2019-02-12 | MLK-12623-02 ARM: dts: imx: Add 700MHz setpoint define in dts | Bai Ping | |
According to the latest datasheet(Rev. 0, 12/2015), When the chip is run at LDO enabled mode, the highest setpoint can be set to 700MHz in overdrive mode. Signed-off-by: Bai Ping <ping.bai@nxp.com> | |||
2019-02-12 | MLK-11461-2 ARM: dts: imx6ul: add LDO enable dtb for 9x9 evk board | Anson Huang | |
Add LDO enable dtb for i.MX66UL-9x9-EVK board for those customers who want to use ldo enable mode. Signed-off-by: Anson Huang <b20788@freescale.com> |
