Since TSC has pin conflict with I2C1 which is used by PMIC and Camera,
we need to move TSC setting from LCDIF dts file into a separated one to
achieve the LCDIF and Camera feature in one DTS file. After the change,
we can get the supported features as follows.
-lcdif.dtb: lcd and camera, but no tsc
-tsc.dtb: lcd and tsc, but no camera
Signed-off-by: Robby Cai <robby.cai@nxp.com>
Add touch support for the LCD screen on imx6ull-ddr3-arm2 board.
Due to the touch pin conflict with usbotg1 and I2C1 bus, so this
patch disable I2C1 bus and usbotg1.
Signed-off-by: Haibo Chen <haibo.chen@nxp.com>
lcd touch
Since pwm3 and lcd touch are conflict for one pin, change
backlight to use pwm1 instead. But pwm1 also conflicts with
enet1, so enable backlight in a new dts file.
Signed-off-by: Fancy Fang <chen.fang@nxp.com>
The pwm3 and otg1 share the same pin 'GPIO1_IO04'. And default,
the pin is used for otg1. So create a new dts file to solve
this conflict.
