The license text has been mangled at some point then copy pasted across
multiple files. Restore it to what it should be.
Note that this is not intended as a license change.
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Acked-by: Afzal Mohammed <afzal.mohd.ma@gmail.com>
Acked-by: Michael Trimarchi <michael@amarulasolutions.com>
Acked-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
imx6ul-pico has WDOG1_B pin connected to the PMIC.
Pass the 'fsl,ext-reset-output' property so that the watchdog
can trigger a system POR reset via PMIC.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
imx6ul-pico-hobbit has a bcm4343 wifi chip connected to usdhc2 port.
Add support for it.
Signed-off-by: Vanessa Maegima <vanessa.maegima@nxp.com>
According to the imx6ul-pico-hobbit schematics the Ethernet PHY reset GPIO
is GPIO1_28, so fix it accordingly.
Also adjust the reset duration to 1ms, because the KSZ8081 datasheet
requires 500μs.
Signed-off-by: Diego Dorta <diego.dorta@nxp.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
As of commit 1006ed7e1b258dac ("serial: imx: Use generic uart-has-rtscts
DT property"), the Freescale IMX UART driver recognizes the generic
"uart-has-rtscts" DT property, deprecating the vendor-specific
"fsl,uart-has-rtscts" DT property. Hence replace the latter by the
former in all DTS files.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Add initial support for imx6ul pico hobbit board.
For information about this board, please visit:
http://www.wandboard.org/images/hobbit/hobbitboard-imx6ul-reva1.pdf
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
