The pin GPIO1_IO01 externally pulls down, it is required to sequentially
connect this pin (signal WAKE_MICO#) to +3v3 and then disconnect it to
trigger a wakeup interrupt.
Adding the flag GPIO_PULL_DOWN allows the system to be woken up just
connecting the pin GPIO1_IO01 to +3v3.
Related-to: ELB-2901
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
This commit unifys the backlight settings. All displays sold by Toradex
are now supporting 150Hz as a PWM backlight typical frequency.
Use this value for all SoM's and put also some better default values
for different brightness.
(cherry picked from commit 0f2115c3c8934714e88a768ace4c324d08ac9039)
arch/arm64/boot/dts/freescale/fsl-imx8qm-apalis.dts
arch/arm64/boot/dts/freescale/fsl-imx8qxp-colibri-aster.dts
arch/arm64/boot/dts/freescale/fsl-imx8qxp-colibri-eval-v3.dtsi
arch/arm64/boot/dts/freescale/fsl-imx8qxp-colibri-lvds-dual-eval-v3.dts
arch/arm64/boot/dts/freescale/fsl-imx8qxp-colibri-lvds-single-eval-v3.dts
arch/arm64/boot/dts/freescale/fsl-imx8qxp-colibri.dtsi
Do not apply this patch on imx8 dts, as I will pull them in separately
later on.
