commit 1bcfe0564044be578841744faea1c2f46adc8178 upstream.
Use the correct IRQ line for the MSI controller in the PCIe host
controller. Apparently a different IRQ line is used compared to other
i.MX6 variants. Without this change MSI IRQs aren't properly propagated
to the upstream interrupt controller.
Signed-off-by: Oleksij Rempel <o.rempel@pengutronix.de>
Reviewed-by: Lucas Stach <l.stach@pengutronix.de>
Fixes: b1d17f68e5c5 ("ARM: dts: imx: add initial imx6sx device tree source")
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
Make the syscon-poweroff driver change only the shutdown bits on the
SNVS_LP control register.
This change fixes an issue with the RTC wakeup alarm, that was
previously disabled during power off.
Signed-off-by: Guy Shapiro <guy.shapiro@mobi-wize.com>
Reviewed-by: Marcin Niestroj <m.niestroj@grinn-global.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Now that support for 'anatop-enable-bit' has been added to ANADIG
driver, reintroduce 'anatop-enable-bit' for all applicable LDOs.
Cc: yurovsky@gmail.com
Cc: Dong Aisheng <aisheng.dong@nxp.com>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Russell King <linux@armlinux.org.uk>
Cc: devicetree@vger.kernel.org
Signed-off-by: Andrey Smirnov <andrew.smirnov@gmail.com>
dtc recently added PCI bus checks. Fix these warnings.
Signed-off-by: Rob Herring <robh@kernel.org>
UART on i.MX6SX (like all other i.MX6 SoC variants) has the same
programming model as the 'imx6q-uart' type, so add it to the compatible
UART string.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Commit 7f107887d199 ("ARM: dts: imx: Remove skeleton.dtsi") causes boot
issues when the bootloader does not create a 'chosen' node if such node
is not present in the dtb.
The reason for the boot failure is well explained by Javier Martinez
Canillas: "the decompressor relies on a pre-existing chosen node to be
available to insert the command line and merge other ATAGS info."
, so pass an empty 'chosen' node to fix the boot problem.
This issue has been seen in the kernelci reports with Barebox as
bootloader.
Also pass the 'memory' node in order to fix boot issues on the SolidRun
iMX6 platforms.
Fixes: 7f107887d199 ("ARM: dts: imx: Remove skeleton.dtsi")
Reported-by: kernelci.org bot <bot@kernelci.org>
Reported-by: Russell King <rmk+kernel@armlinux.org.uk>
Commit 1be81ea5860744520 ("ARM: dts: imx6: Add imx-weim parameters to
dtsi's") causes the following probe error when the weim node is not
present on the board dts (such as imx6q-sabresd):
imx-weim 21b8000.weim: Invalid 'ranges' configuration
imx-weim: probe of 21b8000.weim failed with error -22
There is no need to always enable the "weim" node on mx6. Do the same
as in the other i.MX dtsi files where "weim" is disabled and only gets
enabled on a per dts basis.
All the imx6 weim dts users explicitily provide 'status = "okay"', so
this change has no impact on current imx6 weim users.
If a board does not use the weim driver it will not describe its 'ranges'
property, so simply disable the 'weim' node in the imx6 dtsi files to
avoid such probe error message.
Fixes: 1be81ea5860744520 ("ARM: dts: imx6: Add imx-weim parameters to dtsi's")
As explained by commit 9c0da3cc61f1233c ("ARM: dts: explicitly mark
skeleton.dtsi as deprecated"), including skeleton.dtsi is deprecated.
This fixes the following warning with W=1:
Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name
imx-weim should always set address-cells to 2,
and size_cells to 1.
On imx6, fsl,weim-cs-gpr will always be &gpr
Set these common parameters in the dtsi file,
rather than in a downstream dts.
Signed-off-by: Joshua Clayton <stillcompiling@gmail.com>
Fixed code indent tabs in respetcive imx23, imx51, imx53, imx6dl, imx6q
and imx6sx dtsi and dts files.
Signed-off-by: Jagan Teki <jagan@openedev.com>
The LCDIF interrupt should be triggered by the rising edge of the
IRQ line because we only want the interrupt to trigger once per each
frame. It seems the LCDIF IRQ line cannot be explicitly de-asserted
by software, so the previous behavior before this patch, where the
interrupt was triggered by level-high status of the IRQ line, caused
the interrupt to fire again immediatelly after it was handled, which
caused the system to lock up due to the high rate of interrupts.
