Due to the errata ERR010450 limit, this patch change the imx6ull
usdhc root clock to 132MHz in soc related dts file, remove all
the root clock setting in board dts file, after this patch,
SDR104/HS200 work at 132MHz, DDR50/DDR52 work at 33MHz.
Signed-off-by: Haibo Chen <haibo.chen@nxp.com>
For imx6ull-14x14-evk emmc rework board, usdhc2 HS200 I/O timing is
not stable @176MHz, for write operation, crc error shows up. So this
patch change the frequence to 132MHz.
Enable eMMC for i.MX6ULL EVK rework board due to the pad conflict with NAND
and Micro-SD.
