path: root/arch/arm/boot/dts/imx6sx-udoo-neo-extended.dts
2019-06-12ARM: dts: imx6sx-udoo-neo: add bluetooth config to uart3Peter Robinson
This updates the WL1831 bluetooth to use the serial serdev driver interface. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2019-06-12ARM: dts: imx6sx-udoo-neo: enable i2c-2 and i2c-4 for onboard sensorsPeter Robinson
The i2c2 bus has a external plug which enables the easy connection of external "bricks" with sensors of various kinds, while i2c4 on the Extended/Full boards has a pair of on board motion sensors, accelerometer and magnetometer on one chip and gyroscope on another so it makes sense to enable these i2c buses for use. Tested on UDOO Neo Full. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2019-06-12ARM: dts: imx6sx-udoo: Use the correct style for SPDX License IdentifierPeter Robinson
Use the SPDX License Identifier for GPL-2.0+ OR X11 Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2018-12-10ARM: dts: imx6sx: Fix memory node duplicationFabio Estevam
Boards based on imx6sx have duplicate memory nodes: - One coming from the board dts file: memory@ - One coming from the imx6sx.dtsi file. Fix the duplication by removing the memory node from the dtsi file and by adding 'device_type = "memory";' in the board dts. Reported-by: Rob Herring <robh@kernel.org> Signed-off-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2018-02-12ARM: dts: imx: Add memory node unit nameMarco Franchi
Fix the following warnings from dtc by adding the unit name to memory nodes: Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name Converted using the following command: perl -p0777i -e 's/memory \{\n\t\treg = \<0x+([0-9a-f])/memory\@$1$\0000000 \{\n\t\treg = <0x$1/m' `find ./arch/arm/boot/dts -name "imx*"` The files below were manually fixed: -imx1-ads.dts -imx1-apf9328.dts -imx6q-pistachio.dts Signed-off-by: Marco Franchi <marco.franchi@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-11-14ARM: dts: imx6sx-udoo: Add board specific compatible stringsFabio Estevam
Add a compatible entry for the specific board versions. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-10-24ARM: dts: imx6sx: Add UDOO Neo supportAndreas Färber
Add initial device trees for UDOO Neo Basic, Extended and Full boards: * Serial console is enabled, other serial ports are prepared. * I2C based PMIC is enabled. * Ethernet is enabled for Basic and Full. * SDHC is enabled, with the SDIO_PWR GPIO modeled as a regulator. * Both user LEDs are enabled, with the orange one reserved for the M4 and with the SD card as default trigger for the red LED. The decision on a board compatible string is deferred to later. Cc: Ettore Chimenti <ettore.chimenti@udoo.org> Signed-off-by: Andreas Färber <afaerber@suse.de> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