Cc: Lucas Stach <l.stach@pengutronix.de>
To establish a connection between GPIO controllers and pin multiplexor
controller add gpio-ranges properties to all GPIO controllers found
on iMX50, iMX6Q/D, iMX6DL/S, iMX6SL, iMX6SX, iMX6UL and iMX7D/S
SoCs. The change was done after human parsing of output from
% gawk -n '{ sub(/.*__/, ""); if ($1 ~ "^GPIO") print $1, $2/4}' imxXX-pinfunc.h | sort -n
Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com>
Add bindings for the Vivante GC400T GPU found in the i.MX6SX.
Building with W=1 option leads to several warnings like:
Warning (unit_address_vs_reg): Node /soc/aips-bus@02000000/anatop@020c8000/regulator-1p1@110 has a unit name, but no reg property
Fix them by removing the unneeded unit-addresses.
Acked-by: Rob Herring <robh@kernel.org>
198MHz is a valid operating point for mx6sx.
Add entries for VDD_ARM_CAP and VDD_SOC_CAP voltages for 198MHz according
to the imx6sx datahseet:
http://cache.nxp.com/files/32bit/doc/data_sheet/IMX6SXIEC.pdf
(a 25mV offset is added to the minimum allowed values for safety).
These values also match the ones from the NXP kernel.
Property 'dma-source' is not used anywhere, nor it is documented, so
let's just get rid of it.
According to sdma_peripheral_type in include/linux/platform_data/dma-imx.h
IMX_DMATYPE_SAI corresponds to index 24, so fix it accordingly.
Suggested-by: Zidan Wang <zidan.wang@nxp.com>
Audio IP need the spba clock, but original clock name "dma" is not
accurate, so change it to name "spba". The audio driver has been
using the new name "spba", the binding document has been updated.
Signed-off-by: Shengjiu Wang <shengjiu.wang@freescale.com>
Specify the 'adck-max-frequency' property in the adc nodes.
According to Documentation/devicetree/bindings/iio/adc/vf610-adc.txt
this is a recommended property.
Acked-by: Fugang Duan <B38611@freescale.com>
It can improve the USB performance when choosing larger
burst size at some systems (bus size is larger), there is
no side effect if this burst size is larger than bus size.
Signed-off-by: Peter Chen <peter.chen@freescale.com>
After setting ahb burst configuration as 0, we can increase tx/rx
burst size, it will improve the USB performance
The correct core clock of spdif is SPDIF_GCLK, which is added to
clock tree. So the dts also need to be updated.
Pull ARM DT updates from Olof Johansson:
"Ladies and gentlemen, we proudly announce to you the latest branch of
ARM device tree contents for the mainline kernel. Come and see, come
and see!
No less than twentythree thousand lines of additions! Just imagine the
joy you will have of using your mainline kernel on newly supported
hardware such as Rockchip Chromebooks, Freescale i.MX6UL boards or
UniPhier hardware!
For those of you feeling less adventurous, added hardware support on
platforms such as TI DM814x and Gumstix Overo platforms might be more
of your liking.
We've got something for everyone here!
Ahem. Cough. So, anyway...
This is the usual large batch of DT updates. Lots and lots of smaller
changes, some of the larger ones to point out are:
- Rockchip veyron (Chromebook) support, as well as several other new boards
- DRM support on Atmel AT91SAM9N12EK
- USB additions on some Allwinner platforms
- Mediatek MT6580 support
- Freescale i.MX6UL support
- cleanups for Renesas shmobile platforms
- lots of added devices on LPC18xx
- lots of added devices and boards on UniPhier
There's also some dependent code added here, in particular some
branches that are primarily merged through the clock tree"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (389 commits)
ARM: tegra: Add gpio-ranges property
ARM: tegra: Fix AHB base address on Tegra20, Tegra30 and Tegra114
ARM: tegra: Add Tegra124 PMU support
ARM: tegra: jetson-tk1: Add GK20A GPU DT node
ARM: tegra: venice2: Add GK20A GPU DT node
ARM: tegra: Add IOMMU node to GK20A
ARM: tegra: Add CPU regulator to the Jetson TK1 device tree
ARM: tegra: Add entries for cpufreq on Tegra124
ARM: tegra: Enable the DFLL on the Jetson TK1
ARM: tegra: Add the DFLL to Tegra124 device tree
ARM: dts: zynq: Add devicetree entry for Xilinx Zynq reset controller.
