path: root/arch/arm/boot/dts/imx6sx-udoo-neo-basic.dts
2016-11-14ARM: dts: imx6sx-udoo: Add board specific compatible stringsFabio Estevam
Add a compatible entry for the specific board versions. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-10-24ARM: dts: imx6sx: Add UDOO Neo supportAndreas Färber
Add initial device trees for UDOO Neo Basic, Extended and Full boards: * Serial console is enabled, other serial ports are prepared. * I2C based PMIC is enabled. * Ethernet is enabled for Basic and Full. * SDHC is enabled, with the SDIO_PWR GPIO modeled as a regulator. * Both user LEDs are enabled, with the orange one reserved for the M4 and with the SD card as default trigger for the red LED. The decision on a board compatible string is deferred to later. Cc: Ettore Chimenti <ettore.chimenti@udoo.org> Signed-off-by: Andreas Färber <afaerber@suse.de> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
