path: root/arch/arm/boot/dts/imx6ull-pinfunc.h
2019-06-19treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 500Thomas Gleixner
Based on 2 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license version 2 as published by the free software foundation this program is free software you can redistribute it and or modify it under the terms of the gnu general public license version 2 as published by the free software foundation # extracted by the scancode license scanner the SPDX license identifier GPL-2.0-only has been chosen to replace the boilerplate/reference in 4122 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Enrico Weigelt <info@metux.net> Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Allison Randal <allison@lohutok.net> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190604081206.933168790@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-09ARM: dts: imx6ull: update iomux headerAnson Huang
Update i.MX6ULL iomux header according to latest reference manual Rev.1, 11/2017. Signed-off-by: Anson Huang <Anson.Huang@nxp.com> Reviewed-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com> Reviewed-by: Rob Herring <robh@kernel.org> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2018-09-03ARM: dts: imx6ull: keep IMX6UL_ prefix for signals on both i.MX6UL and i.MX6ULLSébastien Szymanski
Signals available on both i.MX6UL and i.MX6ULL should have the same name because it is the case of all others common signals, it avoids to make mistakes (use the wrong ones) and it makes writing device tree files less complicated. For example: imx6ul-imx6ull-board.dtsi: ... pinctrl_uart5: uart5grp { fsl,pins = < MX6UL_PAD_UART5_TX_DATA__UART5_DCE_TX 0x1b0b1 MX6UL_PAD_UART5_RX_DATA__UART5_DCE_RX 0x1b0b1 >; }; imx6ul-board.dts: #include <imx6ul.dtsi> #include <imx6ul-imx6ull-board.dtsi> ... imx6ull-board.dts: #include <imx6ull.dtsi> #include <imx6ul-imx6ull-board.dtsi> ... Without this patch, the imx6ull-board.dtb will use MX6UL_PAD_UART5_RX_DATA__UART5_DCE_RX instead of MX6ULL_PAD_UART5_RX_DATA__UART5_DCE_RX and the uart5 will be misconfigured. Signed-off-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2018-05-02ARM: dts: imx6ull: add UART5 RTS input select registerStefan Wahren
The iMX6ULL UART5_RTS_B_DATA_SELECT_INPUT DAISY Register has some different bit definitions to that same register in the i.MX6UL. The bits for the i.MX6UL: 000 CSI_DATA03_ALT8 — Selecting Pad: CSI_DATA03 for Mode: ALT8 001 GPIO1_IO08_ALT8 — Selecting Pad: GPIO1_IO08 for Mode: ALT8 010 GPIO1_IO09_ALT8 — Selecting Pad: GPIO1_IO09 for Mode: ALT8 011 ENET1_RX_EN_ALT1 — Selecting Pad: ENET1_RX_EN for Mode: ALT1 100 ENET1_TX_DATA0_ALT1 — Selecting Pad: ENET1_TX_DATA0 for Mode: ALT1 101 CSI_DATA02_ALT8 — Selecting Pad: CSI_DATA02 for Mode: ALT8 But for the i.MX6ULL: 000 CSI_DATA03_ALT8 — Selecting Pad: CSI_DATA03 for Mode: ALT8 001 GPIO1_IO08_ALT8 — Selecting Pad: GPIO1_IO08 for Mode: ALT8 010 GPIO1_IO09_ALT8 — Selecting Pad: GPIO1_IO09 for Mode: ALT8 011 UART1_CTS_B_ALT9 — Selecting Pad: UART1_CTS_B for Mode: ALT9 100 UART1_RTS_B_ALT9 — Selecting Pad: UART1_RTS_B for Mode: ALT9 101 ENET1_RX_EN_ALT1 — Selecting Pad: ENET1_RX_EN for Mode: ALT1 110 ENET1_TX_DATA0_ALT1 — Selecting Pad: ENET1_TX_DATA0 for Mode: ALT1 111 CSI_DATA02_ALT8 — Selecting Pad: CSI_DATA02 for Mode: ALT8 Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2018-04-18ARM: dts: imx6ull: add UART5 input select register definitionsGreg Ungerer
The iMX6ULL UART5_RX_DATA_SELECT_INPUT DAISY Register has some different bit definitions to that same register in the iMX6UL. The bits for the iMX6UL: 000 CSI_DATA00_ALT8 — Selecting Pad: CSI_DATA00 for Mode: ALT8 001 CSI_DATA01_ALT8 — Selecting Pad: CSI_DATA01 for Mode: ALT8 010 GPIO1_IO04_ALT8 — Selecting Pad: GPIO1_IO04 for Mode: ALT8 011 GPIO1_IO05_ALT8 — Selecting Pad: GPIO1_IO05 for Mode: ALT 100 UART5_TX_DATA_ALT0 — Selecting Pad: UART5_TX_DATA for Mode: ALT 101 UART5_RX_DATA_ALT0 — Selecting Pad: UART5_RX_DATA for Mode: ALT But for the iMX6ULL: 000 CSI_DATA00_ALT8 — Selecting Pad: CSI_DATA00 for Mode: ALT8 001 CSI_DATA01_ALT8 — Selecting Pad: CSI_DATA01 for Mode: ALT8 010 GPIO1_IO04_ALT8 — Selecting Pad: GPIO1_IO04 for Mode: ALT8 011 GPIO1_IO05_ALT8 — Selecting Pad: GPIO1_IO05 for Mode: ALT 100 UART1_TX_DATA_ALT9 — Selecting Pad: UART1_TX_DATA for Mode: ALT9 101 UART1_RX_DATA_ALT9 — Selecting Pad: UART1_RX_DATA for Mode: ALT9 110 UART5_TX_DATA_ALT0 — Selecting Pad: UART5_TX_DATA for Mode: ALT0 111 UART5_RX_DATA_ALT0 — Selecting Pad: UART5_RX_DATA for Mode: ALT0 Specifically for a board I am working on with the serial console on UART5 I need to be able to enable UART5_RX_DATA_ALT0 mode. There is no definition for the iMX6ULL version of that in imx6ul-pinfunc.h or imx6ull-pinfunc.h. Add definitions for the missing UART5 input select register bits of the iMX6ULL. Signed-off-by: Greg Ungerer <gerg@linux-m68k.org> Acked-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-11-15ARM: dts: imx6ull: add imx6ull supportPeter Chen
It is the 10th processor in the well-known imx6 series, and derived from imx6ul but cost optimized. The more information about imx6ull can be found at: http://www.nxp.com/products/microcontrollers-and-processors/ arm-processors/i.mx-applications-processors/i.mx-6-processors /i.mx6qp/i.mx-6ull-single-core-processor-with-arm-cortex-a7-core :i.MX6ULL imx6ul.dtsi is the SoC common stuff for both imx6ul and imx6ull; imx6ul-14x14-evk.dts is the board common stuff for both imx6ul and imx6ull 14x14 evk. In this patch, for SoC part, the imx6ull.dtsi includes imx6ul.dtsi; for board part, imx6ull-14x14-evk.dts includes imx6ul-14x14-evk.dts. Signed-off-by: Peter Chen <peter.chen@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
