path: root/arch/arm/boot/dts/imx6sx-pinfunc.h
2017-02-23MLK-11390-1 ARM: dts: update imx6sx pinfunc headerAnson Huang
Update i.MX6SX pinfunc header, add uart mux function. Signed-off-by: Anson Huang <b20788@freescale.com>
2016-08-29ARM: dts: imx6sx: document SION necessity of ENET1_REF_CLK1Christoph Fritz
Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2014-08-19ARM: dts: imx6sx: fix the pad setting for uart CTS_Bimx-fixes-3.17Fugang Duan
The current pinfunc define all uart CTS_B IO port for DCE uart 'CTS_B' IP port. Since uart IP port 'CTS_B' is output, and it don't need to set 'SELECT_INPUT' bit. Signed-off-by: Fugang Duan <B38611@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-07-18ARM: dts: imx: add pin function header for imx6sxShawn Guo
Add pin function header for i.MX6 SoloX SoC. Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
