The sw2iso count should cover ARM LDO ramp-up time,
the MAX ARM LDO ramp-up time may be up to more than
100us, this patch sets sw2iso to 0xf (~384us) which
is the default value.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Reviewed-by: Bai Ping <ping.bai@nxp.com>
This reverts commit e10bb395568fbda30eb76cf0d0d6e479ed30648f.
The mxsfb driver uses old bindings so we need to provide those
Acked-by: Robert Chiras <robert.chiras@nxp.com>
Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com>
Add USB OTG1 port ID pin for imx6ul-14x14-evk.dts
Acked-by: Peter Chen <peter.chen@nxp.com>
Signed-off-by: Li Jun <jun.li@nxp.com>
Commit 65e6b5f1b4a7 ("ASoC: wm8960: Fix playback in CPU DAI master
mode") broke wm8960 codec master mode by choosing "bad" SYSCLK values.
This patch partially reverts commit mentioned above by restoring the
SYSCLK values. It turns out that using params_physical_width instead of
params_width in the previous patch it is enough to fix CPU DAI mode.
Signed-off-by: Daniel Baluta <daniel.baluta@nxp.com>
With the current rates for MCLK is not possible to derive bitclk
for all files in S20_3LE format and also for files with S24_LE sampled
at 48000Hz.
In order to fix this, we need to find a better MCLK value. We did this
in two steps:
1) Use params_physical_width to get rid of S20_3LE burden.
2) Brute force into all available rates which can pass fsl_sai_set_bclk
algorithm.
Thus we found 36864000 to be the smallest acceptable rate for MCLK.
Reviewed-by: Mihai Serban <mihai.serban@nxp.com>
Suggested-by: Shengjiu Wang <shengjiu.wang@nxp.com>
For the slot support SD3.0 card, during system suspend, if plug out
the sd card, and insert another SD3.0 card, after system resume back,
SD3.0 card can't be recognised as SD3.0 card, just SD2.0 card.
This is bause the time delay between vmmc regulator off and on is
too small, this patch add the oo-on-delay in vmmc-supply regulator,
to assign proper delay value.
Signed-off-by: Haibo Chen <haibo.chen@nxp.com>
enable sim for imx6ul
Signed-off-by: Gao Pan <pandy.gao@nxp.com>
Commit 2c2a56059ff7e7e4 ("MLK-11407-8: ARM: dts: i.mx6sx/i.mx6ul: add
ldo-bypass support") was backported from imx_4.1.y and added a
duplicate i2c node which was already present upstream.
This patch removes the duplicated node and moves the difference
(clocks for wm8960) to the existing upstream node.
Signed-off-by: Octavian Purdila <octavian.purdila@nxp.com>
Reviewed-by: Daniel Baluta <daniel.baluta@nxp.com>
Add BT modem device reset node.
Signed-off-by: Fugang Duan <fugang.duan@nxp.com>
Upstream commit bf3251e ("ARM: dts: imx6ul-14x14-evk: Add audio
support") switched to using the simple sound card driver.
This does not seem to work anymore on vanilla 4.9.5 (aplay gets stuck
with no sound output). Adding the rest of our out internal patches
from 4.1 causes even greater issues, the card does not even enumerate.
While we eventually want to switch to using simple sound card, lets
revert to using the fsl,imx-audio-wm8960 driver for the time being,
while investigating what it takes to switch to the simple sound card
driver.
They belong in the usdhc1 group, where they were already present and
which causes the usdhc1 device to fail probe:
[ 1.484978] imx6ul-pinctrl 20e0000.iomuxc: pin MX6UL_PAD_UART1_RTS_B already requested by 20e0000.iomuxc; cannot claim for 2190000.usdhc
[ 1.496166] imx6ul-pinctrl 20e0000.iomuxc: pin-36 (2190000.usdhc) status -22
[ 1.501959] imx6ul-pinctrl 20e0000.iomuxc: could not request pin 36 (MX6UL_PAD_UART1_RTS_B) from group usdhc1grp on device 20e0000.iomuxc
[ 1.513186] sdhci-esdhc-imx 2190000.usdhc: Error applying setting, reverse things back
Note that out internal commit cf65c8d ("MLK-11300-02 ARM: dts: imx:
add imx6ul board dts support") is similar with the upstream commit
a5fcccb ("ARM: dts: imx: add imx6ul and imx6ul evk board support") but
since it has more nodes defined we had to integrate parts of it
nonetheless.
