path: root/arch/arm/boot/dts/imx6ul-phytec-segin-peb-eval-01.dtsi
2019-07-23ARM: dts: imx6ul: segin: Fix LED naming for phyCORE and PEB-EVAL-01Stefan Riedmueller
Fix node name for the user LEDs to prevent the pinctrl of the phyCORE's leds node from being overwritten. Also use more generic names for user LEDs. Signed-off-by: Stefan Riedmueller <s.riedmueller@phytec.de> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2019-07-23ARM: dts: imx6ul: phyboard-segin: Rename dts to PHYTEC name schemeStefan Riedmueller
Use the same name scheme for the phyBOARD-Segin and the phyCORE-i.MX 6UL as is used for the PHYTEC phyBOARD-Mira and phyCORE-i.MX 6. This is only a cosmetic change and there is no functional change intended. Signed-off-by: Stefan Riedmueller <s.riedmueller@phytec.de> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
