generic uart-has-rtscts DT property"), the Freescale IMX UART driver recognizes the generic "uart-has-rtscts" DT property, deprecating the vendor-specific "fsl,uart-has-rtscts" DT property. Hence replace the latter by the former in all DTS files. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-04-13ARM: dts: imx: add Boundary Devices Nitrogen6_SoloX boardGary Bisson
Based on i.MX6 SoloX with 1GB of RAM. https://boundarydevices.com/product/nit6_solox-imx6/ Signed-off-by: Gary Bisson <gary.bisson@boundarydevices.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
