All Toradex Colibri family boards support the ecspi interface.
Move the definition of spidev0 to the module devicetree and enable
it by default.
Colibri Eval board has a CAN SPI controller. Disable the spidev0
for this board to have the CAN controller been enabled by default.
Colibri Aster board supports 2 spidev interfaces. Enable both of them
and fix the CS configuration.
Related-to: ELB-3401
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Cosmetic change: Rename the reg_sd1_vmmc to reg_sd1_vqmmc as it is
used for vqmmc.
(cherry picked from commit 838d16630594b3fd69a13b6e1d19ee55ec93a841)
This commit unifys the backlight settings. All displays sold by Toradex
are now supporting 150Hz as a PWM backlight typical frequency.
Use this value for all SoM's and put also some better default values
for different brightness.
(cherry picked from commit 0f2115c3c8934714e88a768ace4c324d08ac9039)
arch/arm64/boot/dts/freescale/fsl-imx8qm-apalis.dts
arch/arm64/boot/dts/freescale/fsl-imx8qxp-colibri-aster.dts
arch/arm64/boot/dts/freescale/fsl-imx8qxp-colibri-eval-v3.dtsi
arch/arm64/boot/dts/freescale/fsl-imx8qxp-colibri-lvds-dual-eval-v3.dts
arch/arm64/boot/dts/freescale/fsl-imx8qxp-colibri-lvds-single-eval-v3.dts
arch/arm64/boot/dts/freescale/fsl-imx8qxp-colibri.dtsi
Do not apply this patch on imx8 dts, as I will pull them in separately
later on.
According to manual of I2C bus, both signals sda/scl are "open drain".
Fix flags for all affected Toradex boards.
(cherry picked from commit c87aa86c2d8fbfb0e0e5f6784e99402316fbb966)
arch/arm/boot/dts/imx7-colibri.dtsi
While at it, add the dtbs for Aster Carrier Board to the Makefile.
(cherry picked from commit 48d236e07b708f9cf9332d568f4ef02b8bbd31d6)
(cherry picked from commit 1a31a12c32bf2fa0ed79fe9dede489f0a0b2f5e0)