ARM: dts: UniPhier: fix PPI interrupt CPU mask of timer nodes
ARM: dts: rockchip: correct regulator power states for suspend
ARM: dts: rockchip: correct regulator PM properties
ARM: dts: vexpress: Use assigned-clock-parents for sp810
pinctrl: tegra: Only set the gpio range if needed
arm: boot: dts: am4372: add ARM timers and SCU nodes
ARM: dts: AM4372: Add the am4372-rtc compatible string
ARM: shmobile: r8a7794 dtsi: Add CPG/MSTP Clock Domain
ARM: shmobile: r8a7793 dtsi: Add CPG/MSTP Clock Domain
Commit(def56bb input: snvs_pwrkey: use "wakeup-source"
as deivce tree property name) replaces the property name
of "wakeup" with "wakeup-source", update this change
in i.MX6SX dtsi accordingly.
Signed-off-by: Anson Huang <b20788@freescale.com>
snvs is MFP device. Change dts to use syscon to allocate register resource.
snvs power off also switch to common syscon-poweroff
Signed-off-by: Frank Li <Frank.Li@freescale.com>
Add CAAM device node to the i.MX6SX device tree.
Signed-off-by: Victoria Milhoan <vicki.milhoan@freescale.com>
Tested-by: Horia Geantă <horia.geanta@freescale.com>
enable snvs ONOFF power key support
It may be useful to disable the internal snvs-rtc when an external rtc is
available. This patch adds a label so that dts files can disable it.
Based on a patch from Markus Pargmann for imx6qdl.dtsi.
The chipidea driver adds an extra line of spam to the log when a
host-only chipidea instance is left set to the default of a dual role
controller.
[ 2.010873] ci_hdrc ci_hdrc.1: doesn't support gadget
Set the dr_mode property to host on all the host-only nodes
to avoid this warning.
Signed-off-by: Matt Porter <mporter@konsulko.com>
Acked-by: Peter Chen <peter.chen@freescale.com>
IMX6 has been (ab)using the gic_arch_extn to provide
wakeup from suspend, and it makes a lot of sense to convert
this code to use stacked domains instead.
This patch does just this, updating the DT files to actually
reflect what the HW provides.
BIG FAT WARNING: because the DTs were so far lying by not
exposing the fact that the GPC block is actually the first
interrupt controller in the chain, kernels with this patch
applied wont have any suspend-resume facility when booted
with old DTs, and old kernels with updated DTs won't even boot.
Tested-by: Stefan Agner <stefan@agner.ch>
Acked-by: Stefan Agner <stefan@agner.ch>
All chips of i.mx6 can be powered off by programming SNVS.
For example :
On i.mx6q-sabresd board, PMIC_ON_REQ connect with external
pmic ON/OFF pin, that will cause the whole PMIC powered off
except VSNVS. And system can restart once PMIC_ON_REQ goes
high by push POWRER key.
Signed-off-by: Robin Gong <b38343@freescale.com>
Add enet2 support for imx6sx-sdb board, and add the "fsl,imx6q-fec"
compatible for fec2 node to be compatible with the old version.
Signed-off-by: Fugang Duan <B38611@freescale.com>
Pull networking updates from David Miller:
"Most notable changes in here:
1) By far the biggest accomplishment, thanks to a large range of
contributors, is the addition of multi-send for transmit. This is
the result of discussions back in Chicago, and the hard work of
several individuals.
Now, when the ->ndo_start_xmit() method of a driver sees
skb->xmit_more as true, it can choose to defer the doorbell
telling the driver to start processing the new TX queue entires.
skb->xmit_more means that the generic networking is guaranteed to
call the driver immediately with another SKB to send.
There is logic added to the qdisc layer to dequeue multiple
packets at a time, and the handling mis-predicted offloads in
software is now done with no locks held.
Finally, pktgen is extended to have a "burst" parameter that can
be used to test a multi-send implementation.
Several drivers have xmit_more support: i40e, igb, ixgbe, mlx4,
virtio_net
Adding support is almost trivial, so export more drivers to
support this optimization soon.
I want to thank, in no particular or implied order, Jesper
Dangaard Brouer, Eric Dumazet, Alexander Duyck, Tom Herbert, Jamal
Hadi Salim, John Fastabend, Florian Westphal, Daniel Borkmann,
David Tat, Hannes Frederic Sowa, and Rusty Russell.
2) PTP and timestamping support in bnx2x, from Michal Kalderon.
3) Allow adjusting the rx_copybreak threshold for a driver via
ethtool, and add rx_copybreak support to enic driver. From
Govindarajulu Varadarajan.
4) Significant enhancements to the generic PHY layer and the bcm7xxx
driver in particular (EEE support, auto power down, etc.) from
Florian Fainelli.
