path: root/arch/arm/boot/dts/imx6ul-liteboard.dts
2017-08-05ARM: dts: imx6ul-liteboard: Support poweroffMarcin Niestroj
Support proper system power-off, which disables main regulator. This results in much lower power consumption and support of power-on issued by button press. Signed-off-by: Marcin Niestroj <m.niestroj@grinn-global.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-01-10ARM: dts: imx/vf: Correct license textAlexandre Belloni
The license text has been mangled at some point then copy pasted across multiple files. Restore it to what it should be. Note that this is not intended as a license change. Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Afzal Mohammed <afzal.mohd.ma@gmail.com> Acked-by: Michael Trimarchi <michael@amarulasolutions.com> Acked-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-10-24ARM: dts: imx6ul: Add DTS for liteBoardMarcin Niestroj
liteBoard is a development board which uses liteSOM as its base. Hardware specification: * liteSOM (i.MX6UL, DRAM, eMMC) * Ethernet PHY (id 0) * USB host (usb_otg1) * MicroSD slot (uSDHC1) Signed-off-by: Marcin Niestroj <m.niestroj@grinn-global.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