Add new pf1550 board support.
Signed-off-by: Robin Gong <yibin.gong@nxp.com>
Enable eMMC for i.MX6UL EVK rework board due to the pad conflict with NAND
and Micro-SD.
Q901 (IRLML6401) is p-channel MOSET, need set pin1 (LCD_nPWREN) to low
to let pin3 output be 3V3. Normally when pin1 is high, then pin3
output should be gated. It was working previously due to some leakage.
Correct the enable logic from the software viewpoint.
Signed-off-by: Robby Cai <robby.cai@nxp.com>
CMA region is a must to avoid the multile memory mapping
for the DMAed memory and also benifit the large continious
phisical memory allocation.
The default value is depend on the target system design and
user cases definition. This is not suitable to put this into
the soc.dtsi, thus we put it into the board DTS.
customer can override the value by changing cma size in DTS file.
Again, customer need set the CMA size correctly according to the
target system. The incorrectly CMA size can cause Linux kernel fail
to boot up.CMA disabled or CMA size set to zero is also not allowed.
Signed-off-by: Jason Liu <jason.hui.liu@nxp.com>
We move WDOG_B pinctrl setting from pinctrl_hog to wdog driver, so need to
remove the original setting in pinctl_hog device node, otherwise the below
warning message will be caught:
[ 1.284161] imx6ul-pinctrl 20e0000.iomuxc: pin MX6UL_PAD_LCD_RESET already requested by 20e0000.iomuxc; cannot claim for 20bc000.wdog
[ 1.294990] imx6ul-pinctrl 20e0000.iomuxc: pin-69 (20bc000.wdog) status -22
[ 1.300689] imx6ul-pinctrl 20e0000.iomuxc: could not request pin 69 (MX6UL_PAD_LCD_RESET) from group wdoggrp on device 20e0000.iomuxc
[ 1.311550] imx2-wdt 20bc000.wdog: Error applying setting, reverse things back
Signed-off-by: Robin Gong <b38343@freescale.com>
Since we have supported control vbus through ID pin, we can
support dual switch function for otg port, but fully otg can't
be supported at this port.
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Sim card CVCC is determined by the gpio value from sim controller.
How the CVCC is controlled on both post card boards is decribed below.
NCN8025:Vcc=ACTIVE_HIGH?5V:3V
TDA8035:Vcc=ACTIVE_HIGH?5V:1.8V
Different sim cards have different CVCC range. To support all cards
with same dts, this patch set gpio active high.
Signed-off-by: Gao Pan <b54642@freescale.com>
Change pad settings to improve signal quality.
The TF card slot on uSDHC2 does not support CD function,
so add non-removable property.
Signed-off-by: Dong Aisheng <aisheng.dong@freescale.com>
The SD CLK signal measured by scope shows the signal rise/fall time
does not meet the spec requirement, need increase the pad driver
strength to meet the spec.
The pad setting value is given by the HW team which has been verified
from scope.
Signed-off-by: Dong Aisheng <b29396@freescale.com>
(cherry picked from commit e4944a51c4bb950a8f13e421eefc000a87350e23)
(cherry picked from commit f491804bc93ebd15adb3222ff4774d14eb714491)
iomux hoggrp
Commit cb75ac1d83e interduces one issue that add fxls8471 interrupt pin into
other module pin function. The patch move the pin to iomux hoggrp pin group.