5) Allow raw buffers to be used for flow dissection, allowing drivers
to determine the optimal "linear pull" size for devices that DMA
into pools of pages. The objective is to get exactly the
necessary amount of headers into the linear SKB area pre-pulled,
but no more. The new interface drivers use is eth_get_headlen().
From WANG Cong, with driver conversions (several had their own
by-hand duplicated implementations) by Alexander Duyck and Eric
Dumazet.
6) Support checksumming more smoothly and efficiently for
encapsulations, and add "foo over UDP" facility. From Tom
Herbert.
7) Add Broadcom SF2 switch driver to DSA layer, from Florian
Fainelli.
8) eBPF now can load programs via a system call and has an extensive
testsuite. Alexei Starovoitov and Daniel Borkmann.
9) Major overhaul of the packet scheduler to use RCU in several major
areas such as the classifiers and rate estimators. From John
Fastabend.
10) Add driver for Intel FM10000 Ethernet Switch, from Alexander
Duyck.
11) Rearrange TCP_SKB_CB() to reduce cache line misses, from Eric
Dumazet.
12) Add Datacenter TCP congestion control algorithm support, From
Florian Westphal.
13) Reorganize sk_buff so that __copy_skb_header() is significantly
faster. From Eric Dumazet"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1558 commits)
netlabel: directly return netlbl_unlabel_genl_init()
net: add netdev_txq_bql_{enqueue, complete}_prefetchw() helpers
net: description of dma_cookie cause make xmldocs warning
cxgb4: clean up a type issue
cxgb4: potential shift wrapping bug
i40e: skb->xmit_more support
net: fs_enet: Add NAPI TX
net: fs_enet: Remove non NAPI RX
r8169:add support for RTL8168EP
net_sched: copy exts->type in tcf_exts_change()
wimax: convert printk to pr_foo()
af_unix: remove 0 assignment on static
ipv6: Do not warn for informational ICMP messages, regardless of type.
Update Intel Ethernet Driver maintainers list
bridge: Save frag_max_size between PRE_ROUTING and POST_ROUTING
tipc: fix bug in multicast congestion handling
net: better IFF_XMIT_DST_RELEASE support
net/mlx4_en: remove NETDEV_TX_BUSY
3c59x: fix bad split of cpu_to_le32(pci_map_single())
net: bcmgenet: fix Tx ring priority programming
Original gpt per clk parent is from ipg_per clk which
may be scaled when system enter low bus mode, as ipg
clk will be lower in low bus mode, to keep system clk
NOT drift, select gpt per clk parent from OSC which
is at fixed freq always.
On i.mx6qdl, add a osc_per clk source for i.mx6q
TO > 1.0 and all i.MX6dl SoC.
On i.mx6sx, just make gpt per clk from OSC.
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
imx6sx has the same LCDIF controller IP as in mx28, so add the proper
compatible strings.
This patch adds simple-card support to the i.MX SoCs.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
Enable 3 queues suppport for ethernet
Since commit 98ea6ad2edd2 (ARM: dts: imx6: use imx51-ssi) the mx6 ssi is
compatible with imx51, so align all the mx6 variant ssi compatible strings as:
compatible = "fsl,<imx6-soc>-ssi", "fsl,imx51-ssi";
The SDMA on imx6sl and imx6sx is more compatible with imx6q one than
imx35. Let's use "fsl,imx6q-sdma" instead of "fsl,imx35-sdma", so that
SDMA ROM script on imx6sl and imx6sx can work for audio driver just like
the case of imx6q.
Reported-by: Fabio Estevam <fabio.estevam@freescale.com>
Acked-by: Robin Gong <yibin.gong@freescale.com>
Like the other mx6 variants, we need to pass fsl,fifo-depth property in dtsi.
Use the correct compatible string for sdma and also provide the sdma firmware
path.
Fix usbmisc compatible string so that usbmisc node can be found and USB
functionality can be functional.
The imx6sx iomuxc-gpr syscon is compatible to imx6q, so let's add
compatible string 'fsl,imx6q-iomuxc-gpr' for imx6sx iomuxc-gpr syscon node.
This is necessary to enable SW workaround for ERR007265,
please refer to imx6_pm_common_init of arch/arm/mach-imx/pm-imx6.c
for detail.
The other i.mx6 variants use "vddarm" as the name of the internal regulator
that powers the core. Use the same convention here for consistency.
Add initial device tree source for i.MX6 SoloX SoC.
