[ Upstream commit f15096f12a4e9340168df5fdd9201aa8ed60d59e ]
According to bindings/regulator/fixed-regulator.txt the 'clocks' and
'clock-names' properties are not valid ones.
In order to turn on the Wifi clock the correct location for describing
the CLKO2 clock is via a mmc-pwrseq handle, so do it accordingly.
Fixes: 56354959cfec ("ARM: dts: imx: add Boundary Devices Nitrogen7 board")
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Acked-by: Troy Kisky <troy.kisky@boundarydevices.com>
Change "WDOD1" to "WDOG1" in watchdog pin names.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
The PWM driver has now capability to specify the PWM polarity
which is e.g. for backlight control. Allow to make use of PWM
polarity by specifying pwm-cells to be 3 in the base dt.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
The rv4162 compatbile string is missing the vendor part, add it.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Gary Bisson <gary.bisson@boundarydevices.com>
The i.MX7 has two iomux controllers. the iomuxc and the iomuxc_lpsr.
In a board dts we have to make sure that both controllers are supplied
with the correct pins. It's way too easy to do this wrong since only
a look into the reference manual can reveal which pins belong to which
controller. To make this clearer add "LPSR" to the pin names which
belong to the LPSR controller.
The base device tree uses KEY_POWER in the snvs-powerkey node,
hence include the input.h header file in the base device tree.
The i.MX 7Solo implements a subset of features available on
i.MX 7Dual. Recreate imx7s.dtsi as the base device tree for
i.MX 7Dual boards. The i.MX 7Dual's additional features over
i.MX 7Solo are:
- Second Cortex-A7 core
- Second Gigabit Ethernet controller
- EPD (Electronc Paper Display, not yet part of the device tree)
- PCIe (not yet part of the device tree)
- Additional USB2.0 OTG controller
The i.MX 7 series currently consists of two SoCs: i.MX 7Solo and
7Dual. The former has a subset of features of the latter, hence
use imx7s.dtsi as the new base device tree. To keep diffstat nice,
just move imx7d.dtsi to imx7s.dtsi temporarily and recreate
imx7d.dtsi in a second commit.
As of commit 1006ed7e1b258dac ("serial: imx: Use generic uart-has-rtscts
DT property"), the Freescale IMX UART driver recognizes the generic
"uart-has-rtscts" DT property, deprecating the vendor-specific
"fsl,uart-has-rtscts" DT property. Hence replace the latter by the
former in all DTS files.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Based on i.MX7 Dual with 1GB of RAM.
https://boundarydevices.com/product/nitrogen7/
Signed-off-by: Gary Bisson <gary.bisson@boundarydevices.com>