Signed-off-by: Fugang Duan <B38611@freescale.com>
Add i.MX6UL board support dts file for boards:
* imx6ul-14X14-evk.dts
* imx6ul-14x14-ddr3-arm2.dts
Signed-off-by: Ye.Li <Ye.Li@freescale.com>
Signed-off-by: Bai Ping <b51503@freescale.com>
[Octavian: merge with upstream, prefer upstrem in case of conflict]
MX6UL_PAD_SNVS_TAMPER0__GPIO5_IO00 is connected to the INT1 pin of
the FXLS8471Q accelerometer, so remove it from the unrelated ENET
group.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Pass the 'backlight' property as described in
Documentation/devicetree/bindings/display/panel/simple-panel.txt
Signed-off-by: Marco Franchi <marco.franchi@nxp.com>
It is preferred to use the panel compatible string rather than passing the LCD
timming in the device tree.
So pass the "innolux,at043tn24" compatible string to describe the parallel LCD
on this board.
Right now mach-imx6ul registers a fixup for the ksz8081 phy. The same
register values can be set through the micrel phy driver by using dts
properties.
This seems preferable and allows cleanly fixing suspend/resume.
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
imx6ul.dtsi already contains:
cpu0: cpu@0 {
arm-supply = <®_arm>;
soc-supply = <®_soc>;
, so remove the duplication.
We need to change trimming value (as a percentage) of the 17.78mA TX
reference current for better signal quality. With this change, we
can pass the eye-diagram test on this board.
Signed-off-by: Peter Chen <peter.chen@nxp.com>
With commit 851ce932242d ("usb: chipidea: otg: don't wait vbus
drops below BSV when starts host"), the driver can support
enabling vbus output without software control, so this board
(control vbus output through ID pin) can support dual-role now.
imx6ul-evk has WDOG1_B pin connected to the PMIC.
Pass the 'fsl,ext-reset-output' property so that the watchdog
can trigger a system POR reset via the PMIC.
Add support for the LCD8000-43T display and for the backlight
controlled via PWM1.
As of commit 1006ed7e1b258dac ("serial: imx: Use generic uart-has-rtscts
DT property"), the Freescale IMX UART driver recognizes the generic
"uart-has-rtscts" DT property, deprecating the vendor-specific
"fsl,uart-has-rtscts" DT property. Hence replace the latter by the
former in all DTS files.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Pass "fsl,sai-mclk-direction-output" to the sai2 node, so that the
SAI2_MCLK can be an output.
imx6ul-14x14-evk has a wm8960 codec connected via SAI2 port.
Add support for it.
Thanks to Petr Kulhavy <brain@jikos.cz> for the hint on initializing
the PLL4 frequency to get a correct MCLK.
imx6ul.dtsi references the macro 'KEY_POWER' from
dt-bindings/input/input.h. Thus, move the include statement for this
file from imx6ul-14x14-evk.dts to imx6ul.dtsi itself.
Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
Though the keyboard and other driver will continue to support the legacy
"gpio-key,wakeup", "linux,wakeup" and "enable-sdio-wakeup" boolean
property to enable the wakeup source, "wakeup-source" is the new
standard binding.
This patch replaces all the legacy wakeup properties with the unified
"wakeup-source" property in order to avoid any futher copy-paste
duplication.
Cc: Sascha Hauer <kernel@pengutronix.de>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Add touch screen surpport for i.MX6UL-EVK board.
Signed-off-by: Haibo Chen <haibo.chen@freescale.com>
i.MX6UL can be powered off by programming SNVS.
When long press ON/OFF button(5 seconds),
PMIC_ON_REQ pin will be set to low and external
PMIC will be powered off.
And system can be powered on by long press ON/OFF
button again.
Signed-off-by: Anson Huang <b20788@freescale.com>
Add ethernet fec1 and fec2 support for i.MX6ul 14x14 evk board.
enable qspi support
Signed-off-by: Frank Li <Frank.Li@freescale.com>
Enable usb host and function driver
Add new SOC i.MX6UL dtb file support, including evk board
support
i.MX6 Ultralite processor include one ARM cortext-A7 core.
Offer high perfomance and lowest power consumption.
Main included:
- 4 MMC/SD/SDIO
- 2 USB 2.0 OTG
- 3 I2S/SAI/AC97
- 4 eCSPI
- 4 I2C
- 2 ENET
- 2 CAN
- 3 wdog
- ASRC
- 8 uart
- LCDIF
- PXP
Signed-off-by: Fancy Fang <chen.fang@freescale.com>
