path: root/arch/arm/boot/dts/imx6ul-isiot.dtsi
2019-07-22ARM: dts: imx6ul: fix clock frequency property name of I2C busesSébastien Szymanski
A few boards set clock frequency of their I2C buses with "clock_frequency" property. The right property is "clock-frequency". Signed-off-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com> Reviewed-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2019-05-23ARM: dts: imx: Avoid colliding 'display' node and property namesRob Herring
While properties and child nodes with the same name are valid DT, the practice is not encouraged. Furthermore, the collision is problematic for YAML encoded DT. Let's just avoid the issue and rename the nodes. Cc: Shawn Guo <shawnguo@kernel.org> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Pengutronix Kernel Team <kernel@pengutronix.de> Cc: Fabio Estevam <festevam@gmail.com> Cc: NXP Linux Team <linux-imx@nxp.com> Cc: linux-arm-kernel@lists.infradead.org Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2018-12-10ARM: dts: imx6ul: Fix memory node duplicationFabio Estevam
Boards based on imx6ul have duplicate memory nodes: - One coming from the board dts file: memory@ - One coming from the imx6ul.dtsi file. Fix the duplication by removing the memory node from the dtsi file and by adding 'device_type = "memory";' in the board dts. Reported-by: Rob Herring <robh@kernel.org> Signed-off-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2018-09-03ARM: dts: i.MX6: Use consistent node names for Engicam filesJagan Teki
Use consistent pinctrl node names for Engicam dt files, sufix 'grp' look consistent than actual node name - pinctrl_gpmi_nand: gpmi-nand { + pinctrl_gpmi_nand: gpminandgrp { Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2018-09-03ARM: dts: imx6ul-isiot: Move node definitions into dtsiJagan Teki
Move usdhc2 and gpmi along with pinctrl nodes on imx6ul-isiot.dtsi from dts files and mark it as 'disabled' and the relevant dts will enable the status as 'okay' Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2018-09-03ARM: dts: imx: Switch Engicam boards to use SPDX identifierJagan Teki
Adopt the SPDX license identifier headers to ease license compliance management. Also added Engicam Copyright on missing files. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2018-05-14ARM: dts: imx: Remove #address/#size-cells from stmpe nodesFabio Estevam
Remove unnecessary #address-cells/#size-cells to fix the following DTC warnings: arch/arm/boot/dts/imx6q-novena.dtb: Warning (avoid_unnecessary_addr_size): /soc/aips-bus@2100000/i2c@21a0000/stmpe811@44: unnecessary #address-cells/#size-cells without "ranges" or child "reg" Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2018-03-16ARM: dts: imx6ul-isiot: Pass the required '#sound-dai-cells'Fabio Estevam
DTC now warns about missing #sound-dai-cells: /sound/simple-audio-card,codec: Missing property '#sound-dai-cells' in node /soc/aips-bus@2100000/i2c@21a0000/codec@a or bad phandle (referred from sound-dai[0]) Pass the required '#sound-dai-cells' property to fix it. Reported-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2018-02-12ARM: dts: imx: Add memory node unit nameMarco Franchi
Fix the following warnings from dtc by adding the unit name to memory nodes: Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name Converted using the following command: perl -p0777i -e 's/memory \{\n\t\treg = \<0x+([0-9a-f])/memory\@$1$\0000000 \{\n\t\treg = <0x$1/m' `find ./arch/arm/boot/dts -name "imx*"` The files below were manually fixed: -imx1-ads.dts -imx1-apf9328.dts -imx6q-pistachio.dts Signed-off-by: Marco Franchi <marco.franchi@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-07-16ARM: dts: imx6ul-isiot: Add FEC node supportJagan Teki
Add support for fec1 node on Engicam Is.IoT variant boards. Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-07-16ARM: dts: imx6ul-isiot: Add Sound card with codec nodeJagan Teki
Add support for Sound card and related codec(via i2c1) nodes on Engicam Is.IoT MX6UL variant module boards. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-07-16ARM: dts: imx6ul-isiot: Move common nodes in imx6ul-isiot.dtsiJagan Teki
Maintaining separate dtsi file with common nodes make unclear and confusing since -isiot.dtsi is available for adding common nodes. If the nodes are common between the dts files then mark status as "okay" otherwise mark it "disabled" so-that respective dts can mark status "okay" Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-04-10ARM: dts: imx6ul-[geam|isiot]: Add sai2 nodeJagan Teki
Add Synchronous Audio Interface(SAI) node for Engicam GEAM6UL and Is.IoT MX6UL variant module boards. Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-04-10ARM: dts: imx6ul-isiot: Add i2c nodesJagan Teki
Add support for i2c nodes i2c1 and i2c2 on Is.IoT MX6UL eMMC variant boards. Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-04-10ARM: dts: imx6ul-isiot: Add backlight support for lcdifJagan Teki
This patch add support for lcdif backlight on Is.IoT MX6UL variant boards. Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-01-24ARM: dts: imx6ul: Add Engicam Is.IoT MX6UL eMMC initial supportJagan Teki
Engicam Is.IoT MX6UL has separate module for eMMC, so add emmc dts file for imx6ul-isiot.dtsi, usdhc2 node represent eMMC. dmesg: ----- mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA mmc1: new DDR MMC card at address 0001 mmcblk1: mmc1:0001 M62704 3.53 GiB Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
