path: root/arch/arm/boot/dts/imx7d-colibri-emmc.dtsi
2020-02-09ARM: dts (ds): imx7: merge changes from toradex_4.9-2.3.x-imx-nextPhilippe Schenker
Merge changes from Toradex Linux 4.9 BSP. Signed-off-by: Philippe Schenker <philippe.schenker@toradex.com>
2020-02-09ARM: dts: imx7: Fix memory node duplicationFabio Estevam
Boards based on imx7 have duplicate memory nodes: - One coming from the board dts file: memory@ - One coming from the imx7s.dtsi file. Fix the duplication by removing the memory node from the dtsi file and by adding 'device_type = "memory";' in the board dts. Reported-by: Rob Herring <robh@kernel.org> Signed-off-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org> (cherry picked from commit 29988e867cb17de7119e971f9acfad2c3fccdb47) Conflicts: arch/arm/boot/dts/imx7d-cl-som-imx7.dts arch/arm/boot/dts/imx7d-colibri-emmc.dtsi arch/arm/boot/dts/imx7d-colibri.dtsi arch/arm/boot/dts/imx7d-nitrogen7.dts arch/arm/boot/dts/imx7d-pico.dtsi arch/arm/boot/dts/imx7d-sdb.dts arch/arm/boot/dts/imx7s-colibri.dtsi arch/arm/boot/dts/imx7s-warp.dts arch/arm/boot/dts/imx7s.dtsi Signed-off-by: Philippe Schenker <philippe.schenker@toradex.com>
2020-02-09ARM: dts: imx7: add Toradex Colibri iMX7D 1GB (eMMC) supportStefan Agner
Add support for the Computer on Module Colibri iMX7D 1GB along with the Colibri Evaluation Board device trees. Follow the usual hierarchic include model, maintaining shared configuration in imx7-colibri.dtsi and imx7-colibri-eval-v3.dtsi respectively. Signed-off-by: Stefan Agner <stefan@agner.ch> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org> (cherry picked from commit f928a4a377e476525298a552185dfd92d2780319)
