Add the pinmuxing and a inactive node for flexcan1 on SODIMM 55/63
and move the inactive flexcan modes to imx6ull-colibri-eval-v3.dtsi
where they belong.
Note that this commit does not enable flexcan functionality, but rather
eases the effort needed to do so.
(cherry picked from commit 983ff8a6b61e9466beb6b4781fb370a6a7da937a)
arch/arm/boot/dts/imx6ull-colibri-nonwifi.dtsi
arch/arm/boot/dts/imx6ull-colibri-wifi.dtsi
arch/arm/boot/dts/imx6ull-colibri.dtsi
Signed-off-by: Philippe Schenker <philippe.schenker@toradex.com
Pass the memory unit-adress to fix the following build warnings with W=1:
Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name
There are cases where dts passes an empty memory node, which will be filled
by the bootloader. Passing the memory base address still allows the
bootloader to fill the memory size.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Acked-By: Lothar Waßmann <LW@KARO-electronics.de>
(cherry picked from commit edc05819786fd5eee330b89bd5892dad1199effc)
arch/arm/boot/dts/imx6dl-colibri-eval-v3.dts
arch/arm/boot/dts/imx6dl-dfi-fs700-m60.dts
arch/arm/boot/dts/imx6dl-ts4900.dts
arch/arm/boot/dts/imx6dl-ts7970.dts
arch/arm/boot/dts/imx6q-dfi-fs700-m60.dts
arch/arm/boot/dts/imx6q-h100.dts
arch/arm/boot/dts/imx6q-novena.dts
arch/arm/boot/dts/imx6q-ts4900.dts
arch/arm/boot/dts/imx6q-ts7970.dts
arch/arm/boot/dts/imx6q-zii-rdu2.dts
arch/arm/boot/dts/imx6qdl-apalis.dtsi
arch/arm/boot/dts/imx6qdl-cubox-i.dtsi
arch/arm/boot/dts/imx6qdl-hummingboard.dtsi
arch/arm/boot/dts/imx6qdl-hummingboard2.dtsi
arch/arm/boot/dts/imx6qp-zii-rdu2.dts
arch/arm/boot/dts/imx6ul-tx6ul.dtsi
Boards based on imx6ul have duplicate memory nodes:
- One coming from the board dts file: memory@
- One coming from the imx6ul.dtsi file.
Fix the duplication by removing the memory node from the dtsi file
and by adding 'device_type = "memory";' in the board dts.
Reported-by: Rob Herring <robh@kernel.org>
Signed-off-by: Fabio Estevam <festevam@gmail.com>
(cherry picked from commit 750d8df6e7b269b828f66631a1d39ea027afc92a)
Add support for the Computer on Module Colibri iMX6ULL and its
Bluetooth/Wifi variant along with the development/evaluation carrier
board device trees. Follow the usual hierarchic include model,
maintaining shared configuration in imx6ull-colibri.dtsi and
imx6ull-colibri-eval-v3.dtsi respectively.
Signed-off-by: Stefan Agner <stefan@agner.ch>
(cherry picked from commit c2e4987e0e02095ed3d19e958b3891954ef38243)
