path: root/arch/arm/boot/dts/imx7d-colibri-eval-v3.dts
2020-02-09ARM: dts: imx7-colibri: move and rename USB Host power regulatorStefan Agner
The Colibri default which enables USB Host power is not necessarily tied to the OTG2 controller, some carrier board use the pin to control USB power for both controllers. Hence name the pinctrl group more generic. Also move the regulator to the generic eval-v3 device tree since the regulator is always on the carrier board. In the Colibri iMX7S case the regulator is just not used. This allows to reuse the regulator in a upcoming SKU Colibri iMX7D 1GB with eMMC. Signed-off-by: Stefan Agner <stefan@agner.ch> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org> (cherry picked from commit 7e81cb3d9cf5a7cc56606a63ca6f100bb3f1f5de)
2017-04-10ARM: dts: imx7-colibri: add Carrier Board 3.3V/5V regulatorsStefan Agner
Model the Carrier Board power distribution by adding a fixed 3.3V and 5V regulator. The 3.3V regulator is connected to the backlight as well as the display supply. The 5V regulator is used to supply USB VBUS. Signed-off-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-06-28ARM: dts: imx7: add Toradex Colibri iMX7S/iMX7D supportStefan Agner
Add support for the Computer on Module Colibri iMX7S/iMX7D along with the development/evaluation carrier board device trees. Follow the usual hierarchic include model, maintaining shared configuration in imx7-colibri.dtsi and imx7-colibri-eval-v3.dtsi respectively. Signed-off-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
