2017-02-23 | MLK-12466 ARM: dts: imx6ul-14x14-evk-usb-certi: add USB certification dts | Peter Chen | |
Below are the differences between standard evk: - Enable tpl - Enable software control vbus for otg2 (hardware rework is needed) - Disable TSC due to the pin conflict with above vbus regulator Signed-off-by: Peter Chen <peter.chen@nxp.com> |
