Using new "fsl,tx-d-cal" for dts, and update document accordingly.
Acked-by: Jun Li <jun.li@nxp.com>
Signed-off-by: Peter Chen <peter.chen@nxp.com>
The sw2iso count should cover ARM LDO ramp-up time,
the MAX ARM LDO ramp-up time may be up to more than
100us, this patch sets sw2iso to 0xf (~384us) which
is the default value.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Reviewed-by: Bai Ping <ping.bai@nxp.com>
suspend/resume
Upstream suspend/resume already works on this board because it includes
imx6ul-14x14-evk which has these properties set. In our internal branch
the imx6ul and imx6ull DT files are distinct so this needs to be fixed
separately.
Equivalent to commit e6f4292ae0a1 ("ARM: dts: imx6ul-14x14-evk: Add
ksz8081 phy properties")
Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com>
Acked-by: Fugang Duan <fugang.duan@nxp.com>
Add USB OTG1 port ID pin for imx6ull-14x14-evk.dts
Acked-by: Peter Chen <peter.chen@nxp.com>
Signed-off-by: Li Jun <jun.li@nxp.com>
For the slot support SD3.0 card, during system suspend, if plug out
the sd card, and insert another SD3.0 card, after system resume back,
SD3.0 card can't be recognised as SD3.0 card, just SD2.0 card.
This is bause the time delay between vmmc regulator off and on is
too small, this patch add the oo-on-delay in vmmc-supply regulator,
to assign proper delay value.
Signed-off-by: Haibo Chen <haibo.chen@nxp.com>
Move the default arm/soc-supply property define in imx6ull
dtsi file.
Signed-off-by: Bai Ping <ping.bai@nxp.com>
This patch fixes the following warning on various imx boards:
OF: Duplicate name in lcdif@......, renamed to "display#1"
Signed-off-by: Octavian Purdila <octavian.purdila@nxp.com>
Removed the unnecessary imx6ul-evk function node, as it was causing
a kernel panic at boot time due to an enumeration error.
Signed-off-by: Tiberiu Breana <andrei-tiberiu.breana@nxp.com>
The new parameter description is:
gpr = <gpr-node, register-offset, mask, value>;
Signed-off-by: Shengjiu Wang <shengjiu.wang@freescale.com>
Enable eMMC for i.MX6ULL EVK rework board due to the pad conflict with NAND
and Micro-SD.
enable csi and ov564x
Signed-off-by: Robby Cai <robby.cai@gmail.com>
Add DTS file imx6ull-14x14-evk.dts which is originated from i.MX6UL EVK with
some changes:
1. sim2 is removed.
2. Move GPIO5 pins setting to iomuxc-snvs
Signed-off-by: ye li <ye.li@nxp.com>
The license text has been mangled at some point then copy pasted across
multiple files. Restore it to what it should be.
Note that this is not intended as a license change.
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Acked-by: Afzal Mohammed <afzal.mohd.ma@gmail.com>
Acked-by: Michael Trimarchi <michael@amarulasolutions.com>
Acked-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
It is the 10th processor in the well-known imx6 series, and derived
from imx6ul but cost optimized. The more information about imx6ull
can be found at:
http://www.nxp.com/products/microcontrollers-and-processors/
arm-processors/i.mx-applications-processors/i.mx-6-processors
/i.mx6qp/i.mx-6ull-single-core-processor-with-arm-cortex-a7-core
:i.MX6ULL
imx6ul.dtsi is the SoC common stuff for both imx6ul and imx6ull;
imx6ul-14x14-evk.dts is the board common stuff for both imx6ul
and imx6ull 14x14 evk. In this patch, for SoC part, the
imx6ull.dtsi includes imx6ul.dtsi; for board part, imx6ull-14x14-evk.dts
includes imx6ul-14x14-evk.dts.
