The Colibri default which enables USB Host power is not necessarily
tied to the OTG2 controller, some carrier board use the pin to
control USB power for both controllers. Hence name the pinctrl
group more generic.
Also move the regulator to the generic eval-v3 device tree since
the regulator is always on the carrier board. In the Colibri iMX7S
case the regulator is just not used. This allows to reuse the
regulator in a upcoming SKU Colibri iMX7D 1GB with eMMC.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
(cherry picked from commit 7e81cb3d9cf5a7cc56606a63ca6f100bb3f1f5de)
Model the Carrier Board power distribution by adding a fixed 3.3V
and 5V regulator. The 3.3V regulator is connected to the backlight
as well as the display supply. The 5V regulator is used to supply
USB VBUS.
Add support for the Computer on Module Colibri iMX7S/iMX7D along
with the development/evaluation carrier board device trees. Follow
the usual hierarchic include model, maintaining shared configuration
in imx7-colibri.dtsi and imx7-colibri-eval-v3.dtsi respectively.
