path: root/arch/arm/boot/dts/imx6ull-pinfunc.h
2019-02-12MLK-16134 ARM: dts: imx6ull: update imx6ull header file with the latest ↵Fugang Duan
imx6ull RDP Update imx6ull header file with the latest imx6ull RDP. - add new pin function definitions. - update pin function changes. Signed-off-by: Fugang Duan <fugang.duan@nxp.com> Reviewed-by: Richard Zhu <hongxing.zhu@nxp.com>
2016-11-15ARM: dts: imx6ull: add imx6ull supportPeter Chen
It is the 10th processor in the well-known imx6 series, and derived from imx6ul but cost optimized. The more information about imx6ull can be found at: http://www.nxp.com/products/microcontrollers-and-processors/ arm-processors/i.mx-applications-processors/i.mx-6-processors /i.mx6qp/i.mx-6ull-single-core-processor-with-arm-cortex-a7-core :i.MX6ULL imx6ul.dtsi is the SoC common stuff for both imx6ul and imx6ull; imx6ul-14x14-evk.dts is the board common stuff for both imx6ul and imx6ull 14x14 evk. In this patch, for SoC part, the imx6ull.dtsi includes imx6ul.dtsi; for board part, imx6ull-14x14-evk.dts includes imx6ul-14x14-evk.dts. Signed-off-by: Peter Chen <peter.chen@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
